Reload this Page >
Mb339s
Mb339s
Old 01-21-2017, 07:53 AM
roydefiant
Default Mb339s
Saw this kit at Jetpower 2016. Really liked the idea of a sport jet modeled after real full size. This picture is from the C&C models Italy web site. I will post more when I start to rig it. Came well packaged in 2 different boxes. In fact the major portion of the fuse was in a complete wooden box. No damage. Came with pipe, wing bags, fuel cell, and electron retracts with trailing edge struts and electric brakes. Highly prefabricated, painted, clear coat, live hinging, all servo mounts already in place. 106 inch wingspan. Seems to be really light, I will weigh components as I start to rig.
Old 01-21-2017, 09:10 AM
jcterrettaz
jcterrettaz's Avatar
I have the 3D version , great machine
Old 01-21-2017, 10:25 AM
DUCMOZ
Thanks for posting. Who sells this?
Behzad
Old 01-21-2017, 11:37 AM
roydefiant
Here is the link
http://www.cmodels.it/modelli_jet/339S.htm
Old 01-23-2017, 02:06 PM
roydefiant
tail weighs 2 lbs 12.5 oz
Old 01-23-2017, 02:16 PM
roydefiant
nose 3 lbs 10.5 oz
Old 02-03-2017, 11:46 AM
roydefiant
wing with retract, strut and wheel weighs 4 lbs 14 oz
canopy 12 oz
fuel cell 11 oz
pipe 1 lb 8 oz
that is 19 lb 4 oz so far without nose gear or carbon fiber wing spar
Old 02-25-2017, 08:31 AM
roydefiant
Canopy is mounted, slides rearward to lock in place. Magnets in front prevent canopy from sliding forward. One magnet inside canopy lip and the other in front fuselage lip. Very secure and nice fit
ID:	2202771   Click image for larger version
ID:	2202772   Click image for larger version
Old 02-27-2017, 02:59 PM
roydefiant
This is the former already installed for mounting the pipe. I have mounted the flanges on the bell housing and can install the pipe that came with the kit
ID:	2203254   Click image for larger version
Old 03-03-2017, 06:33 AM
roydefiant
rudder servo mounted
Old 03-03-2017, 06:09 PM
roydefiant
finished hinging gear doors and mounting servos for gear doors
ID:	2203822   Click image for larger version
Old 03-26-2017, 02:34 PM
roydefiant
all control servos and horns glued in place. Need 3/4 inch servo arm for flaps. The linkage is internal but the flap horns glued in place is shown. The elevator servo used a 1.25 arm going to the control horns
ID:	2207151   Click image for larger version
Old 04-03-2017, 05:54 AM
roydefiant
most of install done
Old 06-04-2017, 07:46 PM
roydefiant
Final weight ready to fly but no fuel 37 1/2 lbs. Maiden soon
Old 06-05-2017, 06:43 AM
roydefiant
Made a mistake. I forgot when I weighed it I had not drained the fuel out after I programmed the ECU and did turbine run-up. Probably about 2 lbs of fuel so I suspect dry weight is probably 35 to 35 1/2 lbs.
Old 07-02-2017, 03:01 AM
roydefiant
Maiden yesterday, 3 flights, flew great, stable flyer, lands slow
https://www.youtube.com/watch?v=3rVY...ature=youtu.be
Old 07-02-2017, 03:03 AM
roydefiant
Had maiden yesterday with beautiful weather. This is a great flying aircraft. Very stable. Lands very slowly with full flap defection. The jet munts 200 performed flawlessly
Old 08-12-2017, 06:09 AM
roydefiant
Default MB339s
more flightsClick image for larger version
