Looking for different ways to sequence gear door system in a Cougar
As we all know there are a lot of different ways to sequence the gear and doors in a scale jet. But I personally have very little experience with this stuff. The Cougar main doors retract after the gear extends.
1. UP 2 and UP4 valves. A proven system to mechanically do this sequence. But a mess of tubing!
2. UP2 and a simple servo actuated two way valve for the nose gear doors. With some sort of mechanical servo sequencing.
3. EV5, love it in my Hawk but since DW discontinued it I want to avoid buying another.
So I am interested in other ways to do this. Just for comparison. I imagine that with the powerful programming options available in our modern radios there may be some cool ways to do this sequencing in the transmitter rather than buying standalone sequencers but I am open to anything. Light and simple is my mantra. Low cost next.
Connect the door open to the gear down line, so when gear goes down and is down, door is open. Then use the singe action valve to close the door. The valve will be in a different channel, mixed with the gear channel and with a long delay. The other option is, if you have a DX18 or equivalent radio, to have the single action with a sequencing program, so it activates with the desired delay.
But to be honest, the Up2 + UP4 is sooooo simple, that I would just go that route
Jack
PS: get a DX18!!!!
What radio do you have?
If your radio is smart you could use a couple of mini servo driven valves.
Simple, cheap, light, easy to understand.
I'm doing sequencing doors using that system.
John.
John.
This is my Cougar install.
I love UP valves, they are my go to first choice for any sequenced set up, never had a failure or problem in 15 years-But its important the cylinders seal or the sequencing don't work!
I check each ram before installing. This DJ model has Robart and UP Cylinders which are always good
D
D
I read your post with great interest, as I am working on a Ziroli Panther. I also have Robart retracts and the UP-2 & UP-4 units. I first made up a mock up of the arrangement so that I could make the timing adjustments to the valves, then moved everything to the airframe. I used colored tubing for the sake of management , I also keep in mind future maintenance and repair, I currently have the air system mounted on to a plywood platform, there will be more adjustments, I also use only the brass "T" from Robart these appear to be leakfree
You cannot make adjustments like that really, the capped off lines will give an instant pressure lock to fire the next shuttle in the valve. In use with retracts and door cylinders plumbed the time the cylinder/ram takes to lock and build pressure will be different. Each and every UP set up I have used is installed as used, pressured to expected pressure 90-110psi depending on gear (leg length and wheel weight) If the legs are big and heavy sometimes I crack the retract in (up) needle a little further out for more air. Then go, rarely need to change anything after that! Amazing.
I have used 2 JT valves on my Hawk and CT-114 and DSX-12 programming, but doors all stay open, so simple. My GJC Mig 15 has a UP3 and is faultless over 2 seasons, When I finally build my DJ Hunter it will use a UP3. Its now my favourite supply on the CARF Hawk too.
