Weatronic/ ultiate Jets important anouncement.
Weatronic/ Ultimate Jets anouncement.
Dear all.
With the release of firmware 6.08, Weatronic unlocked very powerful features that we used to offer new unique products to the market.
First of all, the new Smart 8-23 ULRS that I believe is the most integrated and sophisticated receiver on the market.
http://www.ultimate-jets.net/collect...mart-8-23-ulrs
The receiver is extremely light ( 15 grs/ 0.53 oz ) and compact ( 2.5" x 1" x 0.7" ), yet offers the following:
- Up to 23 servo output ( 8 or 7 PWM, 16 serial )
- 2 Fully parallel RF circuitry, each using one Ultra Long Range hemispheric patch antenna
- 1 Telemetry port
- 1 optional integrated gyro
- High current capacity through our MIL spec serial harness ( up to 20 A peak current ).
- Fully programmable through the BAT transmitter ( the model program is stored in the receiver with all the mixers, ATV, servo centers...)
This is the first time that a 0.5 oz receiver offers 23 fully programmable and independent servo outputs and two Ultra Long Rang patch antennas, an optional integrated gyro and telemetry port!
The serial output of the receiver, when activated, enables to connect servo through three type of protocols: Sum Signal, SRXL Multiplex, SRXL Weatronic. Up to 16 servos can be connected and programmed through the BAT transmitter.Our experience in MIL and aerospace harnesses (UAV ) was used to create a unique high current solution to plug up to 16 digital servo on one serial loop using Kirschoff's law. The UHCL ( Ultimate High Current Loom ) is designed with our range of MIL spec connectors ( USC 3 plug ) and cables ( silver core PTFE coated wire ).An EMS 100 ( Emcotec MPX compatible high quality power plug ) allows direct plugging of a Lipo 2S battery that feed the serial loom directly as well as the receiver. A second battery can be plugged to port 8 of the receiver via a Y lead. The picture below shows the EMS 100 plug as well as master USC 3 femal plug on the receiver.
This allows for a very high reliability and power acceptance. One of the big problem with serial harnesses is that if one component fails, all the servos downstream the component will lose their functionality. To avoid this problem, we are using our industry leading USC 3 ( Ultimate Servo Connector 3 ) which feature a super strong clip-on system ( the plug cannot disconnect once clipped ) and extremely resilient high current gold plated connectors ( tested under 50 Gs of vibration and certified for 5000 connect/ disconnect cycles ).
A small serial board is being designed now. It will use two female USC 3 welded sockets, one servo output and one programming port output. You will be able to connect the board where you want in the model, using different length UHCL harness extensions. The programming port will be used to assign the servo number in the serial sequence with the USB upgrade dongle.The UHCL extensions are available in the following lengths: 40 cm ( 15" ), 80 cm ( 30" ), 120 cm ( 45" ), 160 cm ( 60 " ) and 200 cm ( 75" ) and the following section: 14 AWG and 20 AWG. Custom lenghts can be built on request.The 14 AWG extension must be used at the beginning of the serial loom, whereas the 20 AWG can be used at the end of the loom.The maximum servo power that be assigned to the loom is as followed:Servo 1 to 5: 400 oz.in ( 2 A continuous per servo at peak power )Servo 6 to 16: 200 oz.in ( 1 A continuous per servo at peak power )So, our system allows for 5 high torque digital servos and 10 medium torque.
However, for those will to put only a few small servo to the serial loom, we will also offer a standard size set of serial extensions with JR type connectors, for a maximum of 3 A current capacity.
The Smart 8-23 ULRS receiver also features the ability to accept our Ultra Long Range patch antennas ( thhe ones used on the transmitter ). These antennas boost the range of the receiver up to 5 km/ 3 Mi and most importantly, offer a near omnidirectional reception diagram. That means that the placement of the antenna is a lot less critical as there is no dead zone with this technology.
Also, because of the female SMA connector offered, very thin adhesive foil antennas can be used with this receiver, for carbon fiber or Flite Metal/ metalized fuselages, and glued on the outer side of the model skin.
