byron f16 help
IA
byron f16 help
hello, I recently acquired a Byron f16 built, painted, just needed radio installed and some minor work. then I found that it is missing the rear former that goes across under the vertical fin, so the fin and the stabilizer have no support. would anyone happen to have a template so I can cut a new one ? thanks in advance lyle
Mine didnt have one either. Just take a piece of cardboard and keep trimming till it fits and then use as a template for the plywood.
I think the original never had that former, and perhaps later versions did. Not really sure.. but it is a very good idea to install one as the back ends were known to break off these planes.
The earlier versions didn't have that former. As Vettster stated, using a cardboard template would be your best bet.
Iron bay are kind of not really in business. they were taken over by another company who still sort of operates it. Their main business is with military contracts so they don't pay much attention to R/C customers. there are many a thread about how unhappy or how much effort it has been to get anything out of them for these models. i waited bout 2 months for a canopy for the F-16.
Watch out if you make a large (i.e. scale) cutout for the nose gear as you will have to fit a gear door to it. It created massive amounts of drag for me on mine!!
here is were there is heaps of info on the byron f-16
http://www.rcgroups.com/forums/showt...=ticketec+f+16
Dave
Dave
When you make your former you might want to follow it down the inside of the Fuselage a little. Between the thrust tube and the fiberglass. It will look a little like a wishbone.
You want to put a little stiffness in the vertical fin so it doesn't flutter at high speed.
Happy Flying!
Happy Flying!
IA
thank you for the info guys, looks like I just needed to put a little more thought into it . hopefully i'll get it up and flying and maybe try to put it on video. thanks again
My Feedback: (34)
I made mine my self, also boxing the inside with some light ply will stiffen things up.
I flew mine with an AMT180 and p80
Great flyer but it was very heavy metal. Around 21 will no fuel.
I also added carbon fiber coth across the top of the fuse to stiffen it in the retract areas
What do you plan on for fuel?
I used 3 24oz tanks in s U shape with the bottom of the u on the top side
IA
i'm thinking maybe a piano wire formed to the fuse and up into the fin area , and bond with maybe j b weld, just keep it lite as possible. it's got an os 77 , plan on 30 % . thanks
My Feedback: (29)
What do you plan on for fuel?...........it's got an os 77 , plan on 30 %
Here's my build thread. http://www.rcuniverse.com/forum/rc-j...version-2.html
I have some pretty good photos of the formers I made and showing them installed on the second page
Hope this helps
Hope this helps
My Feedback: (101)
believe it or not, I have had nothing but good luck with Iron Bay. I ordered some parts for the Byron F20 which I converted to turbine.I also have some Wildcat D/F fuel...a case I think unopened. I would consider parting with some. I only have 2 DF jets left, TG Mig 29 and AD Rafeal. One trick I have done to help strengthen, stiffen and fill is to use expandable foam from your hardware store. Doesn't add a lot of weight
os 77 will just fly it u have to be on your toes ive had 5 of the f16 all had os 91 fan engines>> i did not have any stifner in the stab on any of them i never installed a rudder servo glued it> i put in a servo on each side under the stab on one i put in a servo on each wing for the ailerons do not lean the engine out to leanhappy flying
IA
wow, I didn't realize 30 % was too much. glad I mentioned it. all you guys are very helpful , and I appreciate it very much. I've been at this a long time, but have 0 experience with ducted fan engines with tuned pipes. thanks everyone !
