Reload this Page >
Skymaster F-18C Purchase from Chief....
Old 01-27-2016, 10:14 PM
  #101
mackeyjones
Originally Posted by dbsonic
Looks great!
I swear I will never sand and strip another scale plane again for a repaint..
Old 02-06-2016, 11:47 PM
  #102
mackeyjones
Time to put it all back together now.
ID:	2145750   Click image for larger version
Old 02-07-2016, 08:03 AM
  #103
Dblex
My Feedback: (81)
Dblex's Avatar
Great Job!
My build update is as follows:
Elevator servos/linkages and control surfaces installed and working.
Steering servo installed, no pull pull yet.
UP3/UP6/Xicoy valves/UAT/Fuel pump, Filter plumbing installed
Landing gear checkouts finally complete. This was a good 2 weeks of work. Oh my, if I can suggest anything...READ these threads and learn from your peers!!!! For a week they held solid air and I was about to check them off GOOD. I would cycle them in the morning the pressurize the system in the down position and check pressure when I got home. I would cycle the air that was in during the day until they couldn't cycle anymore. Pressure up for the evening in the "up" position and check again in the AM. I have cycled these gear over 100 times to check for leaks and failures. On sign off the neighbor comes by to check the progress and I show off the gear...Left main is getting sticky and wont come down. I hear hissing now and wow...leaks all over the place. Air cylinders are leaking at the O-ring connections. Had to remove a few and tighten them up. Sealed them all now with Hysol!! LMAO
They are working great now!
I am signing off on the LG and Doors and moving on. As I mentioned. My advice was to not move forward on anything until I knew the LG/Doors were working properly. Greatest advice ever.
Updates to follow
Old 02-07-2016, 10:42 PM
  #104
mackeyjones
Originally Posted by Dblex
Great Job!
Fantastic, replumbing would be a major pain if everything else had been done.
Old 02-08-2016, 05:53 AM
  #105
gpman
The plane looks fantastic i just got mine, hope to start on it soon. I will keep following this treat. will you make a movie about the relaunch flight with the new color scheme
kind regards Geoffrey
Old 02-09-2016, 01:10 AM
  #106
mackeyjones
Just a pic of where I put the switch and gauges for air. Ease of access. The Igyro control switch is mounted close to the other switch, I just lift of the rear of the cockpit after the pilot, and can see both the powerbox and gyro screens.
Old 02-09-2016, 04:44 AM
  #107
Dblex
My Feedback: (81)
Dblex's Avatar
Mackey, your cockpit sits in? How is it mounted?
also, how do you like flying with a gyro???
Old 02-09-2016, 06:13 PM
  #108
mackeyjones
The cockpit sits in the lip in the fuse it is trimmed down to fit, I also trimmed that lip in the middle of the sides so the cockpit would sit in properly, I did make a ply plate for the back where I split it. Front and back half are attached to ply lugs with 4 screws.
As far as the Gyro goes, new addition so I will let you know after it is flown again. I plan on fitting one to the large 1/6th when it is out, mainly for when its taking off and landing, and also it saves a lot of mixing for flaps and when the speed brake is deployed. Also be nice to know how fast its going.
Old 02-13-2016, 02:52 PM
  #109
Dblex
My Feedback: (81)
Dblex's Avatar
Anyone add blocks to change the angle of attack on the nose gear???
Old 02-27-2016, 11:41 AM
  #110
Dblex
My Feedback: (81)
Dblex's Avatar
How is everyone doing?
I was out of town working and now finally getting back to finish up the jet. Since no one replied to my question above, I left the nose gear as is. Moving onto electronic installations and wiring.
Question on the rear electronics near the Heat and thrust tube...
Anything special to share? I plan on running all the wiring alongside the fuse away from the pipe and heat. My plan will be to heat tape it all or fabric insulation protection...
Your thoughts?
Old 02-28-2016, 01:29 AM
  #111
mackeyjones
I didnt find it was neccessary to put blocks under the front nose wheel. I did reinforce the plate it sits in though as it is prone to crack. Sorry missed your previous post. I just covered my servo wires with cable shielding and zip tied it as far away on the fuse sides as possible. I just finished adding a smoke tank and pump to a center tank that is detachable, fitted single plugs for the servo wires at the wing joint, which I have been meaning to do after its first flight and just not got around to doing it( have lights in the wings as well so that does away with 3 servo plugs). Just waiting for new flight and ecu batteries to turn up, and Im good to fly it again. I also PM'd my email to you as I dont always check here regularly.
