Reload this Page >
New Mini Xcalibur
New Mini Xcalibur
Old 01-25-2016, 12:14 PM
  #76
Bob_B
Bob_B's Avatar
Dave would this model take a 90mm edf unit and 8S?
Old 01-25-2016, 12:43 PM
  #77
DenisFerrari
Thanks for good news Dave! I'm sure Mini Xcalibur will be another X-series winner.
Old 01-25-2016, 01:16 PM
  #78
Dave Wilshere
Unfortunately not. Ripmax's original plan was for both, but the inlets are too small, the static current on a 90mm fan was massive with a stalled fan. Opening the inlets and re-profiling them over the main gear pockets would completely change the appearance.
Denis-for sure!
Dave
Old 01-26-2016, 12:55 AM
  #79
Birdman6310
If the RRP is £449.99 lets hope a few stores will bring it down to £399.99 for the actual sale price. We will see
Old 01-26-2016, 12:59 AM
  #80
Dave Wilshere
Lets hope not...
Not everyone is Denis!
Old 01-30-2016, 12:42 PM
  #81
Dave Wilshere
So,just back from the Nuremberg Toy fair where the mini Xcalibur was released officially. The new Sports scheme was shown along with the already seen Red Arrows scheme. Looks like the boat won't arrived in Europe until 2nd week in March with timings. Just in time for the start of our season!
Pictures are not great as didn't have a camera and lighting is not great. But it gives you an idea!
ID:	2144302   Click image for larger version
Old 01-30-2016, 01:02 PM
  #82
DenisFerrari
Very nice incoming winner!
Old 01-30-2016, 08:50 PM
  #83
r 3
r 3's Avatar
Better start cleaning the rust off the P20
Old 02-14-2016, 11:34 AM
  #84
Newton5019
Swore i'd never buy a p-20 , but.......getting older does strange things to you. Really looking forward to getting my hands on one of these
Old 03-15-2016, 04:51 AM
  #85
Newton5019
Picked up my xcalibur from Paul today , who collected it from Motor's & Rotor's yesterday .
Quickly unpacked and slotted together, colour scheme looks awsome!!
Will commence assembly in the next week or so once ive cleared the bench of the last couple of jobs, Jet Cat P-20 , JR servos and DMSS headed for this one
Toby
ID:	2152672   Click image for larger version
Old 03-15-2016, 05:08 AM
  #86
Paul0088
Looks good Toby nice scheme
Old 03-17-2016, 12:04 AM
  #87
DenisFerrari
Very nice! ...will surely be a winner
Old 04-23-2016, 10:50 PM
  #88
chunk111
Yesterday I had the maiden flight with my Mini Xcalibur and all was going well until a medium speed turn back into wind caused what seemed to be a tip stall, managed to power up and just missed impact with the ground.
Had a few more circuits keeping the speed higher with wider and flatter turns with no signs of tip stalling, selected full flap and completed one full circuit and had a reasonable slowish landing.
Just wondered if anyone else has flown there's yet and has any comments on flight characteristics, cg position, control throws etc, my cg is 5mm behind the recommended position even with two 1450mah receiver batteries and the fuel pump in the nose, ailerons quite sluggish at the recommended 7mm each way with elevator quite responsive at 20mm each way.
Maybe just too slow with too much elevator on my part but it didn't seem that way at the time.
Old 04-23-2016, 11:08 PM
  #89
Jannica
Hello.
Stall is induced by a too high angle of attack, alfa angle. Stall can occur at any speed if you pull hard enough on the stick. High wing loading and slow speed forces you to fly with a higher alfa from the outset and so lessens your margins. I guess that you flow just a bit on the slow side with a slightly high wing loading and then pulled just a little too hard in the last turn. A classic recipe for disaster.
Happy landings.
Jannica
Old 04-24-2016, 09:35 AM
  #90
Dave Wilshere
I've now had 14 flights on my own model, 8 this weekend at the Nye Jets weekend. I saw a comment on another forum about something similar, at first I was a little surprised as all the flights were faultless and I experienced no issues with the prototype in lot of flying in mixed conditions.
I decided to 'yank' on the elevator and even going quite fast I could get it to bite, but snaps on the top of a loop stop nicely just like the other Xcaliburs.
Thinking about it maybe some thought is needed with these small jets, the Mini Xcalibur was purposely designed with a 1 ltr fuel tank, to give long flights, I have a 2oz hopper in addition and was regularly flying between 8 and 9 minutes all weekend. I guess 1ltr of kero weights over 1 1/2 lbs, so 20% of the models dry weight! I do lots of mixed flying, but restrict slow flying until half way through the tank (4 mins plus on my throttle use) The Mini Xcalibur as the people saw all weekend lands nice and slowly, but we joked about running out of fuel and it not gliding well...this would be fact, the wing loading will be higher than the normal Xcalibur, so this needs thinking about. I do have 3mm of CROW for landing and as these slow fly-bys show it cruises around.
