Reload this Page >
New Kingtech ECU Soon to be released!!!
Reply
Old 02-09-2017, 04:55 AM
  #226
wfield0455
My Feedback: (7)
wfield0455's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by VK96 View Post
Is anyone with Jeti having issues during the "Learn RC" process...Particularly in regards to trim inputs? It doesn't seem to recognize my trim inputs and as result won't go any lower than "idle" (no "Trim low"). I've tried binding the RX's on the CB200 with both the stick AND trim down as the manual states, as well as with the trim neutral without any luck. Any help will be greatly appreciated!!
I use Jeti and I'm not having any problems... What are your throttle channels travels (max positive/max negative) settings ? Since Jeti's default travels are closer to +/-125% for Spektrum, JR and Futaba I personally have mine set to +/-80%. I also use the Throttle Cut and Throttle Idle functions, both controlled by opposite positions of the same switch to select idle/kill. As I recall, the kill position will produce a pulse of ~1100us, idle a pulse of ~1300us and full throttle ! 1900us. I have my failsafe set to -125% which give a pulse width of ~800us which is well outside the normal pulse width range so the system can detect loss of signal. If you go into the servo monitor and press the center function key it will display the servo positions is ms (1.1ms, etc) instead of percent so you can see what the transmitter is sending to the ECU on the throttle channel. Your throttle trim setup could possibly be the problem and your max positive limit / max negative limit settings could be part of the problem as well as they are absolute limits and if set the same as the max positive/max negative can
limit trim range, etc. If that is the case, the servo monitor should make that clear.
Good luck getting it sorted out.
wfield0455 is offline
Old 02-09-2017, 08:53 AM
  #227
CraigG
My Feedback: (40)
CraigG's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I ran into similar issues setting up my Jet Central Rhino. Go into your servo setup and set the throttle positive/negative limits and max limits all to 100%. Then look at your Digital Trim menu and make sure the throttle is set to Thro-Low mode. See if that helps.
Craig
CraigG is offline
Old 02-09-2017, 12:59 PM
  #228
VK96
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks guys... made the changes and all is working as it should. I believe the culprit was the "Thro-Low" mode. I swap my digital trims around so I can trim AIL/ELE with my left hand on the lefty hand side of the TX. When making the changes I didn't change the modes. Wayne, I like your idea of the Idle/Kill switch...might use it! BTW where do you fly? I see you're in MA...Chris
VK96 is offline
Old 02-09-2017, 03:14 PM
  #229
wfield0455
My Feedback: (7)
wfield0455's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes,
I'm a member at SSRCC in Brigdewater and I fly my turbines that are suitable for a grass fields there pretty regularly. I use one of the Safety switches for the throttle cut/idle function so I can't accidentally bump it and accidentally kill the turbine in flight. It works really well.
Old 02-09-2017, 05:20 PM
  #230
VK96
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by wfield0455 View Post
Yes,
Cool...I'm up in NH and just joined the Plum Island club. Will keep an eye out if I'm ever down your way!
VK96 is offline
Old 02-10-2017, 06:45 AM
  #231
wfield0455
My Feedback: (7)
wfield0455's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
They seem to have a Jet rally at Plum Island every Spring and I always try to attend so perhaps I'll see you there.
Old 02-10-2017, 08:48 AM
  #232
TimD.
My Feedback: (207)
TimD.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Question? Bought one of the new k60s last year and I am just now getting to it. Tried to start it yesterday with multiple failed start. I am using a 7cell NIMH 3200 pack. It gets to the point where it is starting to light gets up to 46c then gives bad start/ no start/ sad start something to that effect.
Will the 7c nimh not do it ? Do I have to use the life?
TimD. is offline
Old 02-10-2017, 08:52 AM
  #233
mauryr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
NiMh is too last millenium for kerostart.
mauryr is offline
Old 02-10-2017, 08:54 AM
  #234
Digital Pilot
Digital Pilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
9.9 life.....
Digital Pilot is online now
Old 07-06-2017, 06:47 AM
  #235
TPerk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I had a my 120 KT shut down on the runway, thank god I was still on the runway. I was getting ready to take off and I was going to try and use the brakes on full and add 3/4 power and then release the brakes to see how the jet would take off, as I got close to 3/4 power the engine just shut down and did not go in to the cool down mode has any one had this problem, I checked the bubble tank to see if there where and air bubble in the bubble tank, there where none. Does ant one have any idea what could have happened? After I cooled the engine down I restarted it and all seem find I got a 5min flight and all worked well.
TPerk is offline
Old 10-10-2017, 11:58 AM
  #236
stegl
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nimh battery packs don't have the available current for turbine starts. Use Life or lipo as that gives enough amps for a good start.
stegl is offline
Old 10-10-2017, 02:11 PM
  #237
TimD.
My Feedback: (207)
TimD.'s Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yes they work fine. The pump was stuck from factory. Once freed up never had another issue. I have used Nimh on several now.
