Reload this Page >
Jetlegend/BVM 1:5 F16 PNP
Old 04-24-2017, 06:35 PM
  #101
Viper1GJ
My Feedback: (20)
Viper1GJ's Avatar
Hi Heraldo,
I was flying my B300F powered SM 1/5 F-16 with Jeff this weekend. Got several nice flights in. I do not notice any trim change at all with the SB open. I usually extend the SB with the gear as per full scale when I remember. I forgot two times last weekend however and opened them on landing roll just for looks. However the main reason I would use them is to create drag to allow the power setting to be higher while in final turn and on final so as to reduce the spool up delay in case you need power quickly for a go around or to stop a sink rate. I found flying my final turn and final at a higher AOA and pitch attitude but slower airspeed helped keep the landing speed slower and roll out shorter. However it requires power all the way down and into the flare. I never came to idle before touch down all weekend. On two landings I was adding a little power in the flare to soften the touchdown. We were flying on a beautiful 200 acre sod farm so it was easy to "find the runway". It was everywhere and soft! It made me look better than I was!
Jeff kept me out of trouble with his great spotting and coaching calls also.
Best of luck with your next project.
Gary
Old 04-25-2017, 04:54 AM
  #102
General Jake
General Jake's Avatar
Originally Posted by Viper1GJ
Hi Heraldo,
Gary
That is Text book! Did you get any video to share? I'd love to see that! Chris
Old 04-25-2017, 05:49 AM
  #103
jws_aces
My Feedback: (33)
jws_aces's Avatar
Here is one of Gary's flights I recorded live on FB. Sorry no way to save and convert to youtube. I hope you can watch it.
This link will not work but you copy the address.
www.facebook.com/jeff.stubbs.71/videos/10208833885994326/
Old 04-25-2017, 06:09 AM
  #104
General Jake
I wanted a Number "5"...LOL Thanks for the link!
Old 04-25-2017, 06:11 AM
  #105
General Jake
Here's a copy of my "Viper" checklist...
Viper Checklist with Jetcat P200
Pre-flight
1. After setup – Walk around check
a. Control Surfaces
b. Wing tip secure
c. Vent plugs installed
d. Wheels
e. Tail cone secure
f. Vertical Fin and Rudder
g. Stabs
h. Gear Doors
i. Intake Clear of FOD
Fueling
2. Remove vent plugs
3. Remove and charge turbine battery
4. Attach jet A overflow
5. Attach Smoke overflow if using
6. Close fuel Valve
7. Close Smoke valve
8. Fill Jet A tanks and check for leaks
9. Fill Smoke tanks and check for leaks if using
10. Fill propane tank
Engine Start
11. Safety Team Briefed and ready
12. Check both Rx batteries voltage
13. Turn “on” Transmitter
14. Check Transmitter Voltage
15. Check Trim Settings
16. Check Transmitter model setting
17. Turn “On” both Jet switches
18. Fill Air Tanks 100 psi
19. Test Retracts
20. Refill to 100 psi
21. Reinstall Turbine battery
22. Confirm the following switch positiona. Gear Downb. Lights offc. Gyro Offd. Smoke offe. Airbrake offf. Canopy Upg. Brakes off
23. Fire Extinguisher ready
24. Leaf blower nearby
25. Fuel “On”
26. Smoke “On” (if using)
27. Nav Lights on
28. Set Turbine Trim for start
29. Engine Start set high throttle
30. After start set low stick confirm LED goes to “Green”
31. Smoke Check – Set 50% power turn on Smoke, turn off smoke
32. Run up turbine to 100% and return to idle, confirm After burner comes on
33. Remover Jet A hopper tanks
34. Remover Smoke hopper (if using)
35. Close Canopy – confirm Locked
36. Control surface check
37. Idle up brake check
38. Landing Lights on
Takeoff
39. Taxi into position and adjust nose wheel if needed
40. Confirm Gyro is off
41. Turn on Timer
42. Throttle up – Thunderbirds Gooooo
Shutdown
43. Note fuel level
44. Note PSI
45. Shutoff lights
46. Check intake for FOD
47. Shutdown turbine
48. Cool down with leaf blower
49. Turn off fuel valve
50. Turn off smoke valve
51. Remove and charge turbine battery
Old 04-25-2017, 05:16 PM
  #106
Viper1GJ
My Feedback: (20)
Viper1GJ's Avatar
Hi Jake,
Nice checklist. Mine is very similar. Mine started 16 years ago when I forgot to remove the vent plugs after flipping jet over to change turbine glow plug, and then took off. Pump caveated after TO, dead sticked ok. Came back with checklist the next day.
