It's coming! Skymaster F-18 1/6 on 2016
#234
I haver about 15 flights already in mine and have moo problems at all.
Best regards,
Michel
#235
I wouldnt add a bypass, got to see what slowed air through a bypass can do at MS jets nose down and no airspeed increase.
#239
From what I saw it wouldn't allow the aircraft to gain speed in the dive, it didn't seem to gain speed even in the dive. I think it wouldn't change much if the bypass was big enough, I would post one of those laws but having figured out pictures yet lol
#240
Hi, all
good news, today we just finished test the single turbine flight of the F-18f 1/6.25 powered by 2 x K-160 in the tail without the tailpipe , no problem, the video coming soon.,
#241
Thanks for the video, the only thing I would be interested in is having the same results with wing tanks on. I plan to do one with turbines in the tail eventually. Nice flying 👍
#245
My Feedback: (25)
No, all the tests were done in the air after takeoff. Second test is at 6:14, the second test is with one turbine at idle and the other at full power. I don't know why you would take off with one engine unless you were at the end of the no turn back point and one turbine quit, that would be interesting. Seems to work just fine, would be interested to know the thrust angles myself though.
#246
yes, We will email to all customers who order the turbines mount in the tail , and we will modify the manual as soon,
the customers will need adjust engine correct angle using washers.The engine rails distance is enough to adjust engine installation from 1 to 5 degrees.
#247
My Feedback: (9)
#248
My Feedback: (54)
To me, it is easy to show shutting down an engine in cruise flight when expected and to take proper flight controls. Then to glide in from a high enough altitude. Totally different then what Gunradd had with his jet. Since Gunradd's failed close to V1 or Vr if both were the same, with full drag of tanks, etc. Engines or not, going into any maneuver with speed is easy. Bob Hoover used to prove that with a Shrike. Not really impress that this is a solved issue.
#249
My Feedback: (25)
#250
My Feedback: (54)
I saw the demonstration. You must not understand drag if you don't understand what the tanks have to do with it. You also must not understand what speed has to do with it, and Vmc. The approach was high and fast to touchdown. I've been following the thread so yes I understand the engine angles.
We also don't know how much fuel was on board. Full tanks or half tanks ? Weight makes a huge difference.
