What do you guys think about this new jet built?
My Feedback: (176)
Hi to all I have this jet from friend and yes this is flying wing blown to about 110" wings gremlin combat wing which normally have engine in front propeller power. And this one is built into turbine power .let me know what you think
It seems based in Bill Evanīs scimitar designs...
it will fly well as long it has the right setup. (cg, throws,reflex, etc.)
The rear section could be improved for better cooling..
I would also like to see a former ahead the turbine to improve the rigidity of the rudders.
My Feedback: (35)
Sebastian I cannot image except, as you will recall, Paul Appelbaum scratch built a small & medium size with very similar outlines that he flew numerous times at R-66.
Anyway hope you will maiden it, along with your beautiful T-33, at Route 66 Jets.....
MA
I found in my development of the GremTwin that rudders weren't very effective causing more of a yaw than a turn so it just sort of cause it to crab. Differential thrust was far more effective (which isn't an option for you)
I definitely want to see video!
My Feedback: (7)
The Gremlin and flying wings in general like a CG about 15% MAC so you will be a bit nose heavy but that should be ok. The biggest we've seen so far is the BFG that Wayne Field built that was 96" wingspan and about 17 pounds
It is actually an outgrowth of the Duraplane that Eric Henderson, the designer, kept breaking the tail off of (his son's) and based on flying wing slope soarers. Hence the downspout fuselage and EPS wing. It was used for single design combat and publicly introduced at the 1992 NATS and published in the December 1992 RC Modeler
Hey Jim,
i figured you would get a kick out of a BFTPG
Very cool project and I'd love to see video of the maiden too.
MA