TimD. is offline
Old 10-11-2017, 01:32 AM
  #238
TPerk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I found out why the K T 120 shut down on the runway. This is my first jet engine and I am still learning about jet engines, that being said, the problem was I did not have the throttle trim all the way up as high as it would go and that caused the shut down. I made a call to Barry at K T and he was able to help me find out why the engine shut down, I must say K T has great tech support. I have had a lot of flights after finding out why I had the shut down and I have no problems with the engine after calling Barry.
Thanks Barry
TPerk is offline
Old 10-11-2017, 07:31 AM
  #239
stegl
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Was this a digital trim radio or one with the older slider trims ? A more positive way would be using a switch like an engine kill switch if setup allows it. On my Jeti I bought a locking switch and have this setup as a positive locking engine kill and works like a hot darn with no chance of accidently switching on or off.
Another reason a turbine may shut down is if the failsafe is triggered due to maybe positioning of the receiver antennas' in the aircraft. 2.4 RF apparently does not go thru liquid mediums like fuel and if the ant whiskers are in a bad spot could be blanked out by the full fuel tank as was discovered at the Princeton Jet Fly last spring in a f104.
stegl is offline
Old 10-12-2017, 02:11 AM
  #240
TPerk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Stegl, thanks for your response. I am using a Hi Tec Aurora 9 radio that das digital trims. The reason I was only running to trim up a little above half trim was because I thought if I had it just above half trim it would be a faster way to shut the engine down should I have a hot or wet start. This is my first jet and I like all new RC Jet Pilots I am learning as I go. Talking with Barry from K T about the problem I learned that the trim needs to be all the way up for the engine to get the proper RF signal from the radio. I have had no problems after talking with Barry and keeping the trim all the way up. I have been trying out using a power up take off, by throttling up to half power with the breaks on full lock and the releasing the breaks and going to full throttle on my roll out for taking off, seems to work great having the engine all ready spooled up to half throttle. I now get a much shorter take off distance. I hope that this is not a bad idea, it seems to work so well.
Thank you
T Perk
TPerk is offline
Old 10-12-2017, 03:37 AM
  #241
Dr Honda
Dr Honda's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Did you look at the data terminal to see if there was an error?
From the description... sounds just like some air in the system, or a loose electrical connection.
Dr Honda is offline
Old 10-12-2017, 08:22 AM
  #242
stegl
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi TPerk
I guess my point was , rather than use trims to start and stop your turbine ; why not use a switch similar to motor cut in a fueled engine ? The results are instantaneous
with no delay in case of an emergency or just regular usage. I guarantee that once you use it you will never go back to using trims. I also use the same switch concept as a kill switch for my electrics as then there is no chance of accidently hitting the throttle.
stegl is offline
Old 10-12-2017, 08:32 AM
  #243
why_fly_high
My Feedback: (19)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi TPerk
I set my throttle trim with only 3 steps. Low, mid, and full. Makes the trim more or less a switch.
why_fly_high is online now
Old 10-12-2017, 09:11 AM
  #244
markusvt
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yup, if your radio allows, set the trim to 3 positions only, not 20 little clicks.
markusvt is online now
Old 10-12-2017, 09:16 AM
  #245
Zeeb
My Feedback: (41)
Zeeb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Not only that, but it leaves the shut down function where others would expect to find it should the need arise. While I admit that I did like the older JR 12X analog slider, the three beeps on the digital trim is a whole bunch better than the "20 little clicks.) !
Zeeb is online now
Old 10-12-2017, 11:01 AM
  #246
BarracudaHockey
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I set my trim step as coarse as I could on my DX-18, only takes a few clicks to go from low to high now.
And a friendly reminder, if you mess with it, re-do the radio learning sequence.
BarracudaHockey is online now
Old 10-12-2017, 04:01 PM
  #247
gunradd
My Feedback: (9)
gunradd's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Mine is one click up or down that's it.
gunradd is offline
Old 10-12-2017, 04:37 PM
  #248
Zeeb
My Feedback: (41)
Zeeb's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Bragger..... or no wait, got it on a switch instead?
Zeeb is online now
Old 10-13-2017, 01:26 AM
  #249
TPerk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by Dr Honda View Post
Did you look at the data terminal to see if there was an error? Yes I did and there where no errors.
I also had checked to see if the there was air in the line, there was no air, it was just the trim setting.
TPerk is offline
Old 10-13-2017, 02:13 AM
  #250
TPerk
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thank you all for the great idea. This is what I did after Barry and I checked for errors in the data terminal and found that there where no errors and he helped me find what went wrong and what went wrong was, that I did not have the trim up all the way. I set up my throttle trim steps so that only a few trim steps it goes from low to high very quickly, just like one of you guys had subjected. Oh by the way using the throttle trim on this radio to turn on the start and stop, and using a faster trim setting set up, is better because after the throttle stick is above raised above 1/3 of the of the throw on the throttle stick, the trim can't be changed by accidently hitting the trim button.
TPerk is offline
