Fuel-Soaked Electronics Post Crash?
Hey, Guys
What's everyone's SOP for dealing with fuel-soaked electronics (servos, ECU, rx) after a crash? Brand new 12-ch Powersafe and all satellites were soaked (but still on and lit up when the wreckage was found). K-80 got banged up pretty good, too
My Feedback: (24)
Open them up (probably not servos, though; they are pretty "liquid resistant", good electronics cleaner, like LPS I think? - spray clean and let dry, wiping wherever possible with a lint-free cloth. Need to get the turbine oil off - the usual soak it n a bag of uncooked rice thing won't work here.
Good luck - this isn't ever filled with confidence.
My Feedback: (24)
I would disassemble them and clean thoroughly with Denatured Alcohol or use an ultrasonic cleaner for electronics if you have access to one. Then let them dry out completely, reassemble, and give them a reliability test of an hour or so. If they are working at that point, they should be good to go again.
Bob
I got my iGyro3e soaked in crash. Gave it a good dose of electric cleaner but I have not tried to fire it up and I think I will not have guts to try it out without sending it in for checking to Powerbox. Would be quite a feeling to crash a plane due bad gyro..
CA
Clean with alcohol as said here. Some of the chips are wire bond which may not fair well under high impact loads. Especially the cheaper ICs (intentional since its less cost that the other high perf package technologies which would be overkill). So for reuse you must also tap and check for any issues/glitches etc. This can also help expose board problems if say a trace is broken.
Me, I wouldn't use them again in a jet. Maybe okay in a small sport plane though.
My Feedback: (13)
Shaun,
Unfortunately, I've had a few crashes. I send all the electronics back to Horizon and have them clean up what they can and replace what they can't.
Now I'm using Jeti radio equipment and still use JR servos. The Jeti stuff would go to Esprit and the JR back to JR.
What other have said here sounds all fine to me, but, for piece of mind, I'd send it back.
Jim
Jim
Recycle, the fuel can be pretty corrosive to electronics. It's bad mainly in high humidity environments. Jeti offers 50% replacement warranty, maybe HH has something as well.
What happened? Any telemetry data left?
Zb/Jeti USA
Zb/Jeti USA
