Question for Jet Central kerostart engine owners
My Feedback: (55)
Do any of you filter the fuel to the kerostart feed, ie the 'K' solenoid feed? In other words, is the fuel filter in your plumbing only in the engine fuel supply line (downstream of the 'F' solenoid, per the Jet Central diagram), or is your filter plumbed in the system after the fuel pump, but prior to the split for the 'K' solenoid/starting fuel?
My Feedback: (55)
That's what makes sense to me, Rich...and is how I've done it with other manufacturer's turbines. Why Jet Central (unlike JetCat) shows the filter after the engine fuel feed solenoid and not right after the pump escapes me. The kerostart fuel feed line is unfiltered in the Rabbit plumbing diagram.
The whole point, as I understand it, is to protect the engine not only from any fuel contamination, but from debris if the fuel pump decides to come from together to apart. (As an aside, one can filter their fuel until the cows come home, but that won't do you any good if your system is filterless and the pump starts shredding itself.) Juan responded in another post that the burner isn't harmed by "small to medium debris", but even so, why risk any crud getting in there in the first place?
Thanks for the input. I'm putting the filter after the pump (like I always have with other turbines)...and before the line branches off to the kerostart solenoid.
My Feedback: (55)
Here is what Juan posted, in reply to my concern over the plumbing arrangement:
There are several reasons we prefer the filter after the pump, and only at the primary fuel line, the most important one is that there is a small restrictor for lubrication that can get clogged easily, we also prefer the filter to be at the pressure side and not at suction side, filters tend to catch air bubbles and let them go suddenly, turbines can take bubbles but not the fuel pump, the fuel pump normally is protected by the UAT, but the pump can produce small debris over time and thats what we intend to catch, the burner is not be affected by small/medium debris
I think he got confused, thinking I was suggesting that the fuel filter should be upstream of the pump. That's not it at all. My point was, and is, why leave the kerostart fuel feed line unprotected by placing the filter after the engine fuel feed solenoid ('F' solenoid)? Why not place it right after (downstream of) the pump, but before you 'T' off a line for the kerostart fuel feed?
Juan confused me with the statement about placing the filter"...only at the primary fuel line, the most important one is that there is a small restrictor for lubrication that can get clogged easily." OK, I get that, but why should the filter ONLY go on the "primary fuel line" (which I assume he means the engine fuel feed line)? How does placing the filter just after the pump so that it can filter BOTH the engine fuel and kerostart fuel have any adverse effect on this "small restrictor for lubrication"?
Oh well, seems crazy to me that Jet Central would plumb a filter in only the engine fuel feed line, and leave the kerostart feed line unfiltered...even if the burner can chew rocks.
Last part in the chain need to be the filter, you can have debris released from a valve seat.
If you want to protect the burner, add another filter on it's line
