Reload this Page >
JHH-A7 with the new Kingtech K45
Old 07-15-2015, 09:12 AM
  #76
P. Richards
P. Richards's Avatar
I have some good video of the A-7, and it has been added to the official Jets Over Kentucky DVD last night.
P. Richards aka SwatTeam
Old 07-16-2015, 09:40 AM
  #77
luge_racer
This thread is perfectly timed as I just got my hands on a JHI A-7 that was previously flown on EDF power and was planning on converting it to a King tech k-45. Thank you for paving the way.
Old 07-16-2015, 10:17 AM
  #78
gunradd
My Feedback: (9)
gunradd's Avatar
I already got everything fixed and ready to go again. Just need to find time to get to the field. I ended up attaching the stretch cord from the top main doors to the bottom main doors and they all close perfect now with allot of holding force. I think the stretchy cord is worn out and that's why the stock set up didn't work at all. Probably best to store this plane with the gear up so it does not stretch out the cords over time.
Luge good luck on the build. Let me know if you have any questions. It really does fly great with the K45. Cant wait to get back out and get this bird dialed in.
Old 07-16-2015, 02:32 PM
  #79
EDFCrazy
I've bought what seems to be a good candidate for the K45. length is 53" and wing span is 55".
Old 07-17-2015, 01:02 AM
  #80
Rider-60
My Feedback: (17)
I have a set of new rc crafter gear if anyone needs .
I also have a robart nose retract ,but the nose oleo needs to be redrilled to fit it.
last item I have is a set of air force Sea scheme decals .
Make offer as I can't recall the original price.
Old 07-17-2015, 08:16 AM
  #81
luge_racer
That's some very pretty landing gear. I have no idea as to its value; but probably more than I can spend at the moment.
Old 07-27-2015, 04:11 AM
  #82
gunradd
My Feedback: (9)
gunradd's Avatar
Got the gear working good now along with the doors. Nose steering is not working well and I will need to move the servo to a different spot and redo the cables. Got 4 flights in yesterday and it flies well when moving fast and going in a straight line. Flies like its nose heavy witch it is when the fuel is ahead of the CG. Does not like rudder input and flies like crap inverted. So if you going to fly one limit it to an occasional roll and verticals with level flying. This aircraft is very challenging to fly and not for someone new to turbines. But if you love the A7 like many do its a great aircraft that needs to be respected for what it is and it will do fine.
I have some video my son took on his cell phone.I forgot my airpump at home so had no brakes. I tried to land a little early because I stepped in an ant pile near the pilot station. Towards the end of the flight they made it over to my leg and started biting the crap out of me. So messed up and did a go around then dorked up the landing lol. You can fly for about 5 mins with the 40 oz tank and have enough left for a go around. Each time I landed I had about 15% left in the tank. Also lost the top hatch on the last flight. Didn't realize it until I taxied back. So if anyone has one laying around let me know please. Does not look like fun to scratch build.
https://www.youtube.com/watch?v=fmGD...ature=youtu.be
Old 07-27-2015, 06:54 AM
  #83
Eddie P
Eddie P's Avatar
I know this jet is early in her lifespan as you are still getting her trimmed up and operating 100 percent (in between ant hill attacks) - but have you had an opportunity to dial in your good gyro yet? (Cortex or iGyro, NOT the Eagletree) Just wondering if that would tame some of the inverted handling issues as well as rudder coupling issues the jet may display in certain parts of the envelope and CG ranges. Since you are burning fuel in tanks not directly over the CG that might be part of the stability and control puzzle going on. IOW, what works for the first part of the flight may require some technique differences for control inputs as the CG shifts. The gyro would at least help mask that for a more consistent stability and control profile from an operating perspective. Even if it's not a purely optimum solution aerodynamically, it's dynamic and hopefully an easily usable one.
Old 07-27-2015, 06:58 AM
  #84
gunradd
My Feedback: (9)
gunradd's Avatar
Eddie I tried a gyro in it at first but it was a bad unit so pulled it out and ran it with out a gyro for now just to get it out and dial it in. No doubt a gyro will make it fly a ton better. But as for inverted and other problems I am pretty sure its just the design of the wing and more of an A7 thing. She will fly around just find for normal pattern stuff and I am ok with that.
Old 07-27-2015, 07:19 AM
  #85
Jet20
Kris,
Looks like you're getting it dialed in. It is QUICK! At the end of the day, the A-7 configuration just has some quarks about it, I'm sure the inverted flight difficulty is a by product of that. It's an airplane best flown as though you're sitting in it. It's not a yank and bank type of airframe. I'll see what I can do about finding a replacement hatch.
