Now that we are forced to register,
FL
Now that the AMA has kneeled before the FAA and we have been mandated to use the FAA's scheme of registering our model airplanes...strike that...I mean our" UAS's", I have decided that I will not place the required registration number in an obvious location. Not inside the canopy, not inside a hatch or other location that requires the use of tools either, because that would violate the rules. That would subject me to a longer prison term and a higher fine than a common criminal, like a burglar. Funny how that works.......
When the flaps are up, the number is not visible....when the flaps are down, it is. Ten characters! Why am I not surprised? Four digit AMA number, ten digit FAA number.....go figure. Common AMA and get off dead center and show some cajones!
A "Brother" label maker does the job, and some 5 minute epoxy smooths out the rear spar, allowing the label adhesive to stick.
Here's an example showing the location on my FLY NAVY KingCat.I have done this to my fleet with great results. The FAA inspector won't get to touch my jet this way.
CO
Q47. Is putting my AMA number on my drone enough?
A. No. Not at this time. The registration system will generate a unique FAA registration number, which you must mark on your aircraft.
Q48. Would putting my contact information on my drone be enough?
A. No, you must mark it with the FAA registration number.
Q49. How do I mark my unmanned aircraft with the unique registration number?
A. You may use any method to affix the number, such as permanent marker, label, engraving, or other means, as long as the number is readily accessible and maintained in a condition that is readable and legible upon close visual inspection. If your unmanned aircraft has an easily accessible battery compartment you may affix the number in that compartment.
My Feedback: (24)
From the AMA FAQ webpage on registration:
Q: Do I need to list both my AMA number and my federal registration number on my aircraft?
A: Possibly. We are advocating to allow members to use their AMA numbers. We believe an AMA membership already meets the intent of registration. It should not be necessary for our members to register again through the FAA when they are already registered with the AMA.
This is a change from before where they said that AMA numbers only would suffice. Hopefully it will get worked out such that AMA numbers alone will be sufficient. Until I hear otherwise, only my AMA number is in my models...
Bob
Bob
I agree with you, but I am also weary of the AMA now, since they keep trying to contradict the FAA then telling us to comply anyways.
Bob
Bob
Harley, that is a great idea. I was wondering where to put the number on my KingCat as it requires a tool to remove the canopy/ hatch. Love it. I will use the smallest font I can print.
I got my FAA number and AMA number on my planes. My planes wear these numbers proudly just like my vintage muscle car wears it's factory badging and aftermarket performance equipment stickers And now I focus on enjoying flying my planes without having to 1) worry that I am in violation of any rules, regulations and/or laws with the FAA, AMA and/or club I fly at, 2) no longer spend my time thinking about how requirements have changed. I'll reevaluate this in three years if the fee increases.
I support the only lawsuit against the trampling of freedom and destruction of quality of life this FAA reg represents, that I am aware of at this point.
I fully support regulations on certain forms of RC.
You fly traditional planes, heli's, multirotors, the AMA rules are sufficient.
You
1. Add a camera
2. Add FPV
3. Add GPS
4. Add autonomous capaility
5. Fly BLOS
6. Fly for commercial purposes
And/Or
7. Fly in the NAS
then new regs apply.
I'm completely against this heinous pattern of rule and law making in the US, inaugurated by Obamacare, where millions of people are thrown into a grinder, and the legislators/rulemakers take the "We'll figure it out later" approach. This MO needs to be thwarted. Lawsuit is the language WDC understands. The measures enacted by the FAA >obviously< exceed what's necessary. If you want any Fed agency to use the precedence created in this situation to install more/ worse ridiculous restrictions in the future, than roll over for these. Have the lawmakers and rulemakers actually do some work and produce good regs and laws - that's all I am saying.
I'd like to have offline, live conversations with some of you who aren't bothered by the fact that the reg ruthlessly obliterated decent, law-abiding RC flying in a 2827 square mile area. No kites, no C/L flying, no nothing. That doesn't sound onerous to you? Wait for worse things to come...
Full disclosure: I have a lot to gain if the regs stay in place.
1. I fly RC
2. I have a private pilot rating, deep into IFR training, leading to commercial.
3. I am a part time architecture/real estate photographer.
I can apply for and get the 333 exemption while those without any full-scale pilot certificate will have to spend at least $5k to get the basic rating needed.
It is to my advantage to roll with the FAA regs - but that wouldn't be right. I would rather see fuller justice.
You
1. Add a camera
2. Add FPV
3. Add GPS
5. Fly BLOS
And/Or
7. Fly in the NAS
1. I fly RC
You gotta love it. The AMA told us to hold off registering just long enough to cause us to now pay the registration fee. Not a large amount, but I would have registered in December if they hadn't said, "BUT WAIT". Grrr. Perhaps I ought to deduct the fee from my AMA dues next year and see what they think. Bet that doesn't work at all. I usually don't gripe about stuff, but this whole affair was totally mis-handled from the beginning.
