Aircraft grade Finnish plywood offer.
Dear all.
As part of our effort to offer the very best quality materials to the market, I would like to introduce you to our latest product. The aircraft grade Finnish birch plywood that we use in our kits.
This plywood is my to my specifications, directly imported by us and of the highest grade available in the USA. It far outperforms any hobby grade products and was initially developed to provide aircraft manufacturers with the highest quality plywood for the most demanding applications.
It is made in Finland to the highest quality standards, using 100% Finnish birch.
Each veneer sheet is optically scanned for completely default free aspect and is glued with a European sourced class 3 exterior bond and super high loads in calibrated presses.
The result is a material offering the highest possible strength and resistance to shocks to bending ratio.
Our aircraft grade plywood comes with a certificate of compliance to EN 13986:2004+A1 standards.
It is offered in AB/ AB quality ( the highest possible surface quality ) with a high number of plies and tight dimensional tolerance.
We distribute it in 2 plate sizes:
40 cm x 60 cm ( 15.75" x 23.62" )
30 cm x 40 cm ( 11.81" x 15.75" )
and the following thicknesses:
2 mm ( 0.079" , ca 5/64") featuring 4 plies
3 mm (0.118" , ca 1/8" ) featuring 6 plies
4 mm ( 0.157" , ca 5/32" ) featuring8 plies
5 mm ( 0.197" , ca 3/16" ) featuring10 plies
It is available on our web site at the following address:
https://www.ultimate-jets.net/products/aircraft-grade-finnish-birch-plywood
I hope that this material will fulfill the needs of the most demanding builders and offer a good solution for repairs and upgrade from low quality Chinese plywood.
We can offer CNC cutting services from this material or carbon fiber plates, carbon/ Airex plates on demand. Our CNC routers can process sheets of up to 42” by 42”.
Hi Oli, this is great. Lately everything I have bought from the market has been junk. One section was okay and the rest with so many defects that it was not usable.
looking forward to get some.
Behzad
Behzad
This plywood is much more resilient to shocks than carbon fibers, for sure. Stiffness is a bit lower but not by much.
I have not checked density comparatively but a plain sheet of plywood must not be much heavier than carbon fiber.
It could actually be an interesting idea to make a comparative table with proper testing.
Consistency in the product is 100%.
It comes with a stamp, certificate of conformity to EN standards and origin, including batch number.
Just like we proceed with our CG machines...
For information, we just received another batch of aircraft grade Finnish birch plywood.
With our production line going at max capacity now, we are getting a regular upply of this product.
The plates are 100% traceable, from renewable birch forest and manufactured to the highest quality available anywhere in the World.
Each plate comes stamped with the batch number and certificate of origin and compliance.
We use this plywood in all our builds, except the Sr-71/ A-12 which is full carbon fiber...
Oli,
How compatible is this plywood with laser cutting?
I've had variable success with cutting 1/8 ply on 2 different laser cutters; an Epilog Zing 50W and a Ten-High 4060 50W.
National Balsa 1/8" 6-ply just doesn't seem to work with either cutter - It gets halfway through then chars significantly. I suspect its the glue that is causing the issue.
Balsa USA 1/8" 5-ply - seems to cut in a single pass on the Epilog without significant charring, but needs at least 4 passes with the Ten-High but with some moderate charring. A single pass with the Ten-High needs full power and a slow speed which burns the wood badly.
Still looking for the best 1/8" 5-ply to laser cut.
Paul
Paul
Oli,
Paul
Paul
However I can send you some scraps to test it out.
I know Finnish high grade plywood is just fine with tripled Nd-YAG laser but can't comment how it works on IR and CO2.
That 455nm laser I used may not be the cheapest choice for hobby use tough...
/Jyri
/Jyri