Old 07-27-2015, 10:00 AM
  #86
gunradd
My Feedback: (9)
gunradd's Avatar
Chris thanks for helping
Also thanks for all the advice you gave me on this plane.
Old 07-27-2015, 12:23 PM
  #87
Jet20
Hey, no problem! I'm here to help!
Old 07-27-2015, 03:00 PM
  #88
luge_racer
I figured this would be a plane that would mostly be for cruising around in circuits.
I'm curious, along with a second hand ARF, I also have a kit fuselage and I was wondering if anyone has the plans for the wings and tail feathers?
Old 07-27-2015, 03:23 PM
  #89
Jet20
luge_racer,
My folks have plans available still should you want to order a set.
Old 10-12-2015, 04:38 PM
  #90
DrScoles
My Feedback: (18)
DrScoles's Avatar
I have one on the way! Always loved this plane, one of my favorite plastic models as a kid.
Old 10-20-2015, 08:59 AM
  #91
Jet20
Nice! Let me know if I can be of assistance in getting the airplane flying.
Old 10-20-2015, 09:07 AM
  #92
DrScoles
My Feedback: (18)
DrScoles's Avatar
Thanks Chris! Jon has already been a big help. I think using a 3-axis gyro will tame a lot of the less than desirable flying characteristics. I have so many projects going right now, but I think this one will get pushed to the front of the line. I love my mini Avanti with the K45, looking forward to another small jet. Do you guys sell the retract package? I know I'm getting the struts from Jon, I need the actual retracts and (I think) wheels??? I have everything else I need.
Old 10-20-2015, 12:03 PM
  #93
Jet20
If you have the struts (which is the part we definitely don't have) then my folks should be able to supply you with the remaining components that you'll need (air cylinders for mains, nose retract, and air control kit) to get them operational. Just give them a call or email.
Old 10-25-2015, 06:07 PM
  #94
DrScoles
My Feedback: (18)
DrScoles's Avatar
I got the kit tonight. Thanks Jon! It is gorgeous. All the gear doors fit perfectly, it's just a very nice plane. Refreshing to see this kind of quality. Chris, how much of the duct can I remove? In the manual, it shows that it's cut up to the leading edge wing mount area, can I go farther forward?
Calling in the morning to order the rest of the stuff I need. How did you guys do brakes?
Old 10-26-2015, 02:41 PM
  #95
Jet20
I'm not sure I understand needing to cut the inlet? I don't think that'll be necessary. If I remember right, Jon actually had a turbine version which has the smaller inlet? The DF version had a much larger inlet to mate to a 120mm fan.
Old 10-26-2015, 02:53 PM
  #96
DrScoles
My Feedback: (18)
DrScoles's Avatar
I meant where it goes into the area under the wing. I cut it even with the mounting bolts. Might go a bit further forward on the bottom so I can put a component tray on the floor of the fuse right behind the nose gear.
Left a message with Jet Hangar… I've heard you have some pull there, hoping to get a return phone call soon ;-) ;-)
Old 10-26-2015, 04:04 PM
  #97
gunradd
My Feedback: (9)
gunradd's Avatar
Dr
Installed on barrys A7 wheels and brakes from DreamWorks. They are working great. I think I cut the inlet also for some reason. I'll check it tomorrow.
Old 10-26-2015, 09:08 PM
  #98
DrScoles
My Feedback: (18)
DrScoles's Avatar
Kris, mind telling me which wheels and brakes you ordered from dreamworks?
Old 10-27-2015, 06:00 AM
  #99
Jet20
When I was flying my A-7 with the wren, I used Intairco wheels/brakes. They're a bit heavy, but worked well. Since converting it to electric, I've been using AirPower wheels and brakes from dreamworks. I'm not sure if they're still available, but they're lightweight and work well. I was able to fit them to Robart tires easily enough also.
Old 10-27-2015, 01:32 PM
  #100
DrScoles
My Feedback: (18)
DrScoles's Avatar
Chris, talked to your dad, he should be invoicing me soon for the pipe and gear. What servos do you use? Is the weight savings with mini servos worth it? The manual says 70oz, a bunch of the smaller servos fall right around that.
I ordered the Intairco wheel and brake set from Dreamworks. They're an 1/8" smaller than the ones recommended, but the right axle size. Gotta have brakes where I fly.
