Reload this Page >
JR 28x information
JR 28x information
Old 03-28-2015, 11:43 AM
  #201
c_makhija
Hi Dave,
In the 28X are 2 batteries used as a redundant system?
Chatty.
Old 03-28-2015, 12:02 PM
  #202
jcterrettaz
jcterrettaz's Avatar
from what I read is to fly all week the radio come with one pack only
Old 03-28-2015, 02:09 PM
  #203
Dave Wilshere
Originally Posted by c_makhija
Hi Dave,
Chatty.
Not really, but with two in, if one fails that it will keep working on the other. You can set it to use both together or one after an other.
For me its a weekends flying with no charging needed! 6400mAh :-)
Std DMSS radios are very good on battery, but with all the bling and lit screen this will use more!
Dave
Old 03-28-2015, 02:34 PM
  #204
drac1
drac1's Avatar
Hi Dave,
What's the difference between the 712 and 731 receiver?
Scott
Old 03-28-2015, 04:57 PM
  #205
Airman98
My Feedback: (9)
Airman98's Avatar
The 712 has a port to plug in a extra antenna giving you four ant. The 712 has path diversity so no need for a third ant for telemetry. It also has 28 channel capability while according to manual the 731 is limited to 17 channels. Im using a 712 on my jet with a 36in lead going to the remote ant at the rear of my jet.
Old 03-28-2015, 11:03 PM
  #206
Airman98
My Feedback: (9)
Airman98's Avatar
Just thought I would show how the gear app works. The first graph is my gear going up and down. Second graph is for the main doors, they open then close after the gear goes up. And when the gear goes down they close back up. The third graph is for the nose gear door, it simply closes and opens. The trick to getting it all to work is you first have to go into channel assign and assign ch 6 and 7 to s-gear ch1 and ch2. This adds the 2 extra graphs.
ID:	2084862   Click image for larger version
Old 03-29-2015, 12:58 AM
  #207
Dave Wilshere
Originally Posted by drac1
Hi Dave,
Scott
Scott
What he said. You don't need a remote to get telemetry with the 712, but can add either TL or Diversity remotes if you wish.
For Powerbox SRS units, the 712 is our first choice
Dave
Old 03-29-2015, 01:19 AM
  #208
Dave Wilshere
Hi Dave,
Scott
Scott
Dave
Old 03-29-2015, 01:20 AM
  #209
Dave Wilshere
double post!
Old 03-29-2015, 04:07 AM
  #210
drac1
drac1's Avatar
Originally Posted by Dave Wilshere
Scott
Dave
Thanks Dave and Airman.
Old 03-29-2015, 05:00 AM
  #211
ticketec
Hi Dave,
What is the advantage of the 712 over the RG031BX infinity receiver? I'm setting up an powerbox SRS in my Hawk and am just about to buy R/x's
dave
Old 03-29-2015, 05:21 AM
  #212
drac1
drac1's Avatar
I read on another thread that the 712 uses less power and doesn't get as hot as the 731.
Old 03-29-2015, 07:05 AM
  #213
Dave Wilshere
Originally Posted by ticketec
Hi Dave,
dave
Main one is pure cost. But installation neatness.
For me the 031BX is for installations where you will struggle to get the two close proximity aerials (to Rx';s) in clear space (away from carbon or metal) (on a 712)
Dave
Old 03-29-2015, 08:39 AM
  #214
Airman98
My Feedback: (9)
Airman98's Avatar
To me the advantage of the 712 would be that you have 7 pwm ports available possibly saving you 80 on harness. Then for 40 you can add the dual ant remote that you can place up to 36 in away from 712. Also the 712 has full 28 channel capability. As Dave said about the only thing the infinity has going for it is neatness, but you do have a telemetry ant to deal with.
Old 03-29-2015, 05:06 PM
  #215
drac1
drac1's Avatar
This may seem a bit dumb, but can anyone tell me this.
I have been building a new model for a while and it is set up with JR wide voltage servos. 4 X ail, 2 X elev, 1 X rudd, 1 X throttle and 1 X ignition = 9 channels required. As far as I know, these are not Xbus compatible and i don't want to have to buy more servos.
So is there a way I can use my 28X utilising PWM for the 9 channels?
Old 03-29-2015, 05:11 PM
  #216
spike5150
Sure- just use an 11ch DMSS RX. Or use xbus pwm converters
Old 03-29-2015, 05:23 PM
  #217
drac1
drac1's Avatar
Thanks spike.
i should have put a bit more thought into that. Lol. Of course I can use DMSS Rx's.
Having Xbus on my brain made me forget about DMSS.
Old 03-29-2015, 05:42 PM
  #218
spike5150
Thanks spike.
I hear ya. Learning a new tx plus xbus gets confusing. I think I am getting my head around it, though.
Old 03-29-2015, 08:08 PM
  #219
drac1
drac1's Avatar
More dumb questions could be coming your way then. Lol.
Old 03-29-2015, 11:19 PM
  #220
ticketec
My local didn't have them so when I went looking I realised just how much cheaper they are!
having PWM ports makes no difference in an SRS installation, and nothing States that the infinity is limited in channels either, but I wonder if it's worth getting the extra antenna. Nil stock in Oz of the extra antennas at the moment
A little info to add to the previous discussions, my XG14 weighs in at 812 grams. JR don't publish this info anywhere I've been able to find.
thanks
dave
Old 03-29-2015, 11:31 PM
  #221
Airman98
My Feedback: (9)
Airman98's Avatar
An XBus capable receiver (such as the JR RG712BX) must be used to realizeXBus functionality. Using more than 17 channels is not possible with olderXBus receivers (RG731BX and RG031BX). All other XBus receivers supportthe full 28 channels of this transmitter.
This is in the 28x manual. Page 5-22
Old 03-30-2015, 04:03 AM
  #222
ticketec
Ok thanks.
what do they mean "older"???? The 031BX has been out for less than 6 months!!
thanks
dave
Old 03-30-2015, 05:14 AM
  #223
Airman98
My Feedback: (9)
Airman98's Avatar
By older I can only assume they mean ones that don't have path diversity. The 712 was the first receiver to have it eliminating the need for the telemetry ant. The 612 has just came out as well. http://www.jramericas.com/234746/JRPR03599/?pcat=474
Old 03-30-2015, 11:12 AM
  #224
spike5150
Did you ever conduct your tests? I still don't think this is true. I got some more xbus harnesses last week, so I can do some testing.
Jeremy
Old 03-30-2015, 11:51 AM
  #225
Airman98
My Feedback: (9)
Airman98's Avatar
No have not had the time. But its pretty clear when you read the manual. Even the new receivers have to have the resolution reduced in order to get the 28 channels so my guess is the older one just dont have the bandwidth to support more than 17 channels. When those receivers came out there was only a 14 channel radio.