I just sanded my "1" off and repainted the white. Then put a upside down vinyl "5" in the circle.
Good luck on your jet.
Gary
Old 04-25-2017, 06:24 PM
  #107
General Jake
Hi Gary, I thought of doing that with the number...nice flying! Chris
Old 04-25-2017, 09:34 PM
  #108
Desert Fox 1
Hello All,
Sharing a video of Joe Rafalowski flying his BVM F-16 1/5 PNP
Cheers!
Desert Fox 1
Old 05-16-2017, 06:37 PM
  #109
heraldoboldrin
What CG are you using? and how much flap to land?
Old 05-16-2017, 07:32 PM
  #110
Desert Fox 1
heraldoboldrin,
Not my jet, I just videoed it flying at our field.
Cheers!
Desert Fox 1
Old 05-16-2017, 11:42 PM
  #111
lavi rider
Default 1/5 f-16
no flaps needed reason for that is more complex it involves the lack of LE flaps....
the Cg is 1cm behind the factory mark on the fuselage wing root ( it actually falls on the rear part of the circle mark there).
Old 05-17-2017, 02:36 AM
  #112
jeff sewell
We have moved the CG to 1"/25mm from factory and it could potentially go back further. As my friend says - no flaps needed really (it slows down very quickly).
Have fun...
Jeff
Old 05-17-2017, 03:46 AM
  #113
lavi rider
Some of us went back to 25mm ... it does have some draw back when flying at this setting though...
the model becomes more sensitive in pitch especially if one is operating on a windy day .. especially on flare or close to flare point when a gyro isn't used.
But when using a gyro it is a preferred CG point .
Im flying mine at one cm back to keep the model more stable , has an easier steerable glide ratio in case the gyro is off ( otherwise in a rewarded CG one will need to trim the model for a proper hands free glide ratio).
Any way the model is a real delight to fly .
Old 05-17-2017, 04:06 AM
  #114
jeff sewell
No gyro but getting the C/Pro fitted. Can't say it felt twitchy personally, but each to their own!
Old 05-17-2017, 06:59 AM
  #115
lavi rider
True and does have a lot to with ones set up as far as throws and expo set up .
From what you're writing here i feel you're flying on higher expo precentege .
Old 05-17-2017, 07:34 AM
  #116
jeff sewell
Yeah, I set it up similar to my 1:6 G2 F16 which I had flown for about 21/2 years so I was pretty confident that it would be okay. I used about 42% pos expo but reduced this as, even at the more rearward CG, felt a bit numb around the middle and actually harder to land smoothly! My 1:6 G2 had a very neutral CG position but the landing attitude was great and so predictable. It's taking me a while to dial the bigger one in as I've only had about 20+ flights so far.
Great model, as you say....
Old 05-22-2017, 09:16 AM
  #117
General Jake
Question for the guys flying with the Demon Cortex gyro - I have 4 flights on my BVM 1/5 scale F-16 and only turned on the gyro for a quick flight test. I was told not to use it for cruise and high speed flying, I was told to only use it for takeoff and landing, is this true?
I have the Gyro installed and setup so my slider switch is Off to On, but "on" is Amber only mode, and never goes to Green mode or "heading Hold".
