HSD Foam Turbine Jets
Reply
Old 07-07-2016, 06:10 AM
  #51
Vincent
Vincent's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
Originally Posted by sidgates View Post
I have another friend who is very interested in your F-16 package and also want to see yours fly and get feed back on the engine. 2 of the 3 are retired so our time is very flexible.
I got your email Sid and like I said my F-16 is on the way to Az so it wont be long now
Vin...
Vincent is offline
Old 07-07-2016, 07:25 PM
  #52
Eddie P
Eddie P's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The video was good to see, it really shows how usable the feature is provided it doesn't happen 10 feet off the deck. Sorry to ask if it's already been asked - but are you running kerosene or deisel in these engines? What oil? Did you confirm your flameout issues were related only to the "too aggressive" acceleration schedule or was there something else going on that you were able to pin point and eliminate?
I've only had two flameouts in a turbine engine and it was a P-60SE early model that I had set for too aggressive of an acceleration schedule at 8500' density altitude. And both happened on the ground the same day during testing to see how the engine was acting before takeoff on this hot and high altitude day (that setting worked fine at sea level btw). After dialing the acceleration schedule back a bit it ran fine at 8500' DA too. A ground test will reveal this sort of failure mode with slam idle to full power thrust tests and rapid idle back tests. Too fast of an idle spool down schedule can also create this failure mode so deceleration is also a player in what I've learned.
Eddie P is offline
Old 07-08-2016, 12:43 PM
  #53
cmp3cantrj
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
Originally Posted by Eddie P View Post
I guess I'll have to see this auto start feature before I put too much stock into what it can do.
Jets Munt have this feature already. You can see a demo here:
https://www.youtube.com/watch?v=yPoRI5S1biY
cmp3cantrj is offline
Old 07-08-2016, 05:23 PM
  #54
TTRotary
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
Originally Posted by Henke Torphammar View Post
They are on youtube with K80 too.... I would do it the other way around going smaller. K45/Wren 50 if you are not in to Kolibri. P60 is heavy for the power
Agree. 45-50N plenty for this foam bird. Keep-em light and they will fly better and last longer.
TTRotary is offline
Old 07-08-2016, 05:24 PM
  #55
mikedenilin
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I slowed down the throttle accelerations and solved the problems. This engines originally setting were for diesel and I use Jet A on all my jets. The throttle response is fast enough. About 3 sec from idle to full throttle.
Mike.
mikedenilin is offline
Old 07-15-2016, 01:46 PM
  #56
bell801
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Im new to the EDF world and looking for some help please. I bought the freewing SU-35 fet. Im having issues with the esc. When I bind my spektrum dx8 to my ar6210 every thing works. Retracts, all control surfaces etc. But I can not get the esc to engage the motor, I have tried revising throttle in servo setup. tried throttle trim down all the way. Tried throttle up then quickly bringing stick back to bottom. Im lost and thinking its my esc. Unless there is another trick I'm not trying, Please if you know anything help me.
bell801 is offline
Old 07-31-2016, 04:56 AM
  #57
Mike06659
Mike06659's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've got 9 flights on the SV V1 now and really like the flight envelope. You can really slow it down on landings which makes for a nice nose-up landing. I think you guys will enjoy this bird!
Mike
Mike06659 is offline
Old 09-09-2016, 04:59 PM
  #58
Skymac
Skymac's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Where's everyone running the CG at on the F16, trying to help a friend get his dialed in with a K60 and it loves to just stand on the tail and get pitch happy when slow. Unlike every 16 I've ever put my hands on.
Skymac is offline
Old 09-09-2016, 05:05 PM
  #59
arizcowboy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
185-200 just test flew with 185 no problems
arizcowboy is offline
Old 09-09-2016, 07:34 PM
  #60
miosorio
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi!! Im new in this forum, but I looked for it because Im urged about help. I got my first turbine rc jet, a Super Viper for turbine version. I have looked for a guide set up manual of this plane (the one I could find is for EDF version), but didnt find anything! I looked for a video, I only coul find just one that covers a general overlook but lack of details.
Please if some of you have the experience and knowledge to assist me in the set up process, I will be very grateful!! Where may I find how the control board inside works???
Thanks.
miosorio is offline
Old 09-09-2016, 08:48 PM
  #61
bri6672
bri6672's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
Terry is on it!!
bri6672 is offline
Old 09-10-2016, 12:29 AM
  #62
arizcowboy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks.
Where are you located ???terry
Old 09-10-2016, 12:32 AM
  #63
arizcowboy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Old 09-23-2017, 06:14 PM
  #64
Kim Couturier
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I know this thread is over a year old, but I have a question I can't find an answer to. I have a guy whose trying to trade me an HSD turbofoam viper. He says it's an early model , and the turbine access door is on the bottom of the fuse. Everything seems to be there for turbine use, but, for example, the turbine/pipe mounting brackets have a bunch of glue on them...not a factory looking install. The only vipers I've seen with the hatch on the bottom, are the edf'. Has anybody seen a turbine ready model of this jet with the door on the bottom? Or, could it be an edf that someone tried to convert to turbine use?.
Kim Couturier is offline
Old 09-23-2017, 06:21 PM
  #65
Mike06659
Mike06659's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Every "turbine" Super Viper I have seen the hatch is on the top. I own the very first V1 Super Viper and the hatch is on the top. I think you are seeing a turbine conversion. Any of the other guys in this thread disagree?
Old 09-23-2017, 06:32 PM
  #66
arizcowboy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
I tend to agree the first ones global had , we had turbine hatch on top and the pipe was held in by mounting tabs on pipe to turbine mounting wood rails . Terry
Old 09-23-2017, 07:14 PM
  #67
Desert Fox 1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default HSD Super Viper Jets
+1 I'm with Mike06659
Cheers!
Desert Fox 1
Desert Fox 1 is online now
Old 09-23-2017, 07:29 PM
  #68
Mike06659
Mike06659's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Another thing to consider are the servos. My V1 version had crap servos and hardware which I replaced. You can get a really good deal on a V3 Super Viper with all the upgrades if you look around. It will save you a lot of time and you will have a far better airframe. Just a thought.
Mike
Old 09-23-2017, 09:18 PM
  #69
Kim Couturier
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for all the info! Think I'll get a version 3. Anyone interested in an F-16 in Arctic camo? Asking 850 or will trade for a viper.
Reply
Display Modes
