If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 5 of 5
  1. #1
    olnico's Avatar
    Join Date
    May 2007
    Houston, Texas.
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    First carbon fiber 3D printed component: Diamond gear doors.
    This is another World first from Ultimate Jets.
    The first commercial application of 3D carbon fiber printed components.
    This is a super high tech application that is going to be available very soon to our customers.
    The parts is made from my highly modified Stratasys printer, using NEFCAR. The component is a very unique thermo-activated nano carbon fiber charged NOVALAC epoxy resin.
    World's first: 3D printing carbon fiber honeycomb material.
    Here are a few pictures describing the process:
    1. The parts are CAD designed. This is a very long and precise step as I integrate the hinge recess, reinforcements and control horn from the CAD stage ( to minimize the setup work for the customer).
    Note on this screen capture of the main door that the strut and rotation pins recess are integrated in the design.
    2. The part is 3D printed.
    A specific algorythm is used to create 3D honeycomb filling of the parts. The upper and lower skin are composed of 4 very thin 0.15 mm layers of material printed at different angles to improve stiffness.
    The following picture shows the first two layers at 45 degrees that are designed to give torsional rigidity. Note that the carbon fiber structure that aligns with the print head is clearly visible here.
    Here is another picture of the 3D honeycomb filling being printed.
    Here is a small diagram of what 3D honeycomb looks like:
    The honeyconmb structure is visible vertically ( octogonal ) but also laterally ( pentagonal ) in two directions. On the gear door, the lateral pattern is used from top down.
    Here is the nose gear door before fitting:
    Note the following on this door:
    . Internal 3D honeycomb structure
    . Ellipsoidal cavities
    . 45 degrees chamfers
    . Integrates control horn
    . Crazy light weight ( less than 20 grs ) and super high stiffness.
    Here is the main gear secondary door:
    . Hinge recess
    . Crazy light weight as well ( less than 15 grs ).
    The top layers on all doors are very thin at 150 microns each ( 300 microns total thickness ) but add a tremendous amount of rigidity to the doors.
    3. The kit comes with all the doors, PYCABS printed door brackets ( for shock resistance ), 3 JR 3421 servos, 6 ball hinges and threaded rods, screws and hardware and a set of very precise instructions, minimizing the assembly time. Everything is laid down: from servo position, ball link position on the servo arm to gluing techniques and programming.
    Here are the doors fitted on the plane:
    The door servo fits perfectly in the gear bay, just besides the wheel. It is fixed with my PYCABS Ultimate Servo Brackets:
    Oli. Utimate Jets, Weatronic USA.
  2. #2
    Join Date
    Oct 2004
    Durham, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Very nice!... Can you make fuel tanks, bulkheads, elevators,wings .... ? The fuel tanks could have internal suport very strong light
    Jim \"Bullet\"
  3. #3
    erbroens's Avatar
    Join Date
    Nov 2003
    Curitiba, Parana, BRAZIL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Beautiful!
  4. #4
    olnico's Avatar
    Join Date
    May 2007
    Houston, Texas.
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Quote Originally Posted by EDFJim View Post
    Yes but with limitations:
    I could print a tank from pure polycarbonate. This is the only thermoplastic that is fuel proof and shock proof.
    NEFCAR is not shock proof, not transparent and quite porous.
    Bulkheads are easy to print but the build plate dimensions are limited. Still, would work for most medium size jets.
    Elevators and wings are too big.
  5. #5
    Join Date
    Dec 2004
    Neuburg, GERMANY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    What are the max dimensions?
    Thx
    Hank
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