Also these baby turbines take a while to accelerate any model, maybe the throttle use needs to be understood, I don't below mid stick at any time during a normal flight.
I would not go behind the manual balance point either, mine has a 2200 and 1600 2s li-po in the nose and is a fraction nose heavy over the manual figure I set at 115mm.
Aileron movement of 7mm is at the tip, but the manual missed this!
I fitted an iGyro 3e to mine as my first experiment with a 3 axis gyro and I flew it with and without it activated, the main thing I noticed with it stops any fidgeting, smoothing things out in choppy conditions. I only have it set at 20 something percent so far, but it worked fine even at a low figure that only moves the ailerons a few mm at fairly big rock angles.
I love mine and it was very well received this weekend.
ID:	2158828   Click image for larger version
ID:	2158829   Click image for larger version
ID:	2158830   Click image for larger version
ID:	2158831   Click image for larger version
ID:	2158832   Click image for larger version
ID:	2158833   Click image for larger version
ID:	2158834   Click image for larger version
ID:	2158836   Click image for larger version
ID:	2158837   Click image for larger version
ID:	2158838   Click image for larger version
ID:	2158839   Click image for larger version
ID:	2158840   Click image for larger version
ID:	2158841   Click image for larger version
ID:	2158842   Click image for larger version
Old 04-24-2016, 10:03 AM
  #91
Newton5019
looked good , even in the crosswind, must crack on with mine this week !
got any pics of my 45 degree landing with the cougar
Toby
Old 04-25-2016, 12:30 PM
  #92
DenisFerrari
Dave, mini X looks very good indeed! A little...big winner.
Old 05-01-2016, 03:05 PM
  #93
FlyingMT
Test flew myMini last Sunday, dead cross wing 15-20mph and it handled it without any realissue, and today flew some excellent routines the Mini really is an all-rounderand my P20 is more than enough. Great little model.
Old 05-02-2016, 02:40 AM
  #94
Dave Wilshere
Mark
Excellent news, was flying mine again Saturday at our grass site, long grass and rough ridges with our cross wind runway, no problem. Beardy even did a short video will try and get posted tomorrow.
How long you flying for? I get a consistent 8 mins+
Dave
Old 05-03-2016, 04:40 AM
  #95
Dave Wilshere
Video time!
This was on Saturday, cross wind at our strip, so a bit rough with uncut grass and various patch extensions making ripples. Copes well with little wheels!
This was not a full tank, it started 1/2" from the top.
https://youtu.be/t_MMa5gueRM
Old 05-03-2016, 01:26 PM
  #96
FlyingMT
I have flown my Mini last couple of Sundays, first was cross wind and again last Sunday and the only time I noticed a flip I hadn't initiated was when using too much elevator and she performed a high speed snap role. I will adjust the elevator but I have found my mini to be very docile and providing you maintain flying speed very forgiving. I have a 1600 and 2200 Lipos in the nose for receiver and turbine (P20). Check your balance point and consider using exponential on elevator, aileron and rudder, if you haven't already that is.
Old 05-03-2016, 01:36 PM
  #97
FlyingMT
Hi Dave,
I'm averaging 6min and there's plenty of fuel left, not using a UAT so just the main tank. As a second throw it in the car/van with minimal assembly, just add outer panels its a great little model. She also performs nice combination snaps on the vertical with easy recovery. I always throttle back allowing the model to descend before throttling up. Most of my flight is at half throttle. Glad I got it Dave.
Anyone who hasn't got one and wants a small go anywhere model it seems ideal and the obvious choice.....If I keep on praising it you're have to put me on your payroll Dave!!
We also have two 100 size Xcaliburs on the way (North Weald MFC) that I'll get to test fly when there ready and if they perform as well as the mini the guys will be very impressed, as will I.
Old 05-10-2016, 05:11 AM
  #98
Paul0088
Started a build for a friend
ID:	2161898   Click image for larger version
ID:	2161899   Click image for larger version
ID:	2161900   Click image for larger version
ID:	2161901   Click image for larger version
ID:	2161902   Click image for larger version
Old 05-10-2016, 12:47 PM
  #99
markbrown65
markbrown65's Avatar
Default Mini Racing Xcalibur
Had a bit of a sticker evening....
ID:	2161924   Click image for larger version
Old 05-10-2016, 01:38 PM
  #100
r 3
r 3's Avatar
Hi markbrown65
Can you tell me how you get the motors & rotors transfers from DW
