Habu 32X Turbine
https://www.youtube.com/watch?v=eHaU74JE8T4#t=18
Big thanks to Dom at Essential RC for posting this video of some of my flights yesterday. Quite gusty and thermally yesterday, I made a few adjustments to the set up today (increased the elevator Expo on the down side by 8% more than the up.Set up still needs some minor work, I have JR elevator servos and Savox aileron, I think I'll change the aileron ones sometime as the ailerons are not consistent like the elevator is.
Another 8 flights this weekend, not really a Jet meet model as its small on a huge airfield!
Dw
Dw
Dw
Dw
It was quite windy at the weekend, so ground speed could be quite low. I'm amazed how well the wing is working, I tried flying right on the stall with most of the up in and it just mushes around. I had a few skippy landings over the weekend, the wire legs and softer, fatter tyres I'm using require a gentle touch down to stop it bouncing on a hard surface. Grass is more forgiving!
Dave
Dave
Dave
Dave
It was quite thermally on the day the video was filmed and I did some skippy landings too!
I played with the flap settings on the second day of this event, I reduced the flap by 3/16" and decreased the CROW a fraction to stop the "lift dump" I let Ali have a flight with it and he did a perfect main wheel touch roller landing.
On grass its easier to ace every landing.
#31
#32
I had an EDF Habu 32 and still used that much flap!
I messed around with the 32X wing clean and I can get to full up at low power and it does not snap!
All my grass landings were slow too and it was not as breezy.
Will do some more videos at the local site when we have a chance
Dave
Dave
#33
Dave
Dave
#34
Had a few more flights with the 32X yesterday from our grass site-employee Beardy came over to video it and agreed its not as straight forward as you might think because of the size! Will see what he got tomorrow in the office.
It was a breezy day with the wind coming over several landscaped mounds of earth, so the little bird gets kicked around, though it copes really well considering. Grass was long and damp from overnight rain, I'd hoped the guys would have cut the grass last week :-( Like this it struggles to accelerate during take off, but with TO flap it lifts off at really low speeds :-)
Great mini jet package
#35
https://www.youtube.com/watch?v=Albz...are_video_user
Video we did Saturday there are two flights, one normal length and one shorter. I really must free up the wheels more!
#36
Cool! Well that first takeoff was a little scary, reminded me of when I flew my Habu for the maiden and almost wing stalled it cause I didn't get it up in ideal airspeed. You mention lots of wind so the wind probably batted it a little on your takeoff. Those were some really good flights. I like the in-close maneuvers during the first flight. I got to keep mine that close because I have a tendency to let it get a little far. I've lost one due to letting it get too far and then loosing the plane's orientation at a somewhat low altitude. Not fun! So I need to keep it in tight like you did during your first flight on this video. BTW - what... is that a cow I hear starting at about 1:21 ?
The second flight is really cool. I love that big air. Landings in both vids were very nice. Those are some really tight maneuvers. What are your elevators set at? Thanks for posting.
#37
Up wind of the strip in that direction is a few thousand tons of earth dumped from a gravel extraction, it runs across the field in three humps, then the road in the distance is on a ridge...so it can be very bumpy, but the ground speed was very low and I hauled it off, so limited aileron power, lift and bumpy air makes for fun!
I still have the wheels set tight on the axles for tarmac flying and with the uncut grass its not getting up to speed.
It has a great speed range and in smooth air it grooves around, Beardy was not happy with the videos as the sky made the camera hunt for focus, we will do another when the grass is cut and skies are blue :-)
#38
#39
https://youtu.be/Albzfhoe8MM
nice
#40
Just put the new TJ Kevlar tank in, 32OZ!
Also added a 2 inch JP hobby front nose brake to be compliant at any Jet events in the USA, added 3 OZ to the nose which worked out great because I had 3 OZ of lead without it, its nice to be able to add weight in a functional form.
One thing I will say is that the CG from full tank to empty is quite noticeable on this little model, I find I'm trimming out the elevator from beginning of flight to end.
#41
Hi Dave, I converted a foamy Stinger 90 to turbine with a P20 sx. The nose has twin wheel with trailing link and although our grass field is much rougher than yours, the nose seem to skip over the grass (does not dig in) and let the plane take off. Maybe you should try that set-up. I can send you a picture if you want.
Behzad
Behzad
#42
Behzad
Thanks for the reply, as I said in the report its not so much the grass or surface (ours is soft and was damp from heavy overnight rain) its that I have the wheels set tight for tarmac operation. You can see in the first video Dom from Essential RC posted it slows really quickly on landing and taxiing. We don't have a brake requirement like the USA so this was my best solution. I'll free up the wheels after next weekends meeting as most flying after that will be from grass sites.
Just taxiing I need 3/4 power now :-)
Dave
Dave
