BVM Composite Bandit Build Thread. Yes from 1998.
#102
Here is a tip with the toothpick method.
-Line the parts up perfectly and tape firmly in place from the inside.
-Start gluing on toothpicks from the top.
-Using medium cyno (sparingly) and kicker, glue the first tooth pick to the cowl side only. Don’t put any glue on the fuse side, or get any cyno in the gap.
-Cyno the second tooth pick to the fuse side only. Don’t glue it to the cowl.
-Work down form the top, gluing them on alternately, fuse, then cowl. Space them about 10 mm apart and work right around to the underside.
-When finished, remove the tape you used to hold the parts in place..
-Now, CAREFULLY, slide the cowl forward and off the fuse,,, with half the toothpicks still attached to each side!!
You should be able to slide it back into place with it lining up perfectly. You are now ready to apply Hysol.
The photo below is my crappy photo shop of how it will look.
I actually glue the tooth picks directly on to the surface, with no protective masking tape. It is fairly easy to remove them and refinish the surface. You will need to do some filling in this area anyway.
As Matt says, make sure you get plenty of Hysol into the seam, when you finally glue in place. It should ooze out a little bit.
Keep us posted..
Keep us posted..
#103
Trying to get a pic of this is touch. But as I push my cown onto the fuse, its like the cowl is too big to fit into the fuse seem. There is a good .5mm of slack or so. So if I start bottom or top and line it up exactly with the fuse seem, when I get to the end there is a gap because its too "long". I tried sanding lots but its as thin as its going to get, any ideas what I need to do?
The toothpick method works ok if I use balsa, it allows the slack to spread out a bit but makes an uneven seem. Toothpicks have a bit much give, so the balsa is better. But getting hysol in the fuse underneath the balsa seems to be a chore! Also once I glue it some glue will come out and get on the balsa and the balsa will be fused to the seem. I assume I just sand that out?
Somethings off here.
#105
My Feedback: (10)
Yes the bottom line is the cowl is a bit too big for the fuse. The whole reason you are using the balsa sticks is to try to distribute the cowl gap as evenly as possible over the whole perimeter. If you have a perfect gap somewhere, you will have a huge gap somewhere else. So the balsa sticks just make it easy to have a constant gap.
You don't care how much glue oozes out as you are going to sand it off. I recommend the old classic aeropoxy, loctite 9462. It sands pretty well. Fill up the gap 100% or you will have sanding waves later.
After sanding down the glue, you will have a new challenge, you will have to level out that seam, using a polyester filter (lightweight Bondo), or an epoxy filler I prefer. A lot of work left after those cowls are on.
#106
Well then lol, I guess I didnt follow fully what was going on. Honestly, I keep thinking this is BVM, they are perfect and it must be something I am doing wrong.
On the inside, once you glue, are you sanding down the flanges/mating surfaces flat? I thought that is what you were talking about sanding.
#107
My Feedback: (10)
Well yes, you have to sand the outside, but you also will use filler to level it out (fill, sand, repeat, fill sand, repeat). The outside will get sanded down flat at least 320 grit before the primer goes on.
The inside sanding is just to get it flat enough to glass in the reinforcing cloth reasonably flat.
In my experience this kit is about as good as fiberglass kits came, maybe Jet Model was a bit better, Yellow a bit behind but close. This is just stuff you have to do to build a fiberglass kit, nothing unusual. It all depends how good you want it to come out. I know one thing you can make it a hell of a lot better than the ARFs out there.
#108
Yeah, What Matt Said.
Fibreglass is not a completely “stable” product and it will deform over time. Plus Sizing is never 100 % accurate or consistent, these parts were are hand laid. And sometimes it seems as if the BVM kit designers went out of their way to make a job difficult. (Wait till you try hinging a Super Bandit.)
Remember, your kit is 20 years old and model jet construction has evolved an awful lot since then. In 1998 The Comp Bandit was the absolute top of the tree, aimed at the very best builders and flyers in the Country (all flyers were builders in 1998).
Today, you can buy a Bandit PnP. No glue required .
Keep at it. You will learn so much from building this model, and the end result will be so much more satisfying..
#111
My Feedback: (10)
That looks good,
You are going to need some sort of lightweight bondo type material, like evercoat (catalyzed polyester filler) or some epoxy, I use this:
SUPER FIL from Aircraft Spruce
That Tamiya putty is probably lacquer based, it will be difficult to lay enough of it down for what you will be doing (shrinking, drying, etc.) It is good for pinholes or really small dings but the big stuff you need something that wont shrink. In my opinion
#112
Looks great!!
The inlet/cowl fit step is maybe the toughest part of the build.
+ 1 on the 2 part filler. I use an automotive finishing polyester filler. it is strong and easy to work, but quite heavy. That product Matt recommends looks interesting.
#113
What do you guys think of the fillers from west?
http://www.dreamworksrc.com/catalog/...Systems?page=1
They have a microlight used for filling only, and a low density that is for bonding and filling. Im getting ready to order the Itrap 40ml for this jet though I would throw one of those in the cart.
I also have west epoxy and microballons or milled fiberglass. Is there a reason I need to use a bondo type substance? Typically Ill use spackle on these and hit it with CA or 20min epoxy laminate to fill the pinholes.
#114
My Feedback: (10)
Whatever you think will work, I have never tried thickening epoxy that much, don't see why it would not work.
You have to be able to sand and feather it, that is the key. The edge has to feather into that gel coat you have (I think your kit is so old it still has gel coat and not the grey K-36 primer they used later.
#117
I have never seen the West System fillers before. You guys in North America seem to have access to a lot more products than we do down here. . One reason I like the polyester auto fillers is because it cures very quickly, can be rough cut while green (withing minutes), and is real nice to sand.. I use Taymia filler for pin holes.. It is worth experimenting with fillers. Everyone seems to have a favorite brand and method.
I think your fuse is finished in primer.. My Classic Bandit was..
When are you ordering that Super Bandit Raff ?
#119
My Feedback: (10)
Right over the joint on the inside, maybe 1.5 inches off of the center on either side of the joint. But you have to make the joint flat enough so that you can still get the tanks in. You can always glass it later after you get the inlets in if you are worried about fitting the tanks
#120
For the outside I didnt have too much to fill, thanks to the good advice of using tons of hysol in there. I just tamiya putty for now.
Attached are some pics of the result. I sanded out the 90 degree lip on the inside of the fuse where the cowls mate up. Am I supposed to sand anything else? I got the bottom joint sanded well but not sure how much it needs to be sanded down. I plan to put some thick glass across these joins as far forward into the intake cows as I can get.
#124
Question for the day. When installed, should there be a gap between the inlets and the fuse, or are the inlets supposed to be glued to the side of the fuse? With this gap, there is a small gap on the opposite side with the cowl. If I glue the inlet to the side of the fuse, Ill have to cut an area out of the splitter plate to slide into. Right now the splutter plate will slide in the gap and the cowl has the area cut out for it.
#125
My Feedback: (10)
I am not sure I get your question, but no that gap in the picture should not be there. Test fit the splitter before you do anything else. All you really care about is the fit of the outboard surfaces of the splitter and the inlets. Who care what is going on behind it, you can just shim it.
BTW, I did not glue the splitter on. Easier to take it off for painting.
