Skymaster T-33 Build
Progress has been slower on the front end of the fuse- there are a lot of complex panels to do and I haven't been home to do them. Also, apparently there are far fewer rivets there than on the rest of the plane.
Total rivets: 23,793
#32
I finished up the tail and tanks in the last week.
Total Rivets: 32,376 - I still have to do the small gear doors and aileron covers, but this is a much larger number than I would've guessed before starting out.
Next up is sanding everything, followed by a good cleaning and paint
#36
I've been sanding the last few days, and still have a lot more to go. Although it takes a lot of time/effort, it's pretty incredible what a difference it makes! Pictures are: 1) Flite Metal as applied- not sanded, 2) sanded with Scotch Brite pad- brings out an "orange peel" effect from the glue backing, 3) 320 grit sandpaper- starting to remove the orange peel, 4) 400 grit sandpaper- bringing out a nice shine. The surface needs to be cleaned really well before painting, and will be polished when everything else is finished to stop (slow) the oxidation
#38
Sanding the flite metal took a long time, but I finally got it finished. All the 3D panels on the plane were sanded the opposite direction so they stand out more.
Paint booth is booked for this week, so I should get it painted soon!
#43
