Jeti DS-24
Reply
Old 12-05-2018, 08:06 AM
  #1126
Edgar Perez
My Feedback: (13)
Edgar Perez's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by Tip22v View Post
What is that you don't trust about the CBM200 with its current firmware? Is there any estimate on when this new firmware will be available? Is anyone flying a CBM200 with 2 x R3 + 900 MHz, if so is there anything I need to watch for?
Thanks -Tom
actually trust may not be the right word.
The are earlier posts on this thread about the way CB200 will still use Rx #1 even when there is significant interference and Rx #2 signal is good.
In my opinion this significantly reduce the value of using the CB200 versus other options.
Edgar Perez is online now
Old 12-05-2018, 08:08 AM
  #1127
Dansy
My Feedback: (53)
Dansy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well its your opinion.....mine is the CB200 is perfectly fine....never had problems since 2013......flowns in 3D and jets....
Dansy is offline
Old 12-05-2018, 12:03 PM
  #1128
Tip22v
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I read those posts about the receiver priority and the CB200, I think it was around post #395. After considering all of the information I'm thinking the best option for "triple" redundancy using a CB200 would be to use a REX receiver for one input into the CB200 (Rx1), then plug an R3 into the REX receiver for redundant 2.4, then plug a 900mhz receiver into the Rx2 port of the CB200. Someone else on this thread has mentioned this option as well. The idea here is that the 2 x 2.4 receivers presumably switch back and forth better depending on which has the better signal(?), while the 900 MHz receiver will only take over if both 2.4 receivers fail. What I don't know with this setup is what happens to telemetry? Can I still get telemetry on all three receivers? Also, if I want to include a Cortex Pro in the mix what does that involve? Thanks for the help. - Tom
Tip22v is online now
Old 12-05-2018, 12:37 PM
  #1129
wfield0455
My Feedback: (7)
wfield0455's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
At the time it seemed as if the regular receivers made better use of the secondary receiver but after some testing by a regular poster over on RCG it turns out the regular receivers behave in a very similar fashion to the cb200 in this regard. I've heard that a new firmware for the cb200 is expected that will improve this situation but I'm not sure when or if that will actually happen. Even as it is, while not ideal, it's not the end of the world either.
wfield0455 is offline
Old 12-05-2018, 01:49 PM
  #1130
Dansy
My Feedback: (53)
Dansy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I used the Cortex pro before and will again next season.....work fine.
telemetry will work the same with or without the Cortex....and 3 RXs you just got more that you can select like the 900 voltage, signal ect....
Dansy is offline
Old 12-06-2018, 07:58 AM
  #1131
Tip22v
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sounds like I just need to pick a configuration and go with it
Old 12-06-2018, 09:55 AM
  #1132
camss69
My Feedback: (46)
camss69's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I put a CB200 setup in one of my planes early this year and have been flying it with no perceived issues either while flying or viewing the telemetry. The CB200 as well as the standard receivers have been this way the whole time with very few issues as I understand it. It demonstrates that the backup receivers may not be as necessary as we all think they are. Obviously they aren’t or planes would be falling out of the sky. My current build i had planned a REX12A with a R3 as a second RX. But now I’m wondering if I even bother with the R3. I already have another R3 acting as a remote switch for the DSM10. . Maybe I just go with the REX12A and the R3 as the switch and call it good.
Don’t get me wrong when the firmware update or the new CB2XX comes out I’ll be looking to to update... but really, at least in my flying environment/installations the second RX doesn’t appear necessary.
camss69 is offline
Old 12-06-2018, 10:50 AM
  #1133
digitech
My Feedback: (10)
digitech's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have done like this
rex3-20 clone mode into port a cortex
rex3-20 default mode into port b cortex (port b has telemetric)
cortex port 6 to rx1 on cb200
rex900 on rx2 on cb200
digitech is offline
Old 12-10-2018, 10:43 AM
  #1134
ZB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
New Jeti Ditex TD 0606M & TD 0806MD servos just showed up. This finally completes the whole line of Ditex servos.
Zb/Jeti USA
ZB is offline
Old 12-10-2018, 01:18 PM
  #1135
camss69
My Feedback: (46)
camss69's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Zb/Jeti USA
Any specs on these?
camss69 is offline
Old 12-13-2018, 08:55 AM
  #1137
ZB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Look what is coming as Xmas gift from Jeti, new Central Box 200 for 3x Receiver connection.
Zb/Jeti USA
ZB is offline
Old 12-13-2018, 10:32 AM
  #1138
Tip22v
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Zb/Jeti USA
Is this a firmware update or new hardware? I hope it’s just firmware because I just bought 2 CB200 units in the past couple of weeks!
Old 12-13-2018, 11:34 AM
  #1139
F1 Rocket
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is this a firmware update or new hardware? I hope its just firmware because I just bought 2 CB200 units in the past couple of weeks!
FW update for existing CB200s.
Danny
F1 Rocket is online now
Old 12-13-2018, 12:01 PM
  #1140
camss69
My Feedback: (46)
camss69's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Is it already available on Jeti Studio?
Are there release notes someone can post?
camss69 is offline
Old 12-13-2018, 01:44 PM
  #1141
Tip22v
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Danny
Thanks Danny! -Tom
Old 12-13-2018, 11:46 PM
  #1142
causeitflies
causeitflies's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
FW update for existing CB200’s.
Danny
Will this change how a Cortex can be hooked up?
causeitflies is offline
Old 12-15-2018, 04:04 PM
  #1143
FlorianDo
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Question Snow for Christmas ?
Just saw this on my DS24 before switching on, didnt touch it for about 2 months.
Is this a christmas easteregg?
Edit: Seems that there are other things like these, depending on the date in the transmitter :-)
FlorianDo is offline
Old 12-15-2018, 04:18 PM
  #1144
tp777fo
My Feedback: (28)
tp777fo's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I also have it on my DS-16
tp777fo is online now
Old 12-15-2018, 04:58 PM
  #1145
Viper1GJ
My Feedback: (19)
Viper1GJ's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Lol, got it on my -24 also. I thought it was a touch of class!
Gary
Viper1GJ is offline
Old 12-15-2018, 05:54 PM
  #1146
warbird_1
My Feedback: (61)
warbird_1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't see a need for these eye candy trinkets. I'd like to turn them off. What's next,rainbows on rainy days
warbird_1 is offline
Old 12-16-2018, 05:00 AM
  #1147
ltc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Dont forget about the unicorns ... spoiler alert
ltc is offline
Old 12-16-2018, 06:11 AM
  #1148
Custmachr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The snowflakes have been there this time of year for at least two maybe three years now.
Custmachr is offline
Old 12-16-2018, 06:15 AM
  #1149
Dansy
My Feedback: (53)
Dansy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Been there since the very beginning for all of December......enjoy.
To turn it off, just turn the TX OFF........LOL
Dansy is offline
Old 12-16-2018, 07:36 AM
  #1150
philjac94
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Its been there for a few years, but obviously it does not reflect an Australian Xmas Summer
philjac94 is offline
