AD Scorpion: Winter project #2.
Getting started on winter project #2, AD Scorpion from AltecareRC. Now that AD has moved production to Czech Republic, the build quality is very good. Paint scheme looks cool too. Will be powered with a Behotec 180. Guided by Jeti Duplex.
...jim
...jim
PA
Love the looks of that model. I tried to buy a small one (e Scorpion) a few years ago, but was told they were being discontinued, and the only one they had left was a paint scheme I didn't like.
I'm building now AD scorpion from Altecare exactly same to your color. the plywood is a servo elevator shim because regular servo is too small
excuse my english but is not my first
My Feedback: (21)
Jim, Question, I have one still in the box from three years ago, which is part started, when I bought mine there was take of adding gear doors to the next version, V3 I believe, does your SS have gear doors?
And yes looking forward to watching your build for any ideas, especial with the servo configuration for the elevators.
Robert
Robert
More 3D printing fun...
Made a jig to get the pipe/turbine centering and depth at least TLAR.
Wasn't keen on the way they wanted the air brake ram to be mounted, so came up with my own way. It also incorporates a couple of tabs to keep the air brake from closing too far.
Since I need two air valves (retracts and air brake) decided to stack them and save some space. Yes, there is enough room above the retract valve to get the air lines in without kinking them.
Also made a mount for the brake valve.
Still to come: Air tank mount, electronics mounts, ECU mount and fuel pump/soloniods/filter mount.
Yep, I'm having fun!
...jim
...jim
