Reload this Page >
Airworld Hawk 1:4.5 Pitot
Old 01-20-2015, 05:34 AM
fireblade5437
fireblade5437's Avatar
Hey hope you haven't bent it!
You must have quite a few flights on that Hawk by now..
Alan
Originally Posted by husafreak
FWIW I have one of Alan's probes on my CARF Hawk and it is very noticeable in flight, they look the part!
Old 01-20-2015, 03:45 PM
fireblade5437
Wayne
Have started your 1:4 pitot tonight, seeing that this one is first 1:4 I have made is seems massive after doing many CARF ones!
Please can you check distance from headlight lens to edge of moulding (where pitot fits in the moulding)
Paul, Toby and Extraviking all will be in post in the morning.
Alan
Originally Posted by wayne1965
Hi alan
if you can sort one for the larger 1/4 scale airworld I'll have one if possible thanks for your time
Regards wayne
Old 01-21-2015, 10:09 AM
Dave03B
Wayne, will get back to you with the info you requested as soon as I can.
Old 01-21-2015, 10:15 AM
wayne1965
Hi dave
thanks for that I aprieciate it, hope things are all well with you and your enjoying the hawk ��
Old 01-22-2015, 08:34 AM
Paul0088
Got my pitot very nice thanks Alan
Paul ..
Old 01-22-2015, 10:40 AM
  #31
fireblade5437
Paul
Good it arrived ok..
Alan
Old 01-23-2015, 10:27 AM
  #32
fireblade5437
Wayne
Have finished your 1:4 AW pitot, hope to get it into the post tomorrow morning.
The insert I have made is 6mm, if this has to be changed for any reason I will make you another one as this is the first 1:4 etc
Degrease the insert and glue in with Hysol, leave a few thou proud so when you tighten up the probe it tightens onto the insert and not the moulding etc the very small gap will not be noticeable. It will appear as if it tightens up to the moulding.
Alan
Old 01-23-2015, 11:10 AM
  #33
wayne1965
Hi alan
now that's what I'm talking about these has got to be the best probes I've seen, many thanks for your time and help
Regards wayne
Old 01-23-2015, 12:06 PM
  #34
Newton5019
Thanks once again Alan, will get some pictures of the hawk this weekend for you
toby
Old 01-23-2015, 01:42 PM
  #35
fireblade5437
Toby
No problem, look forward to seeing some pics
Alan
Old 01-24-2015, 02:48 AM
  #36
fireblade5437
Wayne
In the post so should be with you am Monday
Alan
Old 01-24-2015, 02:49 AM
  #37
fireblade5437
Double Post.
Old 01-26-2015, 02:30 PM
  #38
wayne1965
Hi alan
just to let you know the probe came today and it's the icing on the cake, it's the dogs danglers thanks very much aprieciate your help and fast service
All the best wayne
Old 01-26-2015, 02:44 PM
  #39
fireblade5437
Wayne
Would be interested in seeing a pic of the whole plane with pitot fitted seeing that it is the first 1:4 that I have done, glad you like it!
Alan
Old 01-27-2015, 10:49 AM
  #40
Extraviking
My AW 14,5
Old 01-27-2015, 10:53 AM
  #41
fireblade5437
Hi Extraviking
Looks great finishes that nose off!
Glad you are happy with it
Alan
Old 01-27-2015, 01:07 PM
  #42
wayne1965
Hi alan
ill be home tomorrow night I'll do pic then, all I can say your a good machinist , I'll pm you about the other job I asked you about
Regards wayne
Old 01-27-2015, 05:22 PM
  #43
salvamento
Hi, this looks nice.
I would love to place an order on one of these pitot for my AW Hawk 1:4,5
Reg
Tor H
Old 01-28-2015, 11:27 AM
  #44
wayne1965
Here's a few pics bit of a rush and struggle in workshop but you will get the idea looks great 
ID:	2068629   Click image for larger version
  #45
wayne1965
Here's a few pics bit of a rush and struggle in workshop but you will get the idea looks great 😃
Old 01-28-2015, 03:00 PM
  #46
fireblade5437
PM sent
Alan
Reg
Tor H
Old 01-28-2015, 03:07 PM
  #47
fireblade5437
Wayne
Looks spot on... Hawk now complete :-)
Alan
Old 01-31-2015, 07:34 AM
  #48
fireblade5437
John
Looks like your LIVE 1:4.5 pitot has worked out, not easy to drill but used Jet A1 as lubricant.
Drilled hole is 2.5mm at the inlet for 20mm then it goes down to 2mm for rest of the pitot. I had to drill the M4 stainless mounting thread separately but again at 2mm there should be prenty of strength left to do the job.
Just have to make the insert, what size pipe you thinking of using? I am thinking the BVM 1/8th pink/purple stuff that we use on the air valves etc let me know
Alan
Tested with BVM small air pipe and you can with a bit of patience make it fit, so if you need a bit bigger ie festo that should also fit...
No seal required for pitot > insert as when screwed together there is no leak.
ID:	2069345   Click image for larger version
ID:	2069346   Click image for larger version
ID:	2069582   Click image for larger version
ID:	2069583   Click image for larger version
Old 02-01-2015, 01:30 PM
  #49
JohnMac
JohnMac's Avatar
Hi Alan,
I picked up a new airspeed sensor form Jeti in Nuremberg. Ideally I would like to feed air down the scale inlet th the calibrated probe. The hole in the front of the probe is about 1mm so this should work OK. I will make up a braket to allow the 4mm bolt to fit in and also to hold the probe I will just have to be sure that the alignment is good.
Unfortunately I can't get the pictures to enlarge, so I can't see your work properly, but I am sure I can make it work.
BR
John
Old 02-01-2015, 01:40 PM
  #50
fireblade5437
Hi John
If you want me to machine anything to make the probe fit to the new sensor let me know.
Could you not fit the insert I have made and connect the end of the insert to your new sensor with a very sort piece pipe?
I have blown down the complete length and to be honest there is not a lot of resistance with the hole being 2mm so it should be able to supply pressure ok to your sensor.
Alan
