Reload this Page >
Jetlegend/BVM 1:5 F16 PNP
Old 03-10-2017, 06:37 PM
  #51
heraldoboldrin
Guys,, where are you installed the batteries to get a nice CG without extra weight?
Old 03-10-2017, 11:41 PM
  #52
jeff sewell
Mine are fixed to the former that supports the nose cone. The ECU pack is on the equipment tray just behind. I have no ballast...
Jeff
Old 03-11-2017, 02:27 AM
  #53
Mark Vandervelden
Mark Vandervelden's Avatar
I have put my Rx packs just a little further back than Jeff, they sit behind the front former were the removable nose cone finishes and are just inside the fus its self.
My F16,s ECU pack also sits in the same as place as Jeff,s ie along side the turbine and with both the pump and ECU in the same position but on the opposite side.
I have experimented with placing ECU packs up front on several different arframes in the past and often find that with these bigger bigger airframes the extra HD wiring needed out weighs the pack itself. In this F16 it would also have given me too far forward a CG.
Both Jeff and my self are using the Jeti 5200 Lion packs for both Rx and ECU
weighing in at 195g each.
Again like Jeffs F16 I needed no nose ballast and the finished airframe came comfortable within our UK 20Kg max weight limit so no certification was needed to be able fly it.
Old 03-12-2017, 01:32 PM
  #54
heraldoboldrin
how many amps the light need each flight?
Old 03-12-2017, 08:55 PM
  #55
heraldoboldrin
someone is using powerbox with f16 PNP? what you do with battery? the black unit don'tt need battery?
Why has 7 air valves? is one for each cilinder?
someone has the manual to send me?
[email protected]
Old 03-12-2017, 11:06 PM
  #56
jeff sewell
The Central Controller uses power taken directly from the RX.
Valves for retracts, doors, wheel brakes and speed brakes..
I don't use Powerbox...
Cheers
Jeff
Old 03-14-2017, 07:54 AM
  #57
rob200970
Everything has gone together very well with no issues. If the weather holds out hopefully test flight will be at Elvington on Sunday. Just need to pinch Jeffs transmitter to copy his settings for surface travel etc, I have it all set up but best to have the same settings as a proven flier. Extremely pleased so far.
Model supplied by Jeff at Zedjet who is always a pleasure to deal with.
ID:	2205274   Click image for larger version
ID:	2205275   Click image for larger version
ID:	2205276   Click image for larger version
ID:	2205277   Click image for larger version
Old 03-14-2017, 08:08 AM
  #58
Mark Vandervelden
Your F16 looks fantastic in those colours, you cant beat a bit of Red, White and Blue "Jeff"
It certainly wont be lacking in umph with the PBS TJ-20 on board ;-)
All the best with your maiden, you wont be disappointed.
Old 03-14-2017, 09:49 AM
  #59
rob200970
Thanks Mark. I agree, can't beat a bit of colour....Jeff loves them really.
I will post after the maiden with hopefully good news.
Old 03-14-2017, 11:01 AM
  #60
jeff sewell
I love colour - as long as it's grey, green or multiple shades of brown - which is exactly what Rob's underpants will look like pre-maiden...
Jeff
Old 03-14-2017, 04:54 PM
  #61
heraldoboldrin
Anybody have the F16 manual to send to my email
[email protected]
Old 03-26-2017, 11:15 AM
  #62
rob200970
Well, finally got to maiden the F16 and as Jeff said in his original post, absolutely no dramas and a pleasure to fly. I did copy Jeff's movements of the surfaces and neutral points etc, but when there is another model exactly the same that is a proven superb flier, why not take advantage!!?
A few clicks of down trim were needed and a couple of right aileron, but once set straight and level flight was effortless. The model flies superbly (although maybe not in my hands) and has great presence. Landing approach takes a bit of getting used to after my normal sports models but to say I am happy is a massive understatement.
Thanks to Jeff for his support and advice (and of course sarcastic remarks), the two F16s look awesome together.
My underpants are still clean too!!!
ID:	2207128   Click image for larger version
ID:	2207129   Click image for larger version
Old 03-26-2017, 12:31 PM
  #63
jeff sewell
Great job Rob... just thinking your camera is sh*t though or maybe it was the photographer (me)
Great day at Elvington - perfect weather and banter.
Jeff
Old 03-26-2017, 01:48 PM
  #64
heraldoboldrin
Amazing Guys.... mine will arrive in 60 days... i will need that setup....rsrsrs
Old 03-27-2017, 01:04 AM
  #65
Mark Vandervelden
Well done Rob, she looks terrific out in the open.
Ill be up with you guys some time soon, we just might be able to have three out at one time!
"There seems to be a gray blur next to your F16 in these pictures with an orange fin behind it"
Old 03-27-2017, 01:55 AM
  #66
jeff sewell
Ram it...
Old 03-27-2017, 10:05 AM
  #67
lavi rider
Got 16 sorties on mine , power box mercury , superb flyer . Activated the gyro this last weekend for the first time using the test flight assistant .. three legs all it took to calibrate the gyro gain .. rock solid .
Old 03-27-2017, 10:20 AM
  #68
lavi rider
Default Pnp 1/5 f-16c iaf
Some shots of mine ...
ID:	2207305   Click image for larger version
ID:	2207306   Click image for larger version
Old 03-27-2017, 05:01 PM
  #69
General Jake
General Jake's Avatar
What gyro are you using?
Old 03-27-2017, 09:08 PM
  #70
lavi rider
The one integrated in the PB Mercury .
Old 03-29-2017, 12:38 PM
  #71
heraldoboldrin
Anyone order the pylon and ordinance kit? have pictures and weight?
Old 03-30-2017, 05:25 AM
  #72
General Jake
Guys, I just received mine and had a few questions:
1. The Fuse came assemble, are you guys taking it apart to check everything inside or just leaving it as is?
2. I plan on installing a P-200...are you guys using the Bypass? I know this turbine needs A LOT of air, so I am concerned with the bypass choking the engine.
3. Just a commit- Disappointed with the lame cockpit..at this price it should have functional MFD's.
Old 03-30-2017, 06:35 AM
  #73
jws_aces
My Feedback: (33)
jws_aces's Avatar
Originally Posted by general jake
guys, i just received mine and had a few questions:
1. The fuse came assemble, are you guys taking it apart to check everything inside or just leaving it as is?
No need to ... Just make sure you talk with bvm about wiring connections for the a/b ring
2. I plan on installing a p-200...are you guys using the bypass? I know this turbine needs a lot of air, so i am concerned with the bypass choking the engine.
Not using it on my k210g
3. Just a commit- disappointed with the lame cockpit..at this price it should have functional mfd's.
kidding right? If you got the bvm pnp for 10k you got a complete jet compared to others that size on the market with a lot less included for almost the same price.
If not BVM then i have no idea what you were promised for what you paid.
Old 03-30-2017, 06:47 AM
  #74
General Jake
It's a BVM.......not nocking it at all and looking forward to flying it. I felt the cockpit was an after thought..anyways, thanks for replying.
Old 03-30-2017, 07:31 AM
  #75
jws_aces
My Feedback: (33)
jws_aces's Avatar
It's all good. The AB ring requires a connection made to the RPM input on the black control box from the throttle out put of the RX. You can use a y harness. It stumps a lot of people.
