Electric brakes
My Feedback: (21)
Electric brakes
Hello
I am converting a set of wheels to electric brakes. I have always used pneumatic and have always greased the o-ring.
My question is to those of you using the electric, magnetic brakes, are you putting grease between the magnet and the brake plate?
Joe Lewis
Kingtech
K-80
K-140
K-180
Owner
Joe Lewis
Kingtech
K-80
K-140
K-180
Owner
PA
I guess it depends on the manufacture. But on mine... I don't.
The reason we use grease on the O-rings, is because the rubber will just grab. On the e-breaks... there's no rubber, and they will slip on their own.
My Feedback: (40)
Craig
My Feedback: (20)
I just installed Electron ER-50s in my Sabre XLT sport jet with the GS-200 controller. Brake power is adjustable on each side to allow a straight roll during braking. Also the GS-200 has internal gyro that will automatically adjust braking power to keep straight. It also has a pulse mode that works like anti skid. I have tested it several times in back yard but have not flown yet. Hope to test fly this weekend.
Electron GS-200 controller showing max braking on both sides.
Taxi tests in grass worked well and braking was adjusted for straight roll out.
NY
That's the same as the gaspar unit dreamworks sells. The unit is really amazing because the gyro works on the nose wheel and the mains with differential braking to keep the model straight as an arrow. I spent some time testing it in Boomerang XL last year and I am really pleased with it.
