Reload this Page >
Considering a Jeti DC/DS-24. Powerbox SRS compatible?
Reply
Old 03-18-2018, 06:07 AM
ZB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Originally Posted by marksp View Post
After physically connecting and setting up Rx, the following PowerBox data can be displayed on DS-24:
- 2x Battery voltage
- 2x Battery capacity
- Lost frames/ Fades / Holds
- GPS 3D speed
- GPS height
- GPS distance
- GPS trip
- GPS coordinates
Are you sure you get used battery capacity? I know PB is missing Amp or mah used.
The max 16 channels and not having Device Explorer makes the system slightly clunky.
I can assign channels, setup my failsafes, assign my telemetry directly using transmitter, with PB none of this is possible.
Zb/Jeti USA
ZB is offline
Old 03-18-2018, 03:07 PM
marksp
My Feedback: (9)
marksp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Zb/Jeti USA
To be more specific with regards to battery, on the PowerBox side you setup up battery chemistry and capacity. After which, the Powerbox both displays and transmits (telemetry) the current battery capacity. So it does not show 'used', but does show how much capacity is remaining, which for me is actually more useful. [Do I have enough capacity for another flight?]
The "assignment" of PowerBox telemetry attributes mentioned above is exactly the same as Jeti native telemetry. On the DS-24, select 'Timers/Sensors', 'Displayed Telemetry', there you will see PowerBox supported list - done. Of course, this is after physically connecting the PowerBox TELE port to the ext port on Rx2 via a male:male servo exstension.
marksp is offline
Old 11-12-2018, 08:31 AM
Tip22v
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I just bought a DS24 and I would like to use it with the Powerbox Mercury units I already have installed in my jets or with the CBM200 power distribution from Jeti. Can someone confirm what Jeti receivers I should buy for the satelites? I'm not sure if I should buy the R3/RSW or something else. Thanks for the help. -Tom
Tip22v is offline
Old 11-12-2018, 08:53 AM
marksp
My Feedback: (9)
marksp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Assuming Mercury setup same as Royal, I’m using (2) Jeti Duplex EX R3 REX receivers connected to Rx1 & Rx2 ports, with one also connected to ‘TELE’ port for telemetry. I decided using (2) 2.4GHz was better that (1) 2.4GHz and (1) 900MHz.
Cheers
marksp is offline
Old 11-12-2018, 09:27 AM
Blancr
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Assuming Mercury setup same as Royal, Im using (2) Jeti Duplex EX R3 REX receivers connected to Rx1 & Rx2 ports, with one also connected to TELE port for telemetry. I decided using (2) 2.4GHz was better that (1) 2.4GHz and (1) 900MHz.
Cheers
+1
Go here for full set up info: - Schematic, Royal SRS+Jeti - Royal SRS / Champion SRS - PowerBox-Systems | Support-Forum
Software for Jeti must be 3.24 and use UDI
Bob
Blancr is offline
Old 12-03-2018, 09:08 PM
  #31
Tip22v
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cheers
I've got two R3/RSW receivers connected to a PB Mecury SRS, I can see the telemetry data from both the receivers and the Mercury, but I cannot get any servos to respond? I tried changing the Servo Inputs on the Mecury but still no luck, any ideas? Thanks for the help, Tom
Tip22v is offline
Old 12-04-2018, 10:03 AM
  #32
ZB
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You need to switch both RXs to UDI 12 or UDI 16, the R3 receivers need different firmware for UDI 16
Zb/Jeti USA
UPDATE 3.24
Download Firmware UDI 16 R3/RSW-18US 3.24 (June, 2015)
Jeti Firmware Updates
ZB is offline
Old 12-04-2018, 11:43 AM
  #33
bluelevel
My Feedback: (37)
bluelevel's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If that also doesn't help, you have to run the setup assistant of the Mercury first and complete all steps. Otherwise there will be NO OUTPUT to the servos
bluelevel is offline
Old 12-04-2018, 08:06 PM
  #34
marksp
My Feedback: (9)
marksp's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If I recall, here are the steps i followed:
1. Update Rx’s using Jeti Studio
2. Bind and configure Rx’s for UDI protocol using Device Manager
3. Configure Powerbox with PB display
4. Connect Rx’s to Powerbox
specific settings, versions and connections in this thread
marksp is offline
Old 12-06-2018, 07:53 AM
  #35
Tip22v
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Running the Setup Assistant did the trick, thanks!
Tip22v is offline
Old 12-11-2018, 07:05 PM
  #36
Tip22v
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Update: After some testing I found that the R3 receivers will work with a Powerbox Mercury SRS on the current receiver firmware, however you will be limited to 12 channels. If you need more than 12 channels (as I do) then you will need to reflash your R3 receivers to version 3.24UDI16, once I reflashed the R3s I was able to access 16 channels on my Mercury SRS.
Tip22v is offline
Old 01-02-2019, 10:50 AM
  #37
Tip22v
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
So I have my Mercury SRS working with Jeti and have three flights so far. I have the PB GPS unit and I am able to get airspeed via telemetry back to my DS-24, however I am not able to get Lat/Long coordinates, even though they are selectable under the telemetry options of the Mercury. Does anyone have any ideas? Thanks, Tom.
Tip22v is offline
Old 01-18-2019, 04:43 AM
  #38
mhpverheggen
My Feedback: (22)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hey Guys,
Question about changing the gyro parameters. I'm reading a lot of good reviews on the powerbox units. I'm using the Cortex pro and I really enjoy changing the gyro parameters directly via my DS-24. Is that available on the powerbox gyro units also?
mhpverheggen is online now
Old 01-18-2019, 06:16 AM
  #39
F1 Rocket
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Only the Jeti Assist and BavarianDemon Cortex systems are supported by Jeti with Device Explorer integration. Powerbox have their own radio system now and are direct competitors. This pretty much garranties Jeti will never support Powerbox products.
Danny
F1 Rocket is online now
Old 01-18-2019, 06:20 AM
  #40
mhpverheggen
My Feedback: (22)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Ah I see. Thanks
Old 01-25-2019, 10:54 AM
  #41
Tip22v
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anyone using an MFlow sensor with a Mercury SRS? Because the Mercury SRS requires the Jeti receivers be in UDI mode (verses EX mode) the MFlow sensor does not appear in the Device Explorer. So, connected the MFlow sensor to another Jeti REX receiver so I could configure it using my DS-24, which worked fine, then after finished configuring the MFlow sensor I reconnected back to my Mercury setup. Everything seems to be working, I'm getting MFlow telemetry data on my DS-24. The one thing I could not do (via the Device Explorer) is set the Alarm for low fuel, according to the instruction book it looks like you can only set the Alarms if you use a JetiBox? It seems odd that you configure everything in the Device Explorer except the Alarm? Thanks for the help, Tom
Tip22v is offline
Old 01-25-2019, 01:44 PM
  #42
Dansy
My Feedback: (53)
Dansy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'm surprise that it work....mind you i'm using Mflow2 only and they required ExBus...
Dansy is online now
Old 01-25-2019, 02:35 PM
  #43
Tip22v
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I believe it only requires EX bus to appear in the device explorer. Im using UDI and the telemetry does display on my DS-24.
Tip22v is offline
