Jr Dmss Telemetry with Turbines??
I've been told that the similarity to the Hott system that I would get the same telemetry as those systems. So does anyone have experience with Telemetry to Dmss ? I'm really looking at two brands specifically Jet Central and King tech. Really open to be able to see start up temps and fuel consumption.
My Feedback: (7)
I have no idea if telemetry for JR DMSS is even remotely similar to Hott but Xicoy sells telemetry units and their Flight Computer which will work with Kingtech turbines. They list Hott in the list of supported systems but then also say support for JR will be added to a future firmware update. I would send them an email and ask them if their units will work with a JR DMSS system before purchasing anything.
Mine just arrived today and it is a unit made by Electrospeed exclusively for Macgregor in UK, (our JR distributors) it is not a JR product but is designed to work on JR DMSS with JetCat ECUs.
A whole host of data can be returned to the transmitter which will need to be configured with a suitable widget. One of the many advantages of the system is that it can be configured to trigger alarms for example, flameout, and it can dispense with the GSU for monitoring startup.
I will experiment with the system and write it up for RCJI with some other very useful devices from PowerBox.
I understand that in future it may be available for at least one other popular ECU.
The UK price is 37 pounds so at the current US exchange rate it is extremely good value and if you have aJR DMSS controlling a JetCat it will be an (almost) essential item.
David Gladwin.
(and the more I use my 28x with DMSS and X-bus the more I like it !)
David Gladwin.
Currently the support of JR radios is very poor, and his customer support (technical questions) not better. The parameters transmitted by the simple telemetry adapter are RPM, EGT, ecu battery voltage and remaining fuel, the Flight computer adds height and Airspeed. You can see an video here: https://www.youtube.com/watch?v=XdrV18-v2Ls&feature=youtu.be.
To monitor the engine startup I would recommend the Bluetooth module, you will have all the info of the data terminal including buttons operation on your phone.
Gaspar
Gaspar
Gaspar
Gaspar
I have the ECU that is pictured in the link I have provided: http://www.troybuiltmodels.com/ns/im...s/k-80e_03.jpg
Will your telemetry module work with that ECU and a Futaba 18MZ?
Patrick
Gaspar
Gaspar
Hello Patrick,
If you have this ecu (out of producion since 2010) then the only possibility to have telemetry is our Flight Computer, the simple telemetry adapter nor the Bluetooth adapter would work with this ecu. Same applies with JetCat ecus.
Another posibility is to upgrade the ecu.
Gaspar
Gaspar
