Reload this Page >
Sebart Mini Avanti w/ K45 build thread
Reply
Old 10-20-2019, 07:31 AM
  #801
Rich Few
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have the jet 1A struts. My concern was if the JP sequence controller would be ok with a 2s life battery. I have been setting up and checking the nose gear and doors with a life battery and not seen any smoke yet ☺
Rich Few is online now
Old 11-06-2019, 06:50 PM
  #802
Razmo
Razmo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
[QUOTE=DrV;12194778]Here is mine. With k45, UAT full, and jp electric brakes its 9.6lb (4.35kg).
Hey DrV
Curious, is this a magnet on/off power switch?
Raz
Razmo is offline
Old 11-07-2019, 04:06 AM
  #803
BarracudaHockey
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Fuel over flow vent plug that you unscrew before you fill the tank.
Or you forget and break the tank by over pressurizing it lol
Turbine install obviously
BarracudaHockey is online now
Old 11-08-2019, 01:45 PM
  #804
smcharg
smcharg's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've built a red white and blue version with the 8S 90mm EDF and now starting the build on my yellow, red and black Mini Avanti that will be turbine. I was all set to pull the trigger on the KingTech K45G2 and noticed a new engine is now available. I talked to Dirk at Pacific RC Jets about it and the new K45G3M is out. The difference is that it is now, essentially, the same size as the K30. It weighs in at 450g compared to the G2 at 700g but produces the same amount of thrust. It's like $110 more but to save 250g....I've done pulled the trigger on the G3. Dirk and Kingtech also say it has the new ECU. I'm not sure what the difference is between the G2 and G3 concerning the ECU...yet.
CMJets is building my 1.3L tank and I'll have Peter from Baja do my pipe. Cannot wait.
smcharg is offline
Old 11-08-2019, 03:01 PM
  #805
Razmo
Razmo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Guys,
Recently pulled the trigger on Sebarts Mini Avanti which I'll be powering with the Xicoy X45 ... Some help with the following would be appreciated.
1) Those familiar with the X45, would you agree she burns roughly 100/ml per minute at 50% throttle? Thinking of going with a CM Jets Kero/Smoke combo.
2) Can anyone suggest an optimal smoke kit/system for such?
3) Any reason Mobil Jet Oil II is a problem?
3) Suggested UAT?
4) Suggested ball links, size and clevis? Simply prefer using such over the stock linkage.
5) Suggested voltage regulator combined power switch for HV? Thinking Emcotec may be the way to go?
6) Should I consider using epoxy on all hinges versus CA?
7) Are either 55 to 60mm JP mains too large for the cut outs?
8) Is the front wheel a 40 mm? Hoping I can go with 55 mains and matching front wheel that doesn't create a rake effect..
Raz
Razmo is offline
Old 11-08-2019, 07:54 PM
  #806
caliber90
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
1. I donít have any data to tell but I trust their engine spec, like the idle thrust is minimal, similar to what they say,
3. I am using Mobil jet oil, no abnormally found
3. My UAT is made by Spark, a one piece plastic small tank with metal filtering element hard mounted in the center of the tank. Pretty reliable but I want to get rid of it to save weight
4. I use ball links and balls from my helicopter spare, like JR or Hirobo make
5. I donít use any voltage regulator on board, just 2 1500 mAH LiPo.
6. I use CA on all hinges except epoxy in flap hinges
7. I use 45mm JP brake wheels, to make it lighter. The catch is to replace the bearings with quality ones. The point , I think is not the wheels, it is the strut spring rate. The later version of M Avanti comes standard with the new version strut which is softer, can absorb shock load during hard landing.
8. I use 40mm JP wheel at the front .
hope this help
caliber90 is offline
Old 11-08-2019, 10:46 PM
  #807
cmjets
cmjets's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi guys, the best choice for fuel system is this:
Regards from Spain
Carlos
CMJETS.com
cmjets is offline
Old 11-09-2019, 12:54 AM
  #808
Aussie1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by Razmo View Post
Hey Guys,
3) Suggested UAT?
Raz
I have posted this earlier, but one litre would be good for at least 10 minutes, due to the low weight/high thrust ratio with this combination. I don't use brakes, not needed or required over here, and use a felt clunk without header and no flame outs yet!
