Running Diesel on Kero Start...Cooking up igniters?
My Feedback: (76)
I have turbines from 2 manufacturers and after running diesel for sometime both of them have recommended I go back to JETA or KERO; These are both German Made turbines. They said the issue they found was igniters getting cooked up and needing cleaning. This was about after 7 hours or run time and I am wondering if this is because during startup Diesel doesn't burn as fast as kero or jeta. I also notice more "flames" with diesel and a bit rougher start, however, once it gets going it runs the same for the most part (albeit acceleration is a bit choppier).
Other than the issues with igniter for the most part both mfgs said internals look normal and they found no difference between this and kero.
I wanted to get some more opinions on people that have been running diesel for a while, how have things been treating you guys.
I don't know but diesel fuel is very good now ..because it's serve sofisticated engine car injection system and must to be
good for reduce bad emission in the atmosphere
we have lot of turbine that run on diesel without any problem...
OIL 3,5% NOT 5% as usual
no problem on bearings with diesel... 30hrs on jetcat , no problem on other engines also
we have a good oil..no toxic and no dte similar... it' s new product ...like aeroshell but without toxic components
Well, my experience on diesel :
i have 12 jetcat, i allways runs on jeta1, since last january i'm using diesel S10, mixed 4 to 4,5% turbine oil, after around 100 hs run time on ours jetcats ( gas and kerostarts ), they running absolutely ok, verya reliiable, fast response and smooth, but, after many ratio mix ( diesel x jeta1 ), to me the best ratio is 70% diesel to 30% jeta1.
Doesnt have smoke on startup and shutdow.
in my last inspection on jetcat, the engine was in perfect conditions.
I will change the oilt to Dte32 light.
jose
jose
My Feedback: (41)
The stuff we get here can really cause problems with the Bosch high pressure common rail fuel injection systems used on most trucks. Those systems originally came out working at 22,000 psi. and I think they run higher than that now. The American diesel does not lubricated those parts very well and if you get any water in it, it'll cut the fuel injectors just like a water jet cutter in a machine shop.
On the Jet A; it's gotten quite difficult to get that stuff anymore as the EPA told all the FBO's (Fixed Base Operators) that they could not sell aviation fuel over the counter. It's thought that they wanted to stop people from buying AvGas for snow machines, jet skis' and such. There was no mention of still selling Jet A so most FBO's will not sell it to you.
Kero is a bit expensive if you buy it in the prepackaged 5 gal. containers at Home Depot or such, but if you look around, unless you're in California, you can usually find distributors who will sell it to you in your own containers for about $5.00 a gallon and it doesn't stink as bad as the Jet A.
