Reload this Page >
DV8R, who is flying them and what would you change?
Old 01-01-2017, 06:50 AM
  #76
FMRR
CARS II, You will love the jet. I bought mine new from TBM with there gear. 28lb with Jetca P80. Very strong airframe and flys like a dream. Got my turbine waiver with mine 2 years ago and still own it with out scratch on it. If there any doubts if a P80 can push it along look up Frank Mraz flying DV8R youtube. Tip to landing her is just slow her down and she will grease in. TBM gear work great just replace the springs with stiffer ones . Glad to see interest in this jet once again. Will follow your progress. Happy New Year to all !
Old 01-01-2017, 01:52 PM
  #77
CARS II
My Feedback: (7)
CARS II's Avatar
Thank you for the pictures Mike.
FMRR, I will watch that video and thanks for the tips.
Watched, very nice performance with P 80.
Old 01-02-2017, 05:24 AM
  #78
FMRR
Your very welcome, glad you enjoyed it. Sorry landing was not captured...camera battery went dead . It was a picture perfect touch down. I have upgraded all three wheels too IntairCo with electric brakes. Also adding two parachutes for fun. I'm thinking about adding F18 Style canopy on top of the orginal to give it more of a miltary look... but have not had the time yet to form the master plug yet. I'll pm you when I do and make one for you you if you like it.. again good luck with your build..you will absolutely love this jet...
Old 01-02-2017, 10:41 AM
  #79
CARS II
My Feedback: (7)
CARS II's Avatar
It will be very nice to get one, thanks.I also have some thoughts about modifying the canopy/hatch, it looks too long and plant to make it shorter ( I'll have to get some drawings going here soon ) I'm also going with the 4" and 3" wheels, I will implement some of the original PCM design and my own.
Old 01-02-2017, 03:16 PM
  #80
CARS II
My Feedback: (7)
CARS II's Avatar
Looking through an old DV8R thread I saw a post regarding flying with 1/8 of elevators up as normal, I also saw a post regarding the fix for that, the horizontal stabs were repositioned so the elevators would end up aligned with the top of the rear of the fuse when in the neutral position ( ala F-16 )
Can you guys comment on that.
Tks.
Old 01-02-2017, 06:18 PM
  #81
CARS II
My Feedback: (7)
CARS II's Avatar
Cutting my first template by hand was interesting, I now direct my work to drawing, got drawing paper wide enough to draw all the parts, I also got me some nice drawing pencils ( I probably never use them but I wanted them anyways )
Where am I going with this, I have no idea but I'm going, continue
Old 01-02-2017, 11:58 PM
  #82
CARS II
My Feedback: (7)
CARS II's Avatar
Double post.
Old 01-03-2017, 12:00 AM
  #83
CARS II
My Feedback: (7)
CARS II's Avatar
OK so, my 10 years old daughter can draw better than me that's for sure drawing is fun and I like it because I am now been able to put on paper all my thoughts about the design of this airplane and they're out of my head, fiiiuuuuuu
As you can see on the pictures I had to reconstruct some of the central part of the fuse to have a complete side of the fuselage and in doing so I had to gestimate the angle of the nose, I think it came out OK so, we are going with it that way, moving forwards.
I now have the contour of the fuse side on paper and I began filling it with details.
ID:	2195379   Click image for larger version
Old 01-03-2017, 01:49 AM
  #84
CARS II
My Feedback: (7)
CARS II's Avatar
Frank
Did you ever heard back from Jay ( jetboy ) about the 120 oz fuel tank or the mold for this jet, I sent him a pm a few days ago but no reply yet.
I would like to have a tank or the mold.
Thanks.
Old 01-03-2017, 08:17 AM
  #85
youngguy
My Feedback: (7)
youngguy's Avatar
Tks.
I modified three TBM DV9Rs after seeing the amount of up trim required on another TBM DV8R (mine is the one shown in the photos. I assembled some for other folks). All worked well and the jets flew very nicely through all speed ranges with no up trim required. Probably more cosmetic than requirement. Another individual I know, accomplished the same thing changing the trust angles on his engine.
SaveSave
Old 01-03-2017, 12:38 PM
  #86
CARS II
My Feedback: (7)
CARS II's Avatar
Thank you for the information.
I read that on that thread, I think I'm going to screw the engine mount rails, that way if the trust angle needs adjusting I will be able to do that by moving them instead of adding a spacer on the back of the engine then I can glue them, if the 1/8" up elevators persist then I will consider moving the stabs.
Question, how where you able to move/twist the carbon spar or mount?
I always thought that the engine mount rails were too big and too thick, the owners end up cutting lots of it to be able to fit a bigger engine.