Aussie1 is offline
Old 11-12-2019, 08:11 PM
  #809
Razmo
Razmo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Regards from Spain
Carlos
CMJETS.com
Hi Carlos,
Appreciate it! Beautiful tanks. The 1.3 Liter tank is significantly more than the X45 needs, unless I was looking for 13 to 15 minute flights. Do you have an 800ml tank available?
Raz
Razmo is offline
Old 11-13-2019, 12:14 PM
  #810
Razmo
Razmo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Guys,
Can anyone suggest their preferred ball link size and clevis upgrades for the control linkage?
Any reason I shouldn't use epoxy on all hinges versus CA?
Does anyone know whether the 55 mm JP Hobby main wheels/brakes fit the existing cutouts without problem when retracted?
Has anyone tried either a 45 or 50 mm JP Hobby nose wheel? Curious if either fit without modifications..
Raz
Razmo is offline
Old 11-13-2019, 12:21 PM
  #811
Bob_B
Bob_B's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Guys,
Can anyone suggest their preferred ball link size and clevis upgrades for the control linkage? I use Dubro Clevis's on both ends and I also turn the Flap control horn around for better mechnical advantage!
Any reason I shouldn't use epoxy on all hinges versus CA? Because the hinges are designed to be glued with CA
Does anyone know whether the 55 mm JP Hobby main wheels/brakes fit the existing cutouts without problem when retracted? You should buy the better struts available from www.Effluxrc.com
Raz
See notes above.
Bob_B is online now
Old 11-13-2019, 12:30 PM
  #812
Razmo
Razmo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Bob,
What size ball links do you prefer? I'll consider reversing the flap horn, appreciate the tip. Still waiting on my Avanti to ship..
I thought the hinges may be, but have read others have had problems with CA holding up..
The latest Avanti version (v3) should have plenty strong enough struts from what I understand. Simply hoping I can run 55 mm wheels without cutout modification. Same for a larger nose wheel..
Raz
Razmo is offline
Old 11-13-2019, 01:56 PM
  #813
siclick33
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I might be wrong but I believe what is referred to as the V2 and V3 is actually the same version. If so, and the struts havenít changed, then they are perfect for hard surfaces and workable for very short grass, but for my next Sebart mini size model I will be fitting upgraded struts for long term grass use.
siclick33 is offline
Old 11-13-2019, 02:08 PM
  #814
Razmo
Razmo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hmmm, possibly? This is from Sebart a couple weeks ago... "The latest is V3. The the bulk of the changes between V1 and V3 were in the retracts"..
Raz
Razmo is offline
Old 11-13-2019, 02:14 PM
  #815
Jack heverson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi everyone, I'm going to make his first flight this weekend
Jack heverson is offline
Old 11-13-2019, 02:20 PM
  #816
Jack heverson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
  #817
Jack heverson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Old 11-13-2019, 02:22 PM
  #818
Jack heverson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Old 11-13-2019, 02:23 PM
  #819
Jack heverson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Old 11-13-2019, 02:26 PM
  #820
Jack heverson
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Old 11-13-2019, 03:55 PM
  #821
Bob_B
Bob_B's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bob_B is online now
Old 11-14-2019, 05:35 AM
  #822
cmjets
cmjets's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Carlos,
Raz
hello. Yes, is possible install the tank that you want, with the exactly capacity.
Contact me here:
cmjets2004@yahoo.es
thanks
Carlos
cmjets is offline
Old 11-14-2019, 06:39 AM
  #823
Bob_B
Bob_B's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Bob,
Raz
Raz,
I use clevis's not ball links.
DON'T use accelerator when you glue the CA Hinges in place.
The struts are Okay, just offering a superior solution.
Bob_B is online now
Old 11-14-2019, 07:11 AM
  #824
Razmo
Razmo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Contact me here:
cmjets2004@yahoo.es
thanks
Carlos
Thanks Carlos, will do..
Razmo is offline
Old 11-14-2019, 07:13 AM
  #825
Razmo
Razmo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by Bob_B View Post
Raz,
Thanks Bob!
Razmo is offline
