Experience sullivan proflex tubing and JetA?
My Feedback: (48)
Sullivan Proflex is FKM (fluoroelastomer), which is resistant to gas/oil/diesel/kero. However, there are a number of different classes of FKM with varying degrees of chemical and heat resistance. Sullivan does not say which class of FKM they use. It is widely used inside automotive fuel tanks, some grades of FKM hold up better than others in gasoline (which is a worse environment than kero or diesel). For our applications it's a lot better than Tygon and should last indefinitely.
FKM was invented by Dupont, and their trade name for it is Viton. Personally I use soft Viton tubing from McMaster-Carr inside the fuel tanks on all of my jets and gassers. https://www.mcmaster.com/#viton-fluoroelastomer-tubing/=15m41ws
I have used Sullivan Pro Flex fuel tubing sense it came out. About a month and a half. It is very flexible. Does not collapse under use. It stays flexible in tank and out. I tested it in a tank. I installed it in a tank and then filled it with 92 octain gas with Redline oil. It has been in the gas for about 2 months. Still flexible . Did not harden. I know. Your going to say it hasn't been out that long. Sullivan sent some test tubing to me. thats how I got it. I just ordered more from Tower Hobbies. Got it yesterday. 12 feet for approx $ 30. Will never use Tygon or Viton again. Nice to see the fuel tubing just hanging limp from the fill dot and not sticking straight out. Love it.
I used some in a gas tank for a 3D plane and it’s so flexible the clunk lodged in the front of the tank and caused a dead stick. The tank was pretty small so I was surprised to see that it flexed enough to jam. So in the future I’m going to have to change how I run the pick up. Other then that issue I really like not having to worry about the tygon stiffie
