Reload this Page >
Merlin 140
Merlin 140
Old 03-05-2017, 01:08 PM
jesse2357
Default Merlin 140
I just ordered a Jetmunts 140, and I'm trying to find some info on so I can order stuff I need. Questions I have is what accessories comes in the box and what size is the fuel line going into the engine?
Old 03-05-2017, 01:11 PM
siclick33
Fuel line is 4mm. New engines now have several options available so what's in the box varies according to what you've ordered.
Old 03-05-2017, 04:35 PM
raron455
My Feedback: (38)
raron455's Avatar
Is it a new engine or older,,I have a 160 and am familiar with the engines.
Old 03-05-2017, 05:13 PM
jesse2357
It's a brand new 140 witht he color screen and telemetry adaptor. I was more curious if it came with a fuel shut off valve and fuel tubing but since you say it's 4mm I have one already.
Old 03-05-2017, 08:59 PM
scoeroo
My Feedback: (9)
scoeroo's Avatar
With the new Merlins , all valves are contained in the turbine it self , engine will come with all that is needed , if need be the patch lead from ECU to turbine can be lengthened to suit application
Old 03-06-2017, 04:48 AM
LA jetguy
LA jetguy's Avatar
Congratulations on your new M140XBL... you will like the engine. I have several ..
Usually prior to shipping Sonia will contact you to confirm shipping address and your order. If this is your first JM turbine you will need a system analyzer... as you said the new ones have a very nice color screen. You can eliminate that on your future turbine orders.
I usually don't get the battery (2 cell LiPo 2100)... I use my own and based on CG, the size of my batteries varies.
I would strongly suggest a FOD screen... it's a good insurance ..
The rest in the box is standard... brushless pump, fuel filter, ECU, wiring harnes (ECU to turbine and Battery to ECU), fuel tubing (4mm and 6mm). Tank /UAT to fuel pump is 6mm, and pump to turbine is 4mm and of course the M140XBL, and manual and stickers.
I dont use a fuel fuel shut off valve and its not included.
David
Old 03-06-2017, 05:33 AM
siclick33
I seem to remember they supply a Festo fuel filter. I don't use these as I have seen them crack and leak. Everything else in the box is top quality.
Old 03-06-2017, 05:59 AM
LA jetguy
LA jetguy's Avatar
As long as you use the festo filter before the pump they work perfect. The manual recommends prior pump installation.
David
Old 03-06-2017, 07:20 AM
siclick33
We'll have to agree to disagree.
Old 03-06-2017, 07:59 AM
raron455
My Feedback: (38)
raron455's Avatar
+1
Old 03-06-2017, 09:15 AM
jesse2357
I ordered the custom cause I pay way less for Lipo's and I'm probably going to put a 2s5000 depending on balance in my ultraflash. I also ordered the fod screen and telemetry adaptor. I placed the online order last Wednesday as Gaspar had said it would take 2 weeks but somebody cancelled their order for their turbine and it was testing last Thursday paid on Friday and shipped this mourning. Just awesome service so far. should be a great pairing for my UF
