Skymaster F4 First flights
OK was flying and having a blast. When I asked my caller. Did I just loose a gear door. Came by on knifedge and said nope all doors there. Made a nice landing and hit the chute door and no chute. Then I realizes OK it was the chute and not a gear door. I have it attached with 5lb test fishing line. Perfect test to leave the plane if deployed during flight but strong enough to hold chute on landing
My Feedback: (21)
Yessir, I didn't add or subtract any ballast. The CG is larger than advertised. I recommend start at 300mm and adjust to your preference. Steve S ( I think that's his RCU name ) flies well aft of that if I remember correctly. Andy. Andrews and Dantlly ( dubd ) also have significant experience. Perhaps give them a jingle also.
Just be be sure to have solid mounting of pylons to wing.....it will scare the crap out of you when one of those tanks flies off inflight.
