Cordless air pumps for air retracts?
My air pump using an old nicad battery died lately. I am looking for a good replacement for my jets.
What do you guys use now that:
1) Uses a rechargeable lipo for power
2) Is compact and light
3) Works great for you
4) Provides fast fill up at the pressure range we need?
5) Not a put it together taping bits and pieces from the part bin type of gizmo.
My Feedback: (50)
My Feedback: (39)
This unit is my favourite set-up. I power it with a 3s3200 Lipo that I strapped on with Velcro. Made an adapter for the hose and cut the led "power" indicator so it doesn't drain the battery.
its fast, quiet and easy to carry, handle, etc.
https://www.amazon.com/VIAIR-85P-Por...ords=viair+85p
paulD
paulD
Thanks guys based on this thread and others I will go for the Craftsman air pump it seems like the easiest and more reliable set up.
I wonder why they do not sell them as a kit with battery and charger, being a Makita guy I will have to buy charger and battery too.
One question. Most of the air pumps need an adapter from the end made for tire inflation to the small hose we need. How do you do it?
And
<Only fools do not change their minds> I will be going for a Ryobi unit which is similar to the Craftsman since I already have a battery for it from my edge cutter. I guess only fools do not change teir mind set
And
Perfect that is what I have been using but I never thought of cutting the tip off, I just fitted the hose over it using the preexisting holes. Cutting it short will probably make it more long lasting as it tended to brake at its base easily.
That sounds even better. Can you post a link to the valve you are using? Does it fit in the tire end of the hose?
My Feedback: (7)
Basically one of these to connect to the air compressor and one in the airplane..
http://robart.com/collections/air-sy...lve-fill-chuck
Thanks Wayne, nice to know they will fit the same as the football needle AND won't break as easily.
By the way I went to homedepot and saw this from Ryobi:
https://www.homedepot.ca/en/home/p.1...001002835.html
which I will use instead of the Craftsman. Identical but for the fact that I already have a battery for it from my edge cutter.
Thanks again all for the help.
I have been using one of the original Ryobi cordless inflators since 2006. I replaced the batteries with 10 x 3300mah Nimh ones in 2007. I simply charge the pack directly onto the contact points of the battery pack. When the current battery setup no longer last for the 15 to 20 fills I need over a normal weekend, then I will put a 4 cell Lefe pack inside the battery pack casing - and hopefully get another 10 years out of it.
As for the tubing connection; I found that Clippard mini threaded barb nipple connectors had the same thread and was the same size as the original pump fitting - so I simply replaced it (directly onto the pump, without the hose) with such a fitting. This allowed me to use our common airline tubing for the purpose and adding whatever I needed on the plane end. In order to prevent the tubing slipping off after extended use (it has been on there for 10 years now) I lock wired it in place. To stop the tubing breaking from continuous bending directly after the nipple I slipped some tight fitting silicone fuel tubing over the airline which was then pushed over the lock wired setup and left about 50mm (2") longer after the fitting.
Cheers,
Jan
Cheers,
Jan
Thanks SF. I am not familiar with the Clippard connection you mentioned but will have look at the thread match with what I have. Getting rid off the big black original tube is a good idea if possible.
My Feedback: (7)
No necessarily. My local Sear hardware store had the Craftsman version on sale for $20 recently. Home Depot had the Ryobi on sale for a similar price at the time. In both cases they are the compressor only with no battery or charger. Ryobi offers package deals with an additional tool plus battery and charger for about $100 and when I got mine I got a nice drill, battery, charger and compressor for $115. It's all a matter of being in the right place at the right time or what other tools you may already have on hand that you can share battery packs with..
Off the shelf units almost always suffer from the following:
1) LIpo protection circuit is built into the battery - forcing you to use their own brand batteries - which are rarely anywhere near the quality of what you get from a model supplier.
2) LIpo protection circuit is built into the battery - forcing you to use their own charger/ power supply - which are rarely anywhere near the quality of what you get from a model supplier - and does not give the level of information about the state of the battery that you get from the charger you probably already have.
3) LIpo protection circuit is built into the battery - forcing you to use their own brand batteries and power supply/charger. If the company goes out of business or simply changes supplier then replacements will become unavailable. This recently happened to me with a lithium batteried drill I bought from Maplin - the charger died and the guy in the shop said - sorry we don't do that one anymore and we don't have a suitable power supply available - try the internet!
If you do get a new one then a big brand is essential to ensure support is available - Ryobi is probably the best choice esp. if you already have bought into their system.
However I would check out the voltage of your old NiCd powered unit, solder a Deans plug (or whatever you use) to the contacts and plug in a suitable voltage lipo (about 2500 mahr - 4000mahr will last many sessions).
Attach it to the pump will 3M dual lock "super Velcro" and away you go.