I don't have the USB cable, so am using the factory settings.
My question is, are you guys using the gyro during the entire flight (High Speed) or just takeoff and landing.....
Chris
Old 05-22-2017, 03:36 PM
  #118
Viper1GJ
My Feedback: (20)
Viper1GJ's Avatar
Chris,
I use my gyro full time, take off to landing. I do not use heading hold, only normal mode. I adjust the gain from 0-100% with a rotary knob in the Amber only normal mode. I have been normally flying between 20-40 % with full time gyro. Works great and really helps in gusty wind.
Gary
Old 05-23-2017, 04:07 AM
  #119
General Jake
Chris,
Gary
Gary,
I have the Cortex set on my LS switch so it's either off or 0% - %100 on AMBER only...I'll try it next time I fly for the entire flight...So far I'm loving this jet...BTW, I am getting 10 minutes with reserve with my P-200!
Thanks for the response, Chris
Old 05-25-2017, 03:17 AM
  #120
rob200970
I have now had approx 20 flights on mine and it gets better and better every flight. Have the Demon Cortex Pro fitted and running 35% gain which smooths everything out very well especially on landing approach. I have it enabled in normal mode only from take off to landing and it has made a huge difference. I can not fault the model and it flies superbly (just the pilot needs to improve!!) I never use flaps for landing but might experiment with the speed brakes next time out just for an added bit of realism.
With the PBS TJ20 fitted I have the timer set at 8mins and always have plenty left in the tanks which gives confidence should I ever need to overshoot or hold off landing for any other reason.
Old 05-31-2017, 07:19 PM
  #121
Viper1GJ
My Feedback: (20)
Viper1GJ's Avatar
Can some one tell me the fuel capacity of the main tanks. I can't find that info anywhere. Are the fuel tanks on the CG or forward?
Also I read above that the smoke tanks have 2.4L each which makes 4.8L total. Is this correct? That is over 160 oz of smoke fluid capacity if I understand it correctly.
Gary
Old 05-31-2017, 11:12 PM
  #122
Mark Vandervelden
Mark Vandervelden's Avatar
Hi Gary
Main tanks have a total capacity of 5.2lt as per post 36.
I've found this plenty for my Jets Munt M200 giving 7+ minuets with the fuel level going down to the turbine rails, there is then a further 2lt left at that point.
They sit very slightly behind the recommended factory (JL) CG but as far as I know everyone including myself has moved the CG back and they are now right on the CG.
The smoke tanks are indeed 2.4lt each so a bit OTT and are also quite forward of the CG.
One or two guys have re-plumbed them to use one as extra fuel, my self I simply removed the both as I am not a big fan of smoke.
Hope this helps, Mark V
Old 06-01-2017, 05:16 AM
  #123
General Jake
The retracts, and air brakes consume a lot of air, and the manuals states to fill only to 90PSI...What are you guys filling your tanks too?
All my other jets I always went to 100PSI, not sure why this one requires less?
Also, weight is your weight, minus fuel?
Chris
Old 06-01-2017, 05:28 AM
  #124
jws_aces
My Feedback: (33)
jws_aces's Avatar
Chris
I added another large air tank on mine. I had some issues with the solenoids no working against to much pressure about 100psi. A tip is the lines from the holding tanks to the distribution block are bigger than the 2mm and no locks on them. I had one of mine get hard and leaked. I replaced those air lines with the robart type that stays softer and stays on. No leaks at all. I was having a door up solenoid hanging up all the way down to 85 psi. I simply switch airlines and connectors with another to find one that would function above 90psi problems solved. I taxi out with 95 to 96psi on the box. I can cycle the gear 3 times and still be above 75psi, I like the higher one time retract becuase it will hold the front door closed better in flight.
Great system just takes a little playing with it to get it perfect.
Old 06-01-2017, 07:29 AM
  #125
General Jake
Thanks Jeff!!
