Changing fuel between Jet A and 1-K Kerosene
I am settling into my routine with my JetCat turbine and I had an interesting question come up. I originally started running the engine on 1-K that I got at Lowes. Ran great. After several 5 gallon cans of that and the cost that goes with it, a few of us at our club were able to get a deal on Jet A from a local airport. So we all switched and I have been running Jet A all summer long. When I switched fuels, I flew out as much of the 1-K as I was willing to and then drained and set aside the remainder after I drained the UAT as well. I then refilled everything immediately with Jet A so the two never mixed.
The question I have is that I still have one can of 1-K left over that I haven't used yet and I was curious if it was safe to mix the 1-K and Jet A together or should I repeat the complete drain process I did last time? Thanks for the advice.
Josh
Josh
My Feedback: (7)
ON, CANADA
I have used all 3 with no difference at all on all my engines
Running Diesel at the moment because I can get it from the local gas station
Only thing I notice is a little smoking after shut down with the diesel thats it
Good luck
Ted
Good luck
Ted