Old 03-16-2016, 01:58 PM
  #112
Dblex
My Feedback: (81)
Dblex's Avatar
https://youtu.be/J2tEUbEdC5A
A little update
Old 03-16-2016, 02:25 PM
  #113
dbsonic
dbsonic's Avatar
Looks good. Looks like you're getting there.
Old 03-20-2016, 05:57 PM
  #114
Dblex
My Feedback: (81)
Dblex's Avatar
https://youtu.be/4yh9A0O4bwY
Finished the K180 install!! FINALLY
Old 03-20-2016, 06:59 PM
  #115
dbsonic
dbsonic's Avatar
the paint... that's unlikely to be anything you did so don't feel bad. These things to occasionally come with slight blemishes. From now on I will order matching touch up paints with these kits(ha I means arfs) as you never know when you might need it.
Old 03-21-2016, 02:47 AM
  #116
mackeyjones
Ron, I actually bolt the bottom turbine mount in first, then put the tanks in then fit the turbine and top half of the turbine mount, the hardest part is getting the front 2 bolts into the mount, the ply mounting plates for the turbine I recessed slightly to give clearance for the bolts then I just use and long reach allen key on the top and a tube spanner on the bottom.Takes a while but hopefully I don't have to pull either out for a while. Unfortunately with the larger turbine its neccessary to get them as far forward as possible if you don't want the lead in the nose.
Old 03-21-2016, 02:52 AM
  #117
mackeyjones
totally agree, most likely a spot where the paint wasn't adhered to the glass properly and when its been flexed its caused it. I had a crack show up in mine near the nose on the original paint. When I repainted it, the glass underneath was fine, the paint just isnt as flexible as the fiberglass.
Old 03-21-2016, 06:03 PM
  #118
Dblex
My Feedback: (81)
Dblex's Avatar
Yeah, I am definitely purchasing an airbrush this season. It will be a must have....
Gonna have to learn how to paint! LOL
Old 03-21-2016, 06:36 PM
  #119
Dblex
My Feedback: (81)
Dblex's Avatar
So 140-145 mm for CG is that correct? Skymaster F-18C models?
Old 03-21-2016, 09:39 PM
  #120
dbsonic
dbsonic's Avatar
For recent/newer SM F18c models with carbon wing rods, yes, 145mm is a good safe starting point and then you can go a bit back from there.
Old 03-22-2016, 12:04 AM
  #121
mackeyjones
Definately correct 145mm is a good start. Taken from the leading edge where the wing meets the fuse. Anything further forward will make your flight a lot more interesting than it should be due to your elevator being very ineffective with the tanks full. As far as setting your travel 15 mm on Aileron Up and Down, 45 mm on elevator, 25-30 mm Flaps first stage, 60 mm minimum on Landing. be careful with both your rudder application and speed brake in flight. Speed brake will push the nose up dramatically with out mixing. Too much rudder also has a tendency to tuck the nose under in flight at speed. Very draggy with the wheels down in flight, you will probably get quite a suprise at the difference wheels up and clean.
Old 04-02-2016, 08:30 AM
  #122
Dblex
My Feedback: (81)
Dblex's Avatar
Had to trim 2-3mm on flap for fitment. Anyone closing this up or leaving it open????
Old 04-02-2016, 01:45 PM
  #123
mackeyjones
As I mentioned in my Email, definately Close it up... Also if your on facebook and want to post F18 Pics to my page, use the second link on my sig. Build pics, flying photos or if you just want to chat feel welcome to post there, both are run by me, although one is just for AUS R/C the Second link is for any R/C Hornet/ Super Hornet Photos.
Iain
Old 04-11-2016, 05:03 PM
  #124
Dblex
My Feedback: (81)
Dblex's Avatar
NAS Kingsville Airshow 2016
ID:	2156945   Click image for larger version
ID:	2156946   Click image for larger version
ID:	2156947   Click image for larger version
ID:	2156950   Click image for larger version
Old 04-11-2016, 06:35 PM
  #125
dbsonic
dbsonic's Avatar
That's cool. Which Blue Angel crew members?
