Reload this Page >
Sebart Mini Avanti w/ K45 build thread
Old 09-05-2017, 04:37 AM
  #501
Doug Cronkhite
My Feedback: (34)
Little shout out to Carlos at CMJets..
I received his tank when I was home on vacation, and it's absolutely gorgeous, and fits perfectly in the fuse. Can't wait to get home in December and actually complete the assembly of this little gem.
Old 09-05-2017, 05:00 AM
  #502
why_fly_high
My Feedback: (19)
Originally Posted by Doug Cronkhite
Does anyone in the US sell the Grumania pipe or do I have to buy it from overseas?
My friends and I have ordered a number of Grumania pipes. As far as I know they are only direct in the US. Yes, the shipping stinks.
Old 09-06-2017, 02:44 AM
  #503
extra 300
Is it imperative to use the wood conversion kit that Sebart sells to install the K 45? Initially when I bought the mini Avanti I also bought the EDF unit. Later I decided to go for the turbine install for many reasons, the least was the flight time which would be at least double compared to EDF, in addition to the additional power etc....
Thanks for your feedback
Regards,
Old 09-06-2017, 03:00 AM
  #504
jet-lover
Would you have a link to the timber conversion kit please.
Old 09-06-2017, 03:36 AM
  #505
siclick33
The Sebart conversion kit includes some wood parts to mount the turbine and pipe, the pipe itself and a fuel tank.
Even with a P-20 the Sebart tank is too small and I assume the pipe is too small for the K45. The wood parts won't fit the K45 or a different pipe.
It's quite good and cost effective for P-20 or Kolibri install but pretty much useless for the K45.
Old 09-06-2017, 04:05 AM
  #506
extra 300
siclick33
Thanks for your feedback. does this mean that no wooden parts are needed for the K45? Negatively thanks shedding some lights on the eventual pieces needed
Regards
Old 09-06-2017, 07:01 AM
  #507
a25afm
I'm interested. What are you asking for it?
Old 09-06-2017, 07:33 AM
  #508
siclick33
Here are a couple of pictures of the turbine conversion kit and the P20 installation. Unless you are talking about something that I am unaware of there is no 'wood' kit.
The only pieces of wood in the conversion kit are the 2 rings, that are part of the pipe installation, and 4 pieces that make a 'bridge' to fit the narrower P20 onto the airframe mounting rails.
ID:	2230855   Click image for larger version
Old 09-06-2017, 04:41 PM
  #509
roalddogge
if you install a K45 with a Grumania pipe, you will not need any wooden bits.
For fuel tank go with the CMJets tanks. I am using the earlier 1,7L which gives great flight time. Better option is maybe the 1,3L variant which does not require any cutting
Old 09-07-2017, 02:03 AM
  #510
extra 300
All is clear now thanks very much guys.
Old 09-12-2017, 08:16 AM
  #511
lorenb
Default k-45
Hi everyone, for those who are using k45 with diesel, what is your setup on start menu? im having flames at switchover phase.. using a 3s life
Old 09-12-2017, 08:52 AM
  #512
BarracudaHockey
BarracudaHockey's Avatar
Please talk to Barry before you go messing with those settings, I'm using the stock settings for diesel and KT oil
Old 09-12-2017, 09:12 AM
  #513
DepecheMode101
Stock when i had mine
Old 09-12-2017, 07:05 PM
  #514
roalddogge
Stock, as far as I can remember. Have little flames during switchover but nothing serious
Old 09-13-2017, 12:12 AM
  #515
Midas D.
Stock settings, having 2 no problem what so ever
Old 09-13-2017, 04:18 AM
  #516
BarracudaHockey
From the manual
Stage 2 • Switch Over – (up to 200 to 300 C) This is the stage that the main fuel also opens and a slight yellow to bluish flame is expected, while starter motor drives the rotor even faster in preparation for fuel ramp.
Old 09-16-2017, 12:46 PM
  #517
tuxian007
Hello,
does already anybody use the 1,3l cmjets tank?
Which hopper tank do you recommend?
Does anybody know which flight times are possible with the K45G?
Old 09-17-2017, 10:04 AM
  #518
Midas D.
Use the 1.7l Cm tank with the Cat80 super combo
Old 09-17-2017, 11:03 AM
  #519
tuxian007
Thank you for the info, where can I buy it?
Old 09-17-2017, 07:21 PM
  #520
cmjets
cmjets's Avatar
Hello, you can to buy CMJETS Tanks here:
www.cmjets.com
or write me direct to:
[email protected]
Regardd from Spain
Carlos Marquez
Old 09-17-2017, 11:09 PM
  #521
josex
I use the 1,3l cmjets tank and get 7min flight time. Don't see the need for a bigger tank. If you fly from grass I don't recommend the bigger tank.
Old 09-17-2017, 11:36 PM
  #522
Midas D.
Do Agree on this, i never fill mine up completely cause of the weight and flying from grass.
Got my timer at 5 min and alway's switch the engine off at about 7 min. still plenty off fuel left for at least 1 more go around.
Best choice ever for this bird, but go for the 1.3L
Old 09-18-2017, 11:17 AM
  #523
tuxian007
Thank you for the information, I have written an e-mail to carlos.
Where can I buy the Cat80?
Old 09-18-2017, 11:29 AM
  #524
RemoteJets
Were are you located? Have 2 on stock here ;-)
Instead of the CAT 80 you can also use the Intairco mini air trap.
Best regards,
Berto.
Old 09-19-2017, 05:17 PM
  #525
a25afm
I'm still waiting on my Tamjets pipe for my Mini Avanti. Not sure what to do. Should I keep waiting or contact paypal to see if I can get a refund? I know he's tied up but I just can't get an answer from Tamjets? Does anyone know how to get ahold of him? Is he still in business? Order placed on August 7th.
