Xicoy dual action air valves again!!!!!
Anybody know why I've got one that will not work plugged in to a 18" ext out of a Powerbox Royal. It works fine with a 6" ext but not 18". I don't have a12" to try but I must use an 18". I've tried another PB rec with the same results. ?????????????? Thanks Scott
I just tried it again with two 6" exts and no go. Now the valve sometimes works with the 3" ext and sometimes doesn't. I noticed that the green LED light on the valve is dimmer than another valve plugged in right beside it with no ext. seems to be a voltage problem. I've got the Powerbox set to 5.9 volts. I've tried multiple valves and they all do the same thing. The Powerbox screen says 8.0 volts on batt1 and 2 regulated down to 6.3 volts.
What is the voltage reading at the device? It does seem odd that the voltage would drop that significantly across a 12 -18" harness, unless the system was already loaded to the hilt or the source power supply is just not delivering the current. Maybe the initial connection is not good?
As invermast suggested earlier, try a signal voltage booster like Skektrum part # SPMCP
I've had to use them on older Jet-tronics valves so maybe it will work with your Xicoy units?
http://www.horizonhobby.com/spektrum...-booster-spmcp
Ok. Just an update on these valves. Talked to Gaspar this morn. Come to find out that a bunch of these valves were fitted with the wrong capacitor causing this problem when used with an extension. Gaspar took 40 off the shelf and put an ext on each one, plugged it in and 6 out of the 40 were bad. Glad to get this solved. Now time to tear into for the second time.