The other important announcement I wanted to make here is that we are about to release the Weatronic version of our ASSI telemetry board.
This means that we will very soon be able to input all the ECU data, as well as angle of attack, pitot, accelerations directly to the radio.
We are also programming a set of custom telemetry pages for the ASSI that will be unique and offer specific graphics for the BAT series transmitters.
This will also offer auto throttle function and hopefully engine failure automatic compensation for twins.
Happy New Year!!!!
All the programming is done directly from the large touch color LCD screen.
Regarding ASSI and other modules I make and the integration into Weatronic transmitters.
As I'm supporting more and more transmitter brands, I have acquired a certain insight in the different vendors protocols and capabilities.
I have deep knowledge of Futaba SBUS/SBUS2 and a good knowledge of Jeti, JR, HoTT and Spektrum.
As I'm now integrating stuff into Weatronic I have to say that Weatronic is way ahead of the others in terms of telemetry. They are the _only_ one that has made the telemetry protocol in a near perfect way, and they clearly have been using their heads and technical skills when they designed the protocol. Most other brands are more or less lucky with their implementations but Weatronic is very close to the perfect way of doing things (in terms of protocol and flexibility).
Its going to be very exciting to implement support for that brand in my devices and see what can be done
Your device will certainly move them in the right direction with telemetry. A couple of questions: Does your device connect to the Mux box or does it plug directly into the SCU port of the receiver? If the latter, can other devices be connected as well or does that limit telemetry to your device only?
Is ASSI compatible with the Ver 6xx Jetcat ECU's or is it only the Ver10's? Do you foresee compatibility with the Projet ECU's as well (as Ulimate jet carries BF and Behotec)?
Mike
Thanks Mike,
What I'm doing at the moment, is a small "CAN Bus to SCU" protocol converter. This is a small device that has a CAN bus connector that fits with the rest of my stuff, ASSI, pressure sensor etc.
It also has a SCU IN and a SCU out connector, so it does not need a MUX box to work. You connect a cable from my device's SCU OUT to the receivers SCU IN port. You can then connect other Weatronic telemetry devices to my device's SCU IN port etc (so its a "full blown" implementation of the Weatronic SCU port technology).
The ASSI is compatible with both V6 and V10 ECU's from JetCat (and Xicoy/Gaspar ECU's, AMT and soon Projet (once they answer the last few questions I sent them some time ago...)
Thanks Mike,
Mike
The next level was already reached some time ago by allowing the integration of patch antennas into a micro receiver
Thanks to this technology, it is the only system on the market allowing a range of over 6000 feet for UAV operators ( near ground-to-ground in jammed sub-urban environment ).
http://www.rcuniverse.com/forum/fpv-...o-systems.html
This, coupled with the intelligent frequency hopping technology, offers the best jamming resistance on the market as well. It might seem pretty insignificant until the day you decide to fly your beloved models in a big meeting like Joe Nall or Jet Over Kentucky with many flight lines, or you fly at a sub-urban Californian field...
Not to mention the fact that the patch antenna is the only one o the market to offer an hemispherical reception diagram that does not have any blind spot. Ask Lance Campbell what he thinks about this and how useful it was when he integrated it in his SR-71...
I am not claiming this blind. We have been using the modules for 7 years now and have accumulated over a million hour of use and created a unique operator's data base.
http://www.ultimate-jets.net/blogs/w...-link-database
And our ultimate Log Reader is also unique on the market in that it applies statistical analysis to you flights and give you an immediate readout of the quality of the RF link for each of your flight.
This statistical tool is being integrated on the World database and will soon offer you the ability to compare your system with the one from a German or Israeli user for example, or other people using the same system at your field...
Also I will soon be able to apply statistical data to ECU parameter readout that will be able to detect the degradation of following components over the time:
. Fuel pump ( gear wear )
. Kero burner ( oxidation )
. Combustion chamber ( degradation, warping )
. Turbine stage ( blade leading edge degradation, blade rubbing on the NGV )
We are also working with Carsten on integrating a vibration sensor to the ASSI that will be able to issue statistical alerts for bearing wear for all turbine brands on the market.
