Transmitter Control for Wheel Air Brakes...?
I’m currently contemplating by first venture in RC Jets and I have been trying to educate myself on the various aspect of Turbine install and operation etc.
One question I have which I can’t seem to answer by the powers of Google is what switch / mix / control etc. do you use to operate the air wheel brakes on your models..?
I’m a mode 2 flyer and interested how this should be configure on the transmitter – I’m also assuming its proportional in operation rather than just an on / off function….?
So is it usual convention to use the down elevator to operate the brakes..?
I have a DX18 and regularly use flight modes; so I would have a ‘Take off’ and ‘Landing mode’ that would drop the gear and enable the brakes and the allow mixing of the down elevator (centre to full down) to proportionally operate the brakes (off to full).
Clearly in an actually flying or gear up mode I would disable this.
Does this sound okay? I guess I’m really asking so another more skilled pilot could check out my plane with the correct convention around brake operation.
My Feedback: (9)
Right slider is what I use.
I would not use the elevator channel unless you are out of channels. If your landing a little hot and go down elevator to engage brakes and can make it hop on the nose and break the nose gear and also on a short runway when you should be using all the elevator you have to keep it airborne to bleed off speed you end up doing a carrier landing and slamming down elevator.
My Feedback: (7)
AB, CANADA
Right slider and UP-6 valve, pull slider towards you to brake. I've tweeked the ATV and sub-trim so having the slider at the mid point gives smooth moderate braking during landing roll out. Slider all the way back is brakes on full (and parking brake)
There's is perhaps also a trend toward electrically driven gear and electromagnetic brakes and potentially more reliable and less hassle than air. That's not a given though, and there are proponents for both methods.
Guys with Jeti DS-16 are using built in proportional gyros, tilt transmitter towards you activates wheel brakes.
We also recommend combine your air system with Telemetry Air Pressure Sensor Jeti MBar.
Zb/Jeti USA
Zb/Jeti USA
FL
I use a BVM Smooth Stop II on the right slider(AUX 3, JR12X).. The Smooth Stop is totally proportional and offers a parking brake. Slider up is brakes off, down is brakes on.
Also, I use three flight modes, controlled by the flap switch. Flight modes are neat, as you can independently trim them and they retain their trim memory. They reduce the pilot workload substantially.
I do not mix the landing gear to a flight mode. The landing gear is totally independent of any other control.
If you mix the landing gear to the flight modes, the gear would retract when the flaps go up. This makes the landing gear doors unhappy.
Flight mode (Flap) switch position assignment:
Switch top position: Flight mode 0, clean airframe.
Switch center position: Flight mode 1, flaps at take off position.
Switch lower position: Flight mode 2, flaps at landing position.Flight mode 2 can also contain a mixer to allow "Crow". I use this on my KingCat.
I also use the servo slow feature to prevent quick pitch changes when actuating the flaps.You can do this with your DX18.
I usually retract the gear, then the flaps after take off.
When landing, I reduce power to about 1/3, drop the gear, then lower the flaps to the take off position, then to the landing position after bleeding off some airspeed. the airplane has slowed down.
It is best, IMHO, to make the 'switchology" as simple as possible...use the 'KISS' principle".
if this is your first jet keep it simple and cheap use a on/off switch, which ever one you find the simplest to operate and apply a little lube to the brake to stop it locking the wheel then if you need to just flick it on and off
My Feedback: (54)
IMHO......NEVER use "Down Elevator"!! That is the old way, when there weren't enough channels on the radios! The jets you see bouncing down the runway, are the ones that are using down elevator! This lifts the jet's weight off of the mains, thus reducing braking action when the wheels are in contact with the pavement; and if the pilot was too fast, it bounces down the runway. Use what becomes the "Non-flying Hand". After the mains touch down the left hand becomes the flying hand, so, the right slider is the best choice and can be proportional. The guys' who use a 3 position switch are also the ones you see spin out, due the locking of the brakes. BVM Smooth Stop/servo/ and right slider/ 12X
U.P. 6 using right slider and elevator when the gear is down. Elevator to brake mix is set up so it won't lock, only slow things down. Slider is set to do the same, but also lock for starts. I have found that the elevator stick is by far more precise than slider, especially when you consider expo.
My Feedback: (54)
There is a reason that full down elevator isn't used on full scale jets after landing, until below 80 knots. Full down below 80 knots is for positive steering, especially for loss of engine, wet runway, or ice/snow runway. Using full down elevator prior to 80 knots lifts the jets off of the mains and isn't the most affective way to stop a jet.
