Analog servos on Non essential
My Feedback: (21)
So now I am really confused.
I have been flying my HP Jets F-86 and my Isobar with digital servos on the flying surfaces and small analog servos on the gear and brakes and the speed brakes on the Sabre. The RX in the sabre is a 9 channel JR DSM2 R921and in the Isobar a 12 channel spektrum power safe AR12100 DSM2. I have flown both of these in the past on a JR12X.
Last summer I switched to a DX18 Airware. I put several flights on the Isobar and only 1 on the HP Sabre (engine was at 25 hours).
I read about the recall on the new telemetry RX's from specktrum. I had called asked them about the AR12120 DSMX Power safe RX because I heard that there was suppose to be some issue with that one.
I recently crashed a jet with that RX and xpansion module in it. I did have some analog servos on the non essential's. Canopy, speed brakes, and landing lights.
So the confusion is. I asked Horizon about running a mix of analog and digital servos, there comment was that the rx's need to have all digital servos on it.
A friend of mine is flying a Bobcat with a mix of digital and analog on flying surfaces. He has put a number of flights on last summer with no issue, not sure what RX he is using but I believe it is the Specktrum 9 channel DSMX with out power safe Using a DX 18 Second Gen TX.
So can I use the different servos in the same air frame or not.
I'm so conffused
Joe
I'm so conffused
Joe
My Feedback: (22)
I have spectrum rx's, both powersafe and non power safe and use a combination of digital and analogue servo's in all of my jets. Some jets even use plain old 3 pole cored servo's on things like valves. I have pylon racers and sport planes with spektrum receivers that use 30 year old analogue servo's. Some pylon planes have a combination of digital, coreless, and 3 pole servo's with high frequency vibration screaming engines on them.
I have never seen or heard any warnings about mixing servo's in instruction manuals, online or otherwise. Spektrum or JR 2.4 receivers. The only thing I ever had a problem with was when I switched to 2.4 I had an amplified Y harness in my kingcat, it didn't like that with JR8611 servo's. I swapped out the Y harness and used 2 channels instead and never had a problem. I've used non amplified Y harness's in other jets including the flaps on my Firebird and never had an issue there either.
My Feedback: (21)
I do know that if you use the 22 ms on the TX then you do have to use digital servos. If you activate the Xplus the TX will automatically switch back to the 11ms. With that said that tells me that as long as I am on the 11 ms frame rate then analog can be used.
Thanks Joe
Thanks Joe
My Feedback: (7)
Thanks Joe
Thanks Joe
