Sebart Mini Avanti w/ K45 build thread
#581
Jet 1A strut installation
Received the 5.02mm reamer today from MSC Industrial. I chucked the reamer into a tap handle and very slowly rearmed the upper strut opening to a point just past the set screw hole. The upper strut section is about 10mm shorter than the Tam units, so I cut a spacer from styrene tubing. I stared at 10mm but made a second set of spacers 8mm long. I set the model on its gear t see how level the wing sat to the flat surface and decided the 8mm spacers put the model in the correct stance. The angle of the strut set moves the wheel about 2mm rearward, I found I needed to slightly enlarge the rear edge of the wheel well. I hope this helps. Jet 1a struts
#582
Hello,
how do I go exactly with the installation of the Grumania thrust tube before there was no guidance?
The funnel must I screw in the model but how is this attached then and what are the rivets?
How do I align vertically?
Markus
Markus
#589
Hello,
what do you think about this pump?
RCEXL-the-Smallest-Smoke-Pump-Gasoline-Pump-Smoking-Pump-with-Adjustable-Flow-for-RC-Airplane
I cannot post the link because of too few posts, please google for it.
The weight is more important than the price.
Markus
Markus
#592
My Feedback: (7)
So where can one get a mini Avanti in the US these days ? I've been checking the JR Americas website off and on for a long time and I've never seen it show the mini Avanti as anything but back ordered. I'd love to get one if I could figure out where to get it from without having to spend a fortune to have it shipped half way around the world.
#596
FWIW, I spoke to Chris at JRAmericas a while back about this plane (yellow/black scheme) and about the 2m Prometheus) pattern planes from Sebart)
He said the next container should arrive Jan/Feb. He said by placing a back order item in your cart, it should make it onto the next order; no need to pay in advance.
Unfortunately he said they are not importing Sebart 2m planes any longer due to size??
Take it for what it's worth, it JRAmericas after all ...
IMHO, overseas shipping isn't that bad. Lindinger has very reasonable shipping charges (Ive ordered from them in the past, no issues). You can also order directly from Sebart.it on his online shopping page.
#597
My Feedback: (7)
Actually I already ordered one from Lindinger and it turns out that even with shipping it's $25 less than what JR Americas has on it's website. I've been wanting one of these for a while now so I guess it's finally happening.
Had the Super Viper foamy jet out at SSRCC last weekend and it's flying really well. I'm finding I like the easy transport of these smaller jets. I still like the 140 sized stuff too but it's so much easier to just put something this size in the back of the car and still bring a 60cc aerobatics plane to the field as well.
If you decide to get one too maybe we can save some shipping by ordering a couple of tail pipes and fuel tanks at the same time :^)
#598
Timing is everything
I just ordered a PC-21 from JMB Jets in Luxembourg
Went with Electron retracts and brakes. About 13kg take off weight with K45TP
3m long (2 piece fuse) and based on YT videos it can land at a speed of my 2m planes; should be perfect fir SSRCC
I never ordered the Mini out of concerns over the stock struts/retracts on grass with a K45
I also wanted to avoid the drama surrounding Tamjets fir struts
I was waiting for the ER30 retracts and struts from Electron for the Mini; or maybe the Jet A1 struts with stock retracts
What color did you get?
Grumania pike and CMJets tank?
Aura 8 or Jeti Assist?
Im sure you'll have it built in no time
I tried moving my CARF Tutor around the shop ... and ripped a suture
So maybe I should think of smaller jets or just stick to 2m stuff
#599
#600
My Feedback: (7)
I look forward to seeing the PC21 when you get it as I really like turbo props. Hope you manage to get out flying a bit more often next year. Who knows, there still may be a nice day or 2 left this year if you feel up to it..
