Tm 1000 no data
Not much info to go on here, ... But,
After it binds, do the telemetry screens show upon the transmitter?
While binding, is the Telemetry message showing up under the frame rate?
What transmitter are you using, BTW?
I'd try binding again, when you are standing about 3-5' away with you between the Transmitter and the TM. I have had binds not recognize the TM when I bind too closely to the Rxer.
Have you tried it with a different transmitter? Or tried it with a different TM (e.g. jerk a different TM out of one of your other planes maybe, etc.)
If the above does not work, the TM may have stopped transmitting or the Transmitter may have stopped receiving the TM. I'd call HH and find out what they suggest.
Try rebinding using the menu selection to bind and stay several feet away. Then you need to go back in on the DX-18 in the telemetry menu and select the various inputs to be reported (e.g. Batt Volts, rpm, temp, etc.) if they do not show up as already being selected.
