Reload this Page >
Skymaster 1/6 F-16 vs F-4 Phantom
Old 02-04-2017, 02:56 PM
BlueBus320
My Feedback: (57)
Default Skymaster 1/6 F-16 vs F-4 Phantom
Any thoughts?
Old 02-04-2017, 02:57 PM
SECRET AGENT
My Feedback: (18)
SECRET AGENT's Avatar
Guess it depends on if you like old or new fighters?
Old 02-04-2017, 03:11 PM
luckymacy
None of the above. Skymaster F-15 or F-100... :-)
Old 02-04-2017, 03:14 PM
BlueBus320
My Feedback: (57)
I guess the real question is which 1st? I think the F-4 flies more on rails, but 16's a lot more maneuverable. I've owned both from different companies, but haven't had either Skymaster.
Old 02-04-2017, 03:30 PM
raron455
My Feedback: (38)
raron455's Avatar
I currently own a G2 Skymaster F16, and have owned 3 others,, they fly absolutely fantastic, I dont think think the phantom would let you get away with 1/2 of what the 16 will.
Old 02-04-2017, 03:41 PM
BlueBus320
My Feedback: (57)
Agreed! How'd you like your gen1 16s? Is there a big difference between gen1 & 2?
Old 02-04-2017, 04:02 PM
raron455
My Feedback: (38)
raron455's Avatar
2 of mine were gen 1 planes, they were strong and flew great. No complaints at all.
Sm says the Gen 2 is lighter, I call BS on that, all of mine have weighed in well over 40lbs. One difference is that the top access hatch is actually smaller on the G2, making putting the 3 fuel tank installation a PITA. The G2 the panel lines are much better and super accurate, the lines are even and consistent, they look fantastic. On all of mine the gear door cylinders did not leak and held air, but they are still not up to the task of holding closed when some speed is presented. If you go a full bypass setup I bet they would be fine, but I just run the lower bypass with the inlet duct. I replaced the cylinders on the others with larger 7/16 UP cylinders and that holds em closed. My current one is my favorite of all, flies like a dream and looks scale doing it (unlike the BVM-Jetlegend F16, which is NOTICABLY lighter). On all of mine the paint was really good, except my current one, It is GREAT, the factory did some weathering on it, and it turned out great. I am not saying anything about the F4, I have seen a few, and A buddy of mine is building one right now, and they are a badass for sure, but they do not fly the same, the 16 is an easier bird to handle than the F4.
Old 02-04-2017, 04:09 PM
BlueBus320
My Feedback: (57)
Thanks Ronnie.. I'm working on a trade deal, & the guy is offering me my choice of gen1 16 & F-4. Tough choice IMO.
Old 02-05-2017, 07:20 AM
dubd
dubd's Avatar
Get both. Ultimately it may come down to which one you think looks better. They both fly great.
ID:	2199742   Click image for larger version
Old 02-05-2017, 08:13 AM
BlueBus320
My Feedback: (57)
Agreed!
Old 02-05-2017, 10:30 AM
kevinthoele
They both fly great. However I love my Skymaster F4 the best of any jet I have owned. I am actually ready to do another one and have 2. I just need to sell something to have space to store. Yellow F18 Twin, Dan Gill panther, Feibao F15, Skymaster T38....One of those should give me space.
Good luck with your selection but I think you would be happy with either
Old 02-05-2017, 03:44 PM
BlueBus320
My Feedback: (57)
Thanks Kevin! How many pounds of thrust do you think is good for the Phantom to fly/takeoff/go around nicely?
Jay
Old 02-05-2017, 04:31 PM
RCFlyerDan
My Feedback: (54)
RCFlyerDan's Avatar
Another question to add to the conversation. How are the retracts on the 1/7.75 F-4? Well built and reliable? Or is there a better option? Thx!
Old 02-05-2017, 04:36 PM
dubd
dubd's Avatar
Jay
My first F-4 had a P-200. My second has a K-210. A friend had one with a 160sx and it was anemic even at sea level. He put a K-180 and he was
much happier with the performance.
My K-210 powered F-4
https://youtu.be/wGFHo6P40l0
My old P-200 powered F-4
https://youtu.be/UgyvGWKlhCs
Old 02-05-2017, 04:46 PM
BlueBus320
My Feedback: (57)
Thanks Dantley! He currently has a 36lb Rhino, & what he says corroborates everything you've just said. He said once on step 36lbs will push her, but the TO & 1st turn are a bit marginal. How would I go about finding out if the current existing fuel system & pipe are up to a 40-50 lb thrust turbine?
Old 02-05-2017, 04:52 PM
BlueBus320
My Feedback: (57)
Nice vids too.. could be in my head, but it seems to have more authority with the 200
Old 02-05-2017, 05:14 PM
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
Fuel system is plenty for comfy 8 min with an old airstart Olympus. Unknown pipe capability, I went with a TAM pipe.
Old 02-05-2017, 06:17 PM
BlueBus320
My Feedback: (57)
Thanks Buck! I got a JB220 I think I can shoehorn in there��
Old 02-05-2017, 06:32 PM
dubd
dubd's Avatar
It did have more push with the P-200. Very noticeable in a vertical. The climb was unlimited with the P-200.
Old 02-05-2017, 07:02 PM
sideshow
sideshow's Avatar
get both. ultimately it may come down to which one you think looks better. They both fly great.
lolol
Old 02-05-2017, 08:48 PM
Digital Pilot
Digital Pilot's Avatar
Really comes down to your flying style. I have had both as well.. The F16 is way more maneuverable at slow speeds, F4 is more of a fast mover. Both great flyers in there own way...
Old 02-06-2017, 08:27 AM
BlueBus320
My Feedback: (57)
Thank you sir. It truly does seem like the answer is both. It looks like that's the way I am headed.
Jay
Old 02-06-2017, 09:11 AM
Digital Pilot
I was just talking to Dirk at Pacific RC Jets. He has a 1/7 phantom in stock. Camo I think.
Old 02-06-2017, 09:51 AM
kevinthoele
I have the K210 in mine and love the power. I think you could go to as little as 180 and be happy. For me it handles the big block perfectly so go with a 200 class turbine of your choice would be my recommendation. Also the gear are great and have worked perfectly every flight No need to change. This is not the Xtreme arf gear maybe you are thinking of. These gear a well designed by Dr. Laikai and work awesome.
Old 02-06-2017, 10:06 AM
kevinthoele
I too went with the Tam pipe. With Tams pipe my 210 had every bit of the performance of the P200 in the video. I have not flown with stock 200 class pipe so not sure about it
