Reload this Page >
DerJet F-35A
DerJet F-35A
Old 05-20-2015, 08:17 AM
  #51
Dave Wilshere
While since I posted, but I'm working on this and other models together. DJ sent me the last parts last week so I now have no excuses! A nice tailpipe former mount and some 90 degree retract nipples.
Rudders are now operational. A torque rod needed fitting, this is the process.
Rudder linkage and Ailerons completed. Radio tray epoxied and primed. The two cut-outs are for nose wheel and retract unit access.
ID:	2097323   Click image for larger version
ID:	2097324   Click image for larger version
ID:	2097325   Click image for larger version
ID:	2097326   Click image for larger version
ID:	2097327   Click image for larger version
ID:	2097328   Click image for larger version
Name:	DSC_0574 (Small).JPG
ID:	2097329   Click image for larger version
Name:	DSC_0575 (Small).JPG
Name:	DSC_0576 (Small).JPG
ID:	2097331   Click image for larger version
Name:	DSC_0577 (Small).JPG
ID:	2097332   Click image for larger version
Name:	DSC_0578 (Small).JPG
Old 05-20-2015, 09:48 AM
  #52
FalconWings
My Feedback: (57)
FalconWings's Avatar
Looks good Dave.
Old 05-20-2015, 11:07 AM
  #53
Dave Wilshere
Thanks, everyone who sees it likes it! Guys at DJ have done a great job. Just need more hours in the day! Juggling several projects but determined to get this going soon
Rear former support.
Old 05-20-2015, 11:15 AM
  #54
FalconWings
My Feedback: (57)
Send it to me, i'll get it in the air.
Old 05-20-2015, 02:27 PM
  #55
Dave Wilshere
Nooow all mine :-))
Old 05-20-2015, 04:53 PM
  #56
FlyEng
Now we're talking.....glad to see you're progressing. I look forward to seeing the remainder of the assembly and the methods you use.
Old 07-24-2015, 01:54 AM
  #57
patrnflyr
My Feedback: (7)
patrnflyr's Avatar
Any more news on this plane? It's been a couple of months and was curious about any progress
Old 07-24-2015, 07:58 AM
  #58
Dave Wilshere
Been massively underachieving with lots of weekend shows that run into 4 days. I actually started work on it again yesterday, it will be a straight run now as it needs to be done. Will report as I make progress. Sunday is scheduled as a building day as for once I only have a one day show to visit
Dave
Old 07-24-2015, 11:09 AM
  #59
iiievolution
iiievolution's Avatar
I will be in to inspect the progress next week.
Paul
Old 07-24-2015, 12:26 PM
  #60
Dave Wilshere
Great..pressure!
Some bits I had done.
ID:	2111012   Click image for larger version
ID:	2111013   Click image for larger version
Old 07-28-2015, 11:56 PM
  #61
Dave Wilshere
Finally making good progress.
Derjet say the P-100Rx is idea for the F-35 and from a low weight option, I'm sure its perfect, I can't help thinking a 120-140 would be better, so decided to use a spare P-90Rxi for the initial install as I can easily swap to a P-140Rxi and if needed still go to the lighter P-100Rx. This prototype kit will be a little heavier than production versions, so it will be a good test-it has a stack of area, so I'm not worried.
Glassed all the wood work and made up the fuel tanks. Shape is great, so Felt or weight clunks should work. Derjet supply a hopper tank that is best mounted vertically, this can be behind the radio tray as there is plenty of space. Alternatively a std MAP/BVM type hopper will fit neatly along side the radio tray.
Nose leg steering is done, there is little trail, so small movements are best.
Elevator linkage. Although the factory have done a great job getting everything 90 degrees the angular movement of the servo would mean the rod flexing as it swings. Actually servo movement is quite small requiring a short arm, so it would probably be OK, but I decided to widen the two control horns and put a swinging M3 ball link in place.