And here is a video of the serial board in action with 8 servos connected on the SRXL port of the Smart 8-23 ULRS receiver;
https://www.youtube.com/watch?v=819rwZde0x4 All of this technology is coming from my experience in dealing with airline statistical data analysis and UAV design as well as from Carsten genius mind...
I am putting all my experience and knowledge in developing World class components and services. This is my hobby and what I love to do the most. So I hope that you guys will appreciate it...
The previous video shows a configuration with 8 servos connected to the SRXL port, labelled "Serial Main 1" to "Serial Main 8" on the BAT programming page.
Servos 2 to 8 are still available as regular PWM outputs on the receiver.
So, this config bring the Smart receiver to 15 independent servos/ channels. This can be pushed to 23 independent outputs ( 16 serial servos and 7 PWM servos ) for one receiver, 46 independent outputs with 2 receivers ( Main and Sub 1 ) and 62 independent outputs/ channels with 3 receivers ( Main, Sub 1 and Sub 2 ). The BAT series radios being limited to 62 independent outputs/ channels...
The board we are creating with Carsten will be smaller than the one showing on the video, be be easier to integrate. However it will output maximum 4 servos.
It will feature Lock Plugs for the serial loom AND for the servos for maximum reliability.
The board will also be fail passive. This means that if the active components on the board fail/ burn, the servos downstream the serial loom will no be affected and will still be working.
A maximum of 4 boards can be chained to the serial harness for 16 servo outputs.
As you can see, my aim is to offer to the modelers an aero spec solution ( fail passive, high current and super secure ) that allows to chain many high torque servos on a single serial harness with 100% reliability and full current capability.
Oli, you can actually connect 23 servos in total to the Smart 8 receiver, 7 direct to the receiver and 16 servos from two of the 8 channel expanders in the video (each driving 8 servos)
All 23 servos will be driven by their own channel from the transmitter, so they are all independent of each other.
I've been using the receivers for years, and have a new BAT60 sitting on the bench I'm looking forward to getting into.
I can't speak more highly about how well the patch antennas work. Analyzing the data, I worked my way through 5 different locations/orientations, initially standard antennas then the patch ones.
With the patch antennas in place now, I'm getting 95-100% signal strength when flying over half mile away (I've checked distances with the GPS data.) Anything inside of half mile, it's 100% all the time.
I'm really looking forward to playing with the new toys and options that are evolving...
Lance
Lance
Lance
I hope that we'll be able to grab a few extra dB of reception levels very soon. Not that the system really lacks on this side, but I can't help researching and implementing latest technologies...
Hi Oli
Do you ever sleep?
Great to see the new things coming..
Plus we know how well the patch antennas work on the Micro don't we!
Alan
Do you ever sleep?
Alan
Then, you'll probably be interested to hear that I am now working on the next generation ceramic patch antennas.
Here is a picture of the serial board mock-up with the 4 servos ports ( lock type plugs, JR compatible for added safety ).
The board is about 4' long by 1' wide and 1' thick. 2/3 of the length is taken by the MIL spec connectors, but I was willing to sacrifice a bit of the size towards reliability and current capacity...
Also, the fail passive concept is absolutely essential for a serial board. Should a component fail on the harness, none of the servos downstream will be affected .
...and it's (almost) here
http://www.rcuniverse.com/forum/rc-j...l#post12165116
Also the board mentioned by Oli above is running as prototypes now, being tested at the moment (these will also work with Futaba SBUS , JR XBus and even Spektrum )
As soon as I can get telemetry for JetCat I will convert my CARF Hawk from FASST to Weatronic as it will be an incentive to having to reset everything up again!
Carsten do you know how long it will be before your board will be available?
Notice that Jeti USA viewing as well! Welcome...
Alan
Alan
Hi Alan,
at the moment I'm waiting for some further info from Weatronic in order to get the system up and running perfectly (screen design on transmitter etc). My best bet is I should have it running on the prototype in 2 to 4 weeks.
After that production of a smaller number of converters (a couple of weeks)
