How big of a smoke tank for a 160-210 size turbine
My Feedback: (34)
I'm rebuilding a lightly crashed Avation Diamond. I'm currently building my fuel tanks and I'm copying the originals just a few oz bigger.
So im try to build the smoke tank but I'm trying to decide between building a 40oz or 50oz smoke tank.
So my question how big of a smoke tank would you want for a 160-210 size turbine? Thanks
My Feedback: (8)
There is no relation between the size of the smoke tank and the size of the turbine. It really depends on how much room you have for a smoke tank. I have a 120 turbine with a 48oz smoke tank. Also I want thick smoke so I have the smoke turned up as fast as it will run. Also running two sticks
My Feedback: (40)
Go with the 50oz Mike. Bob-o's right about the size of the engine not really being a factor.
My Feedback: (40)
On my new Natrix, I'm running just one of Dreamworks "Super Stick" injectors with a JetCat smoke pump. The set up puts out great smoke (Super Dri oil) but after about 70% throw the smoke does not noticeably increase. I now have it set to 70% at full throw and manage to get longer burns per/flight. I haven't timed it but I guess I'm getting 4 minutes or so of smoke with about 50oz of oil.