ID:	2111606   Click image for larger version
ID:	2111607   Click image for larger version
ID:	2111608   Click image for larger version
ID:	2111609   Click image for larger version
ID:	2111610   Click image for larger version
ID:	2111611   Click image for larger version
ID:	2111612   Click image for larger version
ID:	2111614   Click image for larger version
ID:	2111615   Click image for larger version
ID:	2111616   Click image for larger version
ID:	2111617   Click image for larger version
ID:	2111618   Click image for larger version
ID:	2111619   Click image for larger version
Old 09-08-2015, 02:15 PM
  #62
Len
Len's Avatar
Hi Dave,
Just curious if you'd had a chance to work any more on this plane? I have one hopefully arriving in Hawaii later this month!
Enjoy,
Len
Old 09-08-2015, 10:40 PM
  #63
Dave Wilshere
Len
Been painfully slow progress through no fault of the aeroplane, I had hoped to have it ready now, its really close but time is still restricted. I'll be able to help you with your build, a lot of the manual is written and I have photos. Will post more here soon. You can also email me at [email protected] and I'll directly answer any questions. Looks like test flying will have to wait until after JetPower, but if a chance occurs I'll let you know!
Everyone who comes into my shop loves the F-35, of the modern fighters it has character!
Dave
Old 10-22-2015, 10:13 PM
  #64
Len
Len's Avatar
Hi Dave, I just got settled after the Blue Angels show we did here last weekend and I unpacked the F-35A today... AWESOME!!! Double throw down gorgeous paint, well packed, in fact the only damage was the stick in the cockpit was broken off a the base. CA'd it on and the rest is beautiful. Anynews on the manual or at least a potential CG location? It won't be too hard to guesstimate it I'd imagine. Did you ever get yours out and airborne? DerJet did a magnificent job on this plane!!!
Len
Old 10-22-2015, 10:53 PM
  #65
Dave Wilshere
Len
Yes, I had my model at JetPower and it certainly got a lot of attention, people liked it a lot. I've still not found the time to finish the last details and fly it. I've had a few family distractions and the busy season stopping me finishing it. If you email me at [email protected] I'll email you the parts of the manual I have finished and we can then easily talk about any questions.
The initial balance point is approx 1 1/4" infront of the hatch lip
Best Regards
Dave
Old 10-28-2015, 05:05 PM
  #66
Len
Len's Avatar
Old 11-09-2015, 07:57 AM
  #67
sailing1
My Feedback: (134)
Has anyone actually completed and flown one of these models. Might be a good candidate for a winter project but would like a little more information/history before proceeding.
Old 11-09-2015, 08:49 AM
  #68
Dave Wilshere
Now the season is becoming quieter I'm hoping to get things finished soon. Len is also cracking on with his, so 2 flying soon
Dave
Old 11-09-2015, 09:19 AM
  #69
Len
Len's Avatar
Barring any unforseen issues, it should be ready to fly in a month or so, just about the time Obama's presence shut us down for Xmas...hoping to get the maiden flight in before he arrives Dec 18.
Old 11-09-2015, 10:38 AM
  #70
DrScoles
My Feedback: (18)
DrScoles's Avatar
He screws up your life too??? ;-)
Old 11-10-2015, 04:09 AM
  #71
FalconWings
My Feedback: (57)
that was low! LOL
Eagerly waiting on flight reports
Old 11-10-2015, 09:25 AM
  #72
Ron S
Ron S's Avatar
Len, we're glad to hear that Canada is getting atleast ONE F-35...
Old 11-10-2015, 05:29 PM
  #73
Len
Len's Avatar
Nope I am building it in Hawaii...Canada can't have it, and I am ready to ship my JL F-35A from Crapada back to the USA too just out of spite...
Old 01-11-2016, 08:53 PM
  #74
Len
Len's Avatar
Just in the midst of the Xicoy CG balancer and the F-35A...soon...stay tuned!
Len
Old 01-12-2016, 11:50 AM
  #75
spike5150
looking forward to pics a vids!
