Reload this Page >
All new Merlin M70XMBL
Old 09-13-2016, 04:58 AM
Jgwright
Default All new Merlin M70XMBL
http://www.jetsmunt.com/wp/m70xbl/
Jets Munt have announced the new M70 XBL and will be showing it at JetPower for those lucky enough to be there.
This engine is 70N thrust out of a case size 75mm dia and weight of only 600 grams
This is all with Brushless starter motor and brushless pump.
The overall size is slightly smaller than the Wren 44 and less weight but produces all that power!
Yet again Gaspar produces something truly exceptional. I have put my name down for one!
John
Old 09-13-2016, 05:47 AM
marc s
marc s's Avatar
Interesting to read its fully programmable in thrust output so the users can dial in what they want - 30-70N
marcs
Old 09-13-2016, 05:55 AM
Grodus
Wow, 100g lighter than the K45 and 60% more thrust. I want one!
Old 09-13-2016, 09:17 AM
Henke Torphammar
Henke Torphammar's Avatar
marcs
Well, that's been doable for long, if not by rpm limit via the throttle stick
How ever this is one of few engines that impress me with a huge leap from the competition. Been waiting for this a long time as the Wren 44 been the standard for too long in this can size.
Old 09-13-2016, 09:57 AM
mr_matt
My Feedback: (10)
mr_matt's Avatar
Is this the one that was initially presented (shown at shows) as a 45 N motor?
Old 09-13-2016, 10:04 AM
Jgwright
No this is entirely new. The M35 has not yet made it into prduction.
John
Old 09-13-2016, 11:12 AM
Jannica
Impressive specs! What about the price?
Old 09-13-2016, 02:44 PM
DrScoles
My Feedback: (18)
DrScoles's Avatar
1600 euro, Very very cool! dial a turbine... I like it!
Old 09-13-2016, 02:55 PM
DUCMOZ
Thank you for sharing the information. these would make a perfect power plant for Small Skymaster A10. Exciting stuff.
Behzad
Old 09-13-2016, 03:29 PM
mr_matt
My Feedback: (10)
mr_matt's Avatar
Can anyone tell me what the typical tail pipe exit diameter would be for this turbine at full power?
Inner pipe diameter I mean
Old 09-13-2016, 03:32 PM
DUCMOZ
I assume it would be like P60 or P70 as it pushes the same amount of air to generate the trust.
Behzad
Old 09-13-2016, 03:36 PM
mr_matt
My Feedback: (10)
mr_matt's Avatar
Yes what might that be? I have never had a full bypass install with a turbine that small
Old 09-13-2016, 04:02 PM
rhklenke
My Feedback: (24)
rhklenke's Avatar
Behzad
My guess is that the efflux velocity is much higher for the Merlin than a P60 or P70 and that's where it gets its thrust.
Bob
Old 09-13-2016, 11:46 PM
Henke Torphammar
I run a 46mm pipe on my Kolibri T50. That adds 0.5lb or push when testing static.(54N installed) Usually people uses too big pipes, such as 46mm for a P20.
Old 09-14-2016, 06:08 PM
roger.alli
roger.alli's Avatar
Man I wish I still owned my Aggressor. What a combo these would make ..
ID:	2181139   Click image for larger version
Old 09-14-2016, 06:34 PM
mr_matt
My Feedback: (10)
mr_matt's Avatar
So Henke you would run a 46 mm ID pipe at full power with this motor? What kind of bellmouth? (No bypass this time).
Does this turbine have the in-flight restart?
Old 09-15-2016, 04:45 AM
Gordon W
Gordon W's Avatar
Wren produce a series of nice pipes. Would the Wren 44 Gold pipe be OK, or should one go for the MW54/70/80/SS/100 size pipe for the M70XBL?
There's a dimensioned diagram on Wren's website which everyone can download as a .pdf (link: https://drive.google.com/file/d/0B4u...NDdVA1MmM/view ) and which I'm copying here as a low definition jpg for a quick look:
Maybe John Wright, who I understand had a hand in the design of these pipes, could advise us, please. In any case, you have the engine on order John, so what will you do for a pipe?
Gordon
Name:	Wren Tailpipe Dimensions.JPG
Old 09-15-2016, 06:32 AM
Jgwright
Gordon
Gordon
I will make my own pipe as I have the materials and a spot welder. I will probably opt for a size between the 44 and 54 maybe 65mm diameter instead of the 62mm and the rest sized accordingly.
I am sure it would work fine with a 54 pipe but the 44 one may be a bit small.
John
Old 09-15-2016, 07:52 AM
Gordon W
Gordon W's Avatar
Thanks John. It'd be handy if Jets Munt could give us all some advice too, or maybe that'll be in the engine manual.
Gordon
Old 09-16-2016, 11:25 AM
cmp3cantrj
John
Price looks quite good too - but would have been REALLY good but for that wretched referendum!
Old 09-16-2016, 01:13 PM
jason
jason's Avatar
That would make a nice turboprop...
Old 09-17-2016, 07:00 AM
patrnflyr
My Feedback: (7)
patrnflyr's Avatar
Will Ultimate Jets carry this turbine in the USA?
Old 09-17-2016, 07:48 AM
DUCMOZ
Probably will be Dreamworks.
Old 09-17-2016, 09:11 AM
Midas D.
http://www.znline.com/produits.php?l...ata=1420455590
This would be the ideaal match
Old 09-17-2016, 11:27 AM
J.F
Time to dig my Grummania Su27 out of the roof, would be incredible with one of these fitted. I think Vaclav at Savex will also become busy with his L39 sales!!
