All New KingTech EPO Jets, by HSD
#251
question guys what do you think about the UAT the new one with v3, i am a bit paranoic, this is my first turbine jet, and i wish never have a flame out taking off, y plan to install the k60 on the plane, and test it, not on a bench, i plan to keep it simple, but i freaking about bubbles, i have not installa anything yet, hope i make all clean and fuel can pass to the turbine with out problems, i will install an eagle tree guardian gyro only for saefty reason on the landind aproach and as i have all my planes with gyrosi will fell like naked with one out of my viper,
#252
I have not heard of anyone having problems with the factory UAT. I'm using the factory one in my F-16 as well. Wire tie all your connections to help prevent any issues at the connection points.
#253
As Digital Pilot says... just wire tie all connections and make sure the fill plug is all the way in and sealed properly.,, I've had 13 flights since last week and all have been enjoyable...
#256
I put another 5 flights on the F16 yesterday. 10 flights total now and its dialed in. Its a great little jet and a blast to fly. I really rang it out yesterday doing heavy maneuvers and slow hi alpha flights.
Got my pilot installed as well.....
#258
well i have almost 20 flights on my viper, never got a flameout, or turbine problems, this kingtech are great engines, i have set 65% expo on the elevator to smooth things out, i fly almost 80 % at max, and get like 150ml on the tank , flying 5 min, the stock smoke pump its awsome, like you can see in the video this jet can handle big g forces, i have push it really hard and the the only thing i see fluttering are the wing on the dives, hope do not get some problems in the future.
https://www.youtube.com/watch?v=VFu5AwBbEt8&feature=youtu.be
#260
Hi guys,
Seeing as I (Dirk) cannot be at Florida Jets this year(Barry will be there), as I know many of you also can't be there. We, thought we would pass on a SPECIAL SALE for everyone. We will not have inventory at the event but, WE ARE OFFERING FREE SHIPPING and AN ADDITIONAL $150.00 OFF ANY HSD JET IN STOCK!! This price is for IN STOCK UNITS ONLY!! Take advantage of this sale while you can. Go to www.pacificrcjets.com to place your order NOW while supplies last!! FREE SHIPPING IN CONTINENTAL US ONLY!! If you are attending Florida Jets, Stop by the KingTech tent and say Hi to Barry.
Good Flying,
Dirk
Pacific RC Jets
[email protected]
626-808-6122
Good Flying,
Dirk
Pacific RC Jets
[email protected]
626-808-6122
#262
Weekend fun.. This Little F-16 is a blast to fly! High AOA flight is easy and predictable. I really threw it around this weekend and it never skipped a beat.
Thanks again to Dirk and Barry @ www.pacificrcjets.com
#264
I fly mine off a 300 ft paved runway regularly and have no problems; often landing and coming to a complete stop before the taxiway at center. I use an IAS telemetry sensor and find that the sweet spot for approach speed is 55 - 60 km/h. A little bit of crow mixing helps a lot.
#265
Looking at picking one of these up and am wondering what is the best route transitioning from an FMS 1700 F4U corsair to one of these bad boys. Never flown edf only prop planes. Love the look and hopefully will eventually get me to my dream jet, F18C in time.
#266
The Super Viper is a great flying jet that goes where you point it and lands relatively slow. If you're going EDF and are proficient with your Corsair it should be a fine transition. If you want to go turbine you should find an experienced turbine pilot to help.
I recently got the F- 16 and after extensively modifying it I just maidened her last weekend. Not the best of flights; I didn't like the way it handled, but a successful landing. Some tuning will be needed
#267
As said, The Super Viper is a great flying jet. The K60 Package is very strait forward and would make for a good starter jet. If you build an EDF version of it the cost for a proper performance fan, ESC and Lipos will cost almost the same as the Turbine version.
#268
No edf. I read the turbine thread which suggests to go with turbine if that is what your goal is as the edf and turbine respond differently. Yea talked to a few people and they recommend the epo Viper to use as a decent trainer for turbine jets. Thank you guys for your input.
I only mentioned the edf because I thought that is what you needed to do in order to move on to the turbine's. But in light of the turbine thread.... I will be picking one of these up to buddy box with at my local field.
#269
hi hope someone can help me installed my turbine with put problems i
have tested 3 times on a bench the maiden flight and another one with
out problems, after 2 month with out flying, i want to star the
turbine and did not start, it stays on stage 1, can someone tell me
whats the problem, i know its under warranty, so what can i do?
video before the problem when it was running correct.
video of problems the turbine do not raise pw and not go to stage 2:
#270
Good day Sir.
I would first make sure there is no restrictions and or problems with the fuel system. Unplug the fuel line from the engine and place it in a cup, run fuel pump test to see if fuel flows.
If that dosent work than give Dirk @ Kingtech a call.
#271
i have make that and the fuel flows perfect, but just the turbine stays on stage 1 and the pw dont move.
#274
Hi Guy's,
I was wondering, does any one fly's the F-16 with the K45? (off grass??) How does it fly with the K45, to me it kinda looks underpowered.....
I'm considering buying one, but the point is, i don't want to invest in a K60 for the simple reason, what to do with a K60 after the Foamy is "in heaven".........
Cheers,
Ed
Cheers,
Ed
