Jet Tronics Dual-Valve plumbing setup?
I'm new to electric values and just received a new Jet-Tronics Dual-valve for gear on my jet. I'm not sure how to plumb these as I would with my UP valves and the instructions only described electronic setup not schematic of tubing setup. Below is the photo of the valve, it was 4 ports. one for "compressed air in"... I get that!!! Then it has two nipples that say "output to Cylinders", and then one nipple that says "Air outlet". Can someone tell me how this is laid out for the three cylinders on gear? I'm sure I'm missing something simple here, but it's not like setting up UP valves I'm used to?
The output to cylinders will give you up from one and down from the other, you need to connect the cylinders together so all three move the same way, then the other side of cylinder to the other nipple for down,
Air outlet is not connect to anything, it lets the air out of cylinders as the other side pushes ram to other side, air in is from your air tank. This valve is for air up air down retracts.
Excellent!!! Exactly what I needed. I knew it had to be simple. It just threw me off that the "air out" had a connector but was just a relief valve. Much appreciated.
My Feedback: (7)
