Introducing the Top RC Model Aspire - New sport jet - build thread
#53
The Aspire fly's very well , have now 6 flight with him.
At 50% gas stick it fly of the runway , i have 16 KG of trust max .
I made a little mix for knife edge , rudder stick to ailerons (17 %) in the same direction.
flying start weight is with 4.2 liter (75 % of the tank) is 17,4 KG.
After the fight of 7 min . i have 1.2 liter in the tank.
empty weight is 14.100 KG with the hopper full.
#73
Thank you
So it looks like the Aspire is heavier than the Odyssey, even though the Aspire has a smaller wingspan. I wouldn’t have expected that.
I was trying to understand why the Aspire seemed to always be sitting nearly flat on its struts whereas the Odyssey sat higher ... I think they use the same struts from TopRC?
17kg wet with 3/4 tank might be too heavy for my 140 Cheetah SP turbine since I fly off grass. I think I may need to get a 160 turbine for this jet.
#74
My Feedback: (51)
Thank you
i think 140 is more than enough for the Aspire on grass. 160 is very powerful as you can see in my video.
#75
I assume you were not near 100% throttle on your flights ! So I guess I can try the JetCentral Cheetah SP 140 and see how it goes. I'll try and keep things light as possible. If not, then it looks like I buy a new turbine,,,
I also noticed in one of your videos that the fin on the top of the fuselage is molded in? I thought the original version of the Aspire had 2 different options: vertical shark fin and a horizontal T canalyzer? Did they stop that in later builds? In any event the knife edge performance obviously looks very good !
It's odd that this plane is heavier with less wing area than the Odyssey but still seems to fly very very well.