Old 01-03-2017, 03:59 PM
  #87
youngguy
My Feedback: (7)
youngguy's Avatar
I did a lot of fileing on the slot that fits the CF joiner and did some changes to the joiner as well. Involved a fair bit of fitting and trial and error. Should be a lot easier todo if you are designing new
mounts. The original DV8R used plywood instead of CF to mount the stabs.
I change the engine mounting rails to the inside of the tail booms to get the necessary clearance to mount a P120SE. Also a bit of work to do the mod.
Old 01-03-2017, 05:17 PM
  #88
CARS II
My Feedback: (7)
CARS II's Avatar
Yes, new mounts for the stabs will be great with CF rods, that way they can be rotated to find the right spot, I will have to think about that for a moment.
For the engine mounts I have already decided to not glue them till the right trust angle has been found.
Thank you for the info.
Old 01-04-2017, 01:09 AM
  #89
CARS II
My Feedback: (7)
CARS II's Avatar
The work continues on the fuse parts, I may have them on a PDF file by Friday.
As you can see, some of the parts are missing pieces from when the jet crash landed, I have to flip the part over to retrace it or look at the pictures in the manual to be able to get a 100% part.
I'm also modifying some parts like fuel tank floor, it doesn't need to be longer than what I have on the drawing, it went back to its original size, I'm removing one of the bulkheads and a floor doubler, again that wasn't there on the original design, less wood lighter product.
ID:	2195461   Click image for larger version
ID:	2195462   Click image for larger version
Old 01-04-2017, 07:59 PM
  #90
Johnny Isaiah Woods
My Feedback: (81)
Carlos,
I am using a Dubro 100 oz fuel tank that fits into the opening of the TBM DV8R. I got this tank
from Tower. You are doing a great job on the pieces I sent you.
Johnny
Old 01-05-2017, 02:28 AM
  #91
CARS II
My Feedback: (7)
CARS II's Avatar
Hey! Johnny, is good to see that you are still around here.
Thanks, I postponed this project for too long, but now we're full throttle on it to get it done soon.
Johnny, could you do me a favor, I need the pattern for the canopy floor, the pieces that I got are not enough to make a template.
I would really appreciate it.
Thank you
Old 01-05-2017, 02:49 AM
  #92
CARS II
My Feedback: (7)
CARS II's Avatar
I now have all the fuse parts drawn on paper, some were easy to do a few were not because of the missing pieces.
The part the holds the stabs that gives them their unique angle was the last one that I had to do, this part is made out of two pieces sandwiching a center one with the cut outs for the stabs angle, to get to the center one I had to torch the part to soften the epoxy that was used to glue it together.
Old 01-05-2017, 09:02 PM
  #93
Johnny Isaiah Woods
My Feedback: (81)
PM sent
Johnny
Old 01-05-2017, 11:04 PM
  #94
CARS II
My Feedback: (7)
CARS II's Avatar
I'm done with the fuse, while I wait for a fuse kit to show up at the front door, I get to start work on the wings.
Old 01-06-2017, 04:33 AM
  #95
geneh-RCU
geneh-RCU's Avatar
Who is going to make the fuselage kit? I also have a TBM DV8R that is ready to fly if we get some good weather I will take it out. It would be good to have a copy of the drawn parts.
Gene
Old 01-06-2017, 10:44 AM
  #96
CARS II
My Feedback: (7)
CARS II's Avatar
Local friend that has a laser cutter.
Gene post pictures of your jet, how about a video of the maiden flight?
Old 01-06-2017, 01:46 PM
  #97
CARS II
My Feedback: (7)
CARS II's Avatar
I talked to Johnny about the missing canopy/hatch frame, he is kind enough to agreed to trace the pattern on a sheet of paper, not only that, he found the missing BH2 together with the nose retract mount that was missing, adding those three parts complets the fuse.
Thank you for lending a hand Johnny.
Old 01-10-2017, 11:28 AM
  #98
CARS II
My Feedback: (7)
CARS II's Avatar
Works continue,
While I wait for the pattern that Johnny sent me I decided to try to recreate the canopy frame, looking at pictures and taking some measurements, I was able to come up with this drawing but I feel it doesn't have the right shape yet, I will compare it with the one Johnny sent to see how close I am.
I also started work on the stabs, this is a great opportunity to see the insides of stabs and later the wing, so far I think this stab had enough glue, the skin was well attached to the frame, every where.
ID:	2196228   Click image for larger version
ID:	2196229   Click image for larger version
ID:	2196230   Click image for larger version
Old 01-11-2017, 05:42 PM
  #99
CARS II
My Feedback: (7)
CARS II's Avatar
Well, Johnny came through again, what a guy the box with the goodies came today, theses parts should complete the fuse.
Old 01-11-2017, 06:15 PM
  #100
Mike06659
Mike06659's Avatar
It would be nice if LDS could offer this as a kit. Maybe if there is enough info we could get it to them?
Mike
http://store.laser-design-services.com/
