Unilight System
#51
As I am getting to that much closer into the build I am going to have to get to this sooner than later. I think I will take you up on the nose gear. I have a PM into the fellow who's picture I borrowed. I think he made his own lens. Maybe he can help out too. Let me now Mike what you would need on costs and things.
Alan
Alan
#52
Raf...
Mike and I use the lights and the 4ch controller in our Viperjets when we fly formation. We have over 125 flights with that setup and no problems with either the lights or the controller. We also punish them a little more than average by leaving the landing lights (six of them in each airplane) on for the entire flight.
KennyMac
KennyMac
#53
My Feedback: (16)
Hello? Anyone still around? I bought a few unilights for my Z B25 (strobes, landing lights), and have a few questions regarding mounting... How are you guys attaching these? Is it ok to epoxy in place? Wood mts? Silicone? I email Alex, but he only responded to one of the questions I had.... Any input would help.. Thanks in advance!
K.O.
#55
"I made a wood mount similar to yours. To secure it a little better I used some of the heat resistant glue they sell. Pretty similar to Rtv in its not permanent like epoxy or hysol."
I'm at work or I'd post a pic. Lemme know if you want to see what I did.... thanks for your reply
#56
My Feedback: (7)
Help !!!
I've got the 8ch Pro Controller running a varity of lights on a 3 position switch - OFF / Scheme 2- Anti-collision lights, Scheme 5 Anticollision and Nav lights. Now I am adding landing light and I have the " Servo 1 " lead Y-d to the gear channel... Landing light is not responding to the gear channel command... Just stays on in Scheme 2 & 5... I want the landing light to come on in Scheme 2 & 5 but only when the gear is in the down position... I assume I am missing something.. Bigtime !! I even mixed the gear channel to an Aux channel and plugged "servo 1 " into that and I get the same result as the y-harness.. I sure could use some help...
Cheers,
Dan
Cheers,
Dan
#58
Hi, yes you are missing something :-)
The servo 1 & 2 are outputs to control dropout lights or similiar. Landing lights should be programmed and selected by your transmitter same as the other light schemes. Have a look to the short tutorial
g. Ulrich
g. Ulrich
#59
My Feedback: (7)
Yes !! I missed " Bigley " !!! I did figure out that the servo ouputs were not what I thought and operate drop lights and such... I had to do a mix in the radio to the gear channel and create additional Schemes in the layout... I don't know how I did it but I did it... It's working as wanted. Thanks for your help, the tutorial makes sense now !! Awesome lighting, Im sure we will be doing more in the future !!!
Cheers,
Dan
Cheers,
Dan
#60
Yes, the gear dependend landing light is bit a bit "advanced" stuff. But there is a lot possible with this kind of programming and modern transmitters. And the standard controlling by a 3-position switch is quite fine for 90% of all cases ;-)
#62
Yes, a very small amount of cyno.
Carefully position the lens on the light to make sure it's central first, a bit of cyno on the end of a pin or similar and slight finger pressure on the lens.
Capilliary action will do the trick!
Gary.
Gary.
#65
Hi,
A little bit epoxy is the safer way. Easier to handle and adjust, better compensate temperature differences and no risk of fogging the lense. Additional you can use a small stripe of tape around the reflector to hold the lens centered while drying, also looks very nice when it is only 3mm wide...
bstussie (10-13-2020)
#69
Hi
I am having a lot of trouble setting up the 8 channel controller. Lost now several hours trying to connect and though I am now connected and conncetion dor is blinking, I can not run the controller with the servo tester. The bars dont light up and there is this message error processing data 0002
I send a mail to Unilight and saw their tutorial in youtube, but going crazy with this..... hope it is not defective
Any one go thru this issue?
Nuno
Nuno
#70
Nuno try to click on the Com port on the top left of the screen. Cycle through the port numbers and see if that picks up your receiver signal which will light up the bars. Mine was not correct by default and I had to search for the correct port. Once I got the right one it was all good. May not be the case with yours but worth a try.
#72
Darn! I was under the impression that the light would strobe by itself w/o the unilight controller. I really wish Dreamworks would specifically state on their site that the controller is needed for the light to strobe. In addition, I thought the unilight controller could make any light you want to strobe so I'm not sure why some are labeled strobes and others are not...The cheapo $3 light I bought from HK strobes by itself!
#73
good day
I am trying to reset black 4 module but is unable to do it.
I follow the instruction but when finish the blue light makes 6 blinks next 1 long blink and start again the sequence, all time the four lights are on and don’t recognize the signal transmitter, I made a lot of resets but nothing happens simply all time the 4 lights are on.
thanks for your help
javier
javier
#74
Javier, I would advise you to email unilight describing the problem, if it's faulty which I suspect they will authorise a repair.
Their service is very good!
Gary.
Gary.
